Home » Language IDEs » AJDT » "Property marker value too long" exception during build
"Property marker value too long" exception during build [message #601077] Mon, 28 June 2010 09:29 Go to next message
Sean Hodges is currently offline Sean HodgesFriend
Has anyone seen this error? I started getting last week, it occurs during a build, and causes the build to fail. I've provided the full stack trace at the bottom of this post.
I suspect I'm getting a build failure in my project; and AJDT is throwing an internal error when trying to log/display it because the classpath is too large...
The project itself is not especially large, but it does have around 120 dependencies for Spring, Hibernate, CXF, etc.
I'm not sure what to do from here, beyond uninstalling AJDT completely. Any ideas for work-arounds?
org.eclipse.core.runtime.AssertionFailedException: assertion failed: Marker property value is too long: Building with settings:
-> output paths: /home/sean/Documents/MarketPlace/src/target/classes, /home/sean/Documents/MarketPlace/src/target/test-classes
-> classpath: /home/sean/Documents/MarketPlace/src/target/test-classes:/ho me/sean/Documents/MarketPlace/src/target/classes:/home/sean/ .m2/repository/javax/activation/activation/1.1.1/activation- 1.1.1.jar:/home/sean/.m2/repository/javax/persistence/com.sp ringsource.javax.persistence/1.0.0/com.springsource.javax.pe rsistence-1.0.0.jar:/home/sean/.m2/repository/javax/servlet/ com.springsource.javax.servlet/2.5.0/com.springsource.javax. servlet-2.5.0.jar:/home/sean/.m2/repository/javax/servlet/co m.springsource.javax.servlet.jsp.jstl/1.2.0/com.springsource .javax.servlet.jsp.jstl-1.2.0.jar:/home/sean/.m2/repository/ javax/transaction/com.springsource.javax.transaction/1.1.0/c om.springsource.javax.transaction-1.1.0.jar:/home/sean/.m2/r epository/javax/validation/com.springsource.javax.validation /1.0.0.GA/com.springsource.javax.validation-1.0.0.GA.jar:/ho me/sean/.m2/repository/javax/xml/bind/jaxb-api/2.1/jaxb-api- 2.1.jar:/home/sean/.m2/repository/javax/transaction/jta/1.1/ jta-1.1.jar:/home/sean/.m2/repository/javax/mail/mail/1.4.1/ mail-1.4.1.jar:/home/sean/.m2/repository/javax/xml/soap/saaj -api/1.3/saaj-api-1.3.jar:/home/sean/.m2/repository/javax/xm l/stream/stax-api/1.0-2/stax-api-1.0-2.jar:/home/sean/.m2/re pository/antlr/antlr/2.7.6/antlr-2.7.6.jar:/home/sean/.m2/re pository/asm/asm/2.2.3/asm-2.2.3.jar:/home/sean/.m2/reposito ry/cglib/cglib-nodep/2.1_3/cglib-nodep-2.1_3.jar:/home/sean/ .m2/repository/org/antlr/com.springsource.antlr/2.7.6/com.sp ringsource.antlr-2.7.6.jar:/home/sean/.m2/repository/com/mys ql/jdbc/com.springsource.com.mysql.jdbc/5.1.6/com.springsour ce.com.mysql.jdbc-5.1.6.jar:/home/sean/.m2/repository/edu/em ory/mathcs/backport/com.springsource.edu.emory.mathcs.backpo rt/3.1.0/com.springsource.edu.emory.mathcs.backport-3.1.0.ja r:/home/sean/.m2/repository/edu/oswego/cs/concurrent/com.spr ingsource.edu.oswego.cs.dl.util.concurrent/1.3.4/com.springs ource.edu.oswego.cs.dl.util.concurrent-1.3.4.jar:/home/sean/ .m2/repository/org/jboss/javassist/com.springsource.javassis t/3.3.0.ga/com.springsource.javassist-3.3.0.ga.jar:/home/sea n/.m2/repository/net/sourceforge/cglib/com.springsource.net. sf.cglib/2.1.3/com.springsource.net.sf.cglib-2.1.3.jar:/home /sean/.m2/repository/net/sourceforge/ehcache/com.springsourc e.net.sf.ehcache/1.4.1/com.springsource.net.sf.ehcache-1.4.1 .jar:/home/sean/.m2/repository/net/sourceforge/jsr107cache/c om.springsource.net.sf.jsr107cache/1.0.0/com.springsource.ne t.sf.jsr107cache-1.0.0.jar:/home/sean/.m2/repository/org/aop alliance/com.springsource.org.aopalliance/1.0.0/com.springso urce.org.aopalliance-1.0.0.jar:/home/sean/.m2/repository/org /apache/commons/com.springsource.org.apache.commons.beanutil s/1.8.0/com.springsource.org.apache.commons.beanutils-1.8.0. jar:/home/sean/.m2/repository/org/apache/commons/com.springs ource.org.apache.commons.collections/3.2.0/com.springsource. org.apache.commons.collections-3.2.0.jar:/home/sean/.m2/repo sitory/org/apache/commons/com.springsource.org.apache.common s.dbcp/1.2.2.osgi/com.springsource.org.apache.commons.dbcp-1 .2.2.osgi.jar:/home/sean/.m2/repository/org/apache/commons/c om.springsource.org.apache.commons.digester/1.8.1/com.spring source.org.apache.commons.digester-1.8.1.jar:/home/sean/.m2/ repository/org/apache/commons/com.springsource.org.apache.co mmons.fileupload/1.2.0/com.springsource.org.apache.commons.f ileupload-1.2.0.jar:/home/sean/.m2/repository/org/apache/com mons/com.springsource.org.apache.commons.io/1.4.0/com.spring source.org.apache.commons.io-1.4.0.jar:/home/sean/.m2/reposi tory/org/apache/commons/com.springsource.org.apache.commons. logging/1.1.1/com.springsource.org.apache.commons.logging-1. 1.1.jar:/home/sean/.m2/repository/org/apache/commons/com.spr ingsource.org.apache.commons.pool/1.3.0/com.springsource.org .apache.commons.pool-1.3.0.jar:/home/sean/.m2/repository/org /apache/el/com.springsource.org.apache.el/6.0.20/com.springs ource.org.apache.el-6.0.20.jar:/home/sean/.m2/repository/org /apache/log4j/com.springsource.org.apache.log4j/1.2.15/com.s pringsource.org.apache.log4j-1.2.15.jar:/home/sean/.m2/repos itory/org/apache/taglibs/com.springsource.org.apache.taglibs .standard/1.1.2/com.springsource.org.apache.taglibs.standard -1.1.2.jar:/home/sean/.m2/repository/org/apache/tiles/com.sp ringsource.org.apache.tiles/2.1.3/com.springsource.org.apach e.tiles-2.1.3.jar:/home/sean/.m2/repository/org/apache/tiles /com.springsource.org.apache.tiles.core/2.1.3/com.springsour ce.org.apache.tiles.core-2.1.3.jar:/home/sean/.m2/repository /org/apache/tiles/com.springsource.org.apache.tiles.jsp/2.1. 3/com.springsource.org.apache.tiles.jsp-2.1.3.jar:/home/sean /.m2/repository/org/apache/tiles/com.springsource.org.apache .tiles.servlet/2.1.3/com.springsource.org.apache.tiles.servl et-2.1.3.jar:/home/sean/.m2/repository/org/dom4j/com.springs ource.org.dom4j/1.6.1/com.springsource.org.dom4j-1.6.1.jar:/ home/sean/.m2/repository/org/hibernate/com.springsource.org. hibernate/3.2.6.ga/com.springsource.org.hibernate-3.2.6.ga.j ar:/home/sean/.m2/repository/org/hibernate/com.springsource. org.hibernate.annotations/3.3.1.ga/com.springsource.org.hibe rnate.annotations-3.3.1.ga.jar:/home/sean/.m2/repository/org /hibernate/com.springsource.org.hibernate.annotations.common /3.3.0.ga/com.springsource.org.hibernate.annotations.common- 3.3.0.ga.jar:/home/sean/.m2/repository/org/hibernate/com.spr ingsource.org.hibernate.ejb/3.3.2.GA/com.springsource.org.hi bernate.ejb-3.3.2.GA.jar:/home/sean/.m2/repository/org/hiber