Home » Eclipse Projects » Plugin Development Environment (PDE) » Feature build.xml not generated in headless build
Feature build.xml not generated in headless build [message #602888] Sun, 25 October 2009 08:28 Go to next message
Franck Mising name is currently offline Franck Mising nameFriend
Member
I am trying to set up a PDE headless build for a feature, and the build fails in the genericTargets.xml cleanElement target.
That target tries to invoke a clean target in the feature/build.xml file which generateScripts has not generated - generateScripts only generates build.xml files for each plugin that make up the feature, but not for the feature itself.
Is generateScripts supposed to generate a feature build.xml? Or do I need to adjust something build.properties so that the build stops looking for that file?
If I right-click feature.xml in the IDE and select "PDE Tools -> generate ant build file" the same thing happens, I get one build.xml file per plugin but not for the feature itself.
By build.properties file is below, any suggestion appreciated!
topLevelElementType = feature
topLevelElementId = com.fairisaac.eclipse.features.advisor
#product=/plugin or feature id/path/to/.product
runPackager=true
#archiveNamePrefix=
archivePrefix=eclipse
collectingFolder=${archivePrefix}
configs = *, *, *
allowBinaryCycles = true
outputUpdateJars = true
zipargs=
tarargs=
buildDirectory=C:/eclipse
buildType=I
buildId=Nightly
buildLabel=${buildType}.${buildId}
timestamp=007
base=C:/
baseLocation=${base}/galileo
baseos=win32
basews=win32
basearch=x86
filteredDependencyCheck=false
resolution.devMode=false
#pluginPath=
skipBase=true
eclipseURL=<url for eclipse download site>
eclipseBuildId=<Id of Eclipse build to get>
eclipseBaseURL=${eclipseURL}/eclipse-platform-${eclipseBuild Id}-win32.zip
skipMaps=true
mapsRepo=:pserver:mailto:anonymous@example.com/path/to/repo
mapsRoot=path/to/maps
mapsCheckoutTag=HEAD
mapsTagTag=v${buildId}
skipFetch=true
logExtension=.log
javacDebugInfo=false
javacFailOnError=true
javacVerbose=true
Re: Feature build.xml not generated in headless build [message #602892 is a reply to message #602888] Sun, 25 October 2009 10:31 Go to previous message
Member
Found the issue, build.properties was missing in the feature directory which causes the PDE Build to consider the feature as binary.
Previous Topic:Feature build.xml not generated in headless build
Next Topic:Is it possible to set plugin and feature versions from ant build?
Current Time: Fri Jun 22 05:49:03 GMT 2018
Powered by FUDForum. Page generated in 0.01971 seconds