nate/com.springsource.org.hibernate.validator/4.0.0.GA/com.s pringsource.org.hibernate.validator-4.0.0.GA.jar:/home/sean/ .m2/repository/org/jboss/util/com.springsource.org.jboss.uti l/2.0.4.GA/com.springsource.org.jboss.util-2.0.4.GA.jar:/hom e/sean/.m2/repository/org/joda/com.springsource.org.joda.tim e/1.6.0/com.springsource.org.joda.time-1.6.0.jar:/home/sean/ .m2/repository/org/junit/com.springsource.org.junit/4.7.0/co m.springsource.org.junit-4.7.0.jar:/home/sean/.m2/repository /org/objectweb/asm/com.springsource.org.objectweb.asm/1.5.3/ com.springsource.org.objectweb.asm-1.5.3.jar:/home/sean/.m2/ repository/org/objectweb/asm/com.springsource.org.objectweb. asm.attrs/1.5.3/com.springsource.org.objectweb.asm.attrs-1.5 .3.jar:/home/sean/.m2/repository/org/tuckey/com.springsource .org.tuckey.web.filters.urlrewrite/3.1.0/com.springsource.or g.tuckey.web.filters.urlrewrite-3.1.0.jar:/home/sean/.m2/rep ository/org/slf4j/com.springsource.slf4j.api/1.5.6/com.sprin gsource.slf4j.api-1.5.6.jar:/home/sean/.m2/repository/org/sl f4j/com.springsource.slf4j.log4j/1.5.6/com.springsource.slf4 j.log4j-1.5.6.jar:/home/sean/.m2/repository/com/wave2/common /common/4.1/common-4.1.jar:/home/sean/.m2/repository/commons -codec/commons-codec/1.2/commons-codec-1.2.jar:/home/sean/.m 2/repository/commons-collections/commons-collections/3.2.1/c ommons-collections-3.2.1.jar:/home/sean/.m2/repository/commo ns-httpclient/commons-httpclient/3.1/commons-httpclient-3.1. jar:/home/sean/.m2/repository/commons-lang/commons-lang/2.5/ commons-lang-2.5.jar:/home/sean/.m2/repository/commons-loggi ng/commons-logging/1.1.1/commons-logging-1.1.1.jar:/home/sea n/.m2/repository/org/apache/cxf/cxf-api/2.2/cxf-api-2.2.jar: /home/sean/.m2/repository/org/apache/cxf/cxf-common-schemas/ 2.2/cxf-common-schemas-2.2.jar:/home/sean/.m2/repository/org /apache/cxf/cxf-common-utilities/2.2/cxf-common-utilities-2. 2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-bindin gs-soap/2.2/cxf-rt-bindings-soap-2.2.jar:/home/sean/.m2/repo sitory/org/apache/cxf/cxf-rt-bindings-xml/2.2/cxf-rt-binding s-xml-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-r t-core/2.2/cxf-rt-core-2.2.jar:/home/sean/.m2/repository/org /apache/cxf/cxf-rt-databinding-jaxb/2.2/cxf-rt-databinding-j axb-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt- frontend-jaxws/2.2/cxf-rt-frontend-jaxws-2.2.jar:/home/sean/ .m2/repository/org/apache/cxf/cxf-rt-frontend-simple/2.2/cxf -rt-frontend-simple-2.2.jar:/home/sean/.m2/repository/org/ap ache/cxf/cxf-rt-transports-http/2.2/cxf-rt-transports-http-2 .2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-ws-ad dr/2.2/cxf-rt-ws-addr-2.2.jar:/home/sean/.m2/repository/org/ apache/cxf/cxf-tools-common/2.2/cxf-tools-common-2.2.jar:/ho me/sean/.m2/repository/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar:/ho me/sean/.m2/repository/org/hibernate/ejb3-persistence/1.0.2. GA/ejb3-persistence-1.0.2.GA.jar:/home/sean/.m2/repository/c om/google/code/facebookapi/facebook-java-api/3.0.2/facebook- java-api-3.0.2.jar:/home/sean/.m2/repository/com/google/code /facebookapi/facebook-java-api-annotation-processor/3.0.2/fa cebook-java-api-annotation-processor-3.0.2.jar:/home/sean/.m 2/repository/com/google/code/facebookapi/facebook-java-api-s chema/3.0.2/facebook-java-api-schema-3.0.2.jar:/home/sean/.m 2/repository/com/sun/xml/fastinfoset/FastInfoset/1.2.2/FastI nfoset-1.2.2.jar:/home/sean/.m2/repository/org/apache/geroni mo/specs/geronimo-activation_1.1_spec/1.0.2/geronimo-activat ion_1.1_spec-1.0.2.jar:/home/sean/.m2/repository/org/apache/ geronimo/specs/geronimo-annotation_1.0_spec/1.1.1/geronimo-a nnotation_1.0_spec-1.1.1.jar:/home/sean/.m2/repository/org/a pache/geronimo/specs/geronimo-javamail_1.4_spec/1.5/geronimo -javamail_1.4_spec-1.5.jar:/home/sean/.m2/repository/org/apa che/geronimo/specs/geronimo-jaxws_2.1_spec/1.0/geronimo-jaxw s_2.1_spec-1.0.jar:/home/sean/.m2/repository/org/apache/gero nimo/specs/geronimo-stax-api_1.0_spec/1.0.1/geronimo-stax-ap i_1.0_spec-1.0.1.jar:/home/sean/.m2/repository/org/apache/ge ronimo/specs/geronimo-ws-metadata_2.0_spec/1.1.2/geronimo-ws -metadata_2.0_spec-1.1.2.jar:/home/sean/.m2/repository/org/h amcrest/hamcrest-core/1.1/hamcrest-core-1.1.jar:/home/sean/. m2/repository/org/hamcrest/hamcrest-library/1.1/hamcrest-lib rary-1.1.jar:/home/sean/.m2/repository/org/hibernate/hiberna te-commons-annotations/3.1.0.GA/hibernate-commons-annotation s-3.1.0.GA.jar:/home/sean/.m2/repository/org/hibernate/hiber nate-core/3.3.1.GA/hibernate-core-3.3.1.GA.jar:/home/s
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.internal.resources.MarkerInfo.checkValidAtt ribute(MarkerInfo.java:63)
at org.eclipse.core.internal.resources.MarkerInfo.setAttribute( MarkerInfo.java:146)
at org.eclipse.core.internal.resources.Marker.setAttribute(Mark er.java:241)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.setMessag e(UIMessageHandler.java:567)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.access$7( UIMessageHandler.java:556)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler$1.run(UIM essageHandler.java:318)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showMessa ges(UIMessageHandler.java:339)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showOutst andingProblems(UIMessageHandler.java:207)
at org.eclipse.ajdt.internal.builder.UIBuildListener.postAJBuil d(UIBuildListener.java:197)
at org.eclipse.ajdt.core.builder.AJBuilder.postCallListeners(AJ Builder.java:1352)
at org.eclipse.ajdt.core.builder.AJBuilder.build(AJBuilder.java :258)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
Re: "Property marker value too long" exception during build [message #601089 is a reply to message #601077] Mon, 28 June 2010 16:32 Go to previous messageGo to next message
For completeness: my issue was resolved. See the bug report if you hit the same problem.
http://bugs.eclipse.org/bugs/show_bug.cgi?id=318150
Re: "Property marker value too long" exception during build [message #601110 is a reply to message #601077] Tue, 29 June 2010 23:24 Go to previous message
Andrew Eisenberg is currently offline Andrew EisenbergFriend
Sorry no reply earlier. Bugzilla is watched much more closely than this forum.
Fix has been committed and is available on the 3.6 branch. Soon to be on the 3.5 branch.
Previous Topic:"Property marker value too long" exception during build
Next Topic:eclipse editor shows errors, but ITD works, how to fix
Current Time: Sun May 20 14:06:23 GMT 2018
Powered by FUDForum. Page generated in 0.02054 seconds
