Home » Archived » Maven Integration (M2E) » m2eclipse / wtp: filter web.xml
m2eclipse / wtp: filter web.xml [message #5386] Wed, 14 May 2008 16:22 Go to next message
Originally posted by: ossipetz.myrealbox.com
Hallo
i am using m2eclipse 0.9.3 with eclipse 3.3.x with quite some success
now. i encountered a 'strange' thing i am not sure if its wtp or
m2eclipse related.
i want to filter the web.xml file. this does work fine. the target
folder contains the filtered version. but when i start tomcat 6.0 it
uses the web.xml from src/main/.. and not the one in the target folder.
the server path points to the target path (option: "Use custom
location") and "Serve modules without publishing" is checked.
can anyone give me a hint on how to point wtp / tomcat to the propper
web.xml? some options are crucial for the application to run.
thanks for any input!
regards
ossi
Re: m2eclipse / wtp: filter web.xml [message #6881 is a reply to message #5386] Wed, 14 May 2008 17:39 Go to previous messageGo to next message
Originally posted by: igorfie.yahoo.com
ossi,
First, we are introducing first-class wtp integration and have made
0.9.4 dev build to preview this functionality. You can find more
information in [1]
Now back to your question. Unfortunately, m2eclipse does not support
custom location of web.xml at the moment. Can you please open an
enhancement request in m2eclipse JIRA [2] and provide sample project to
help us understand your requirements betters?
[1]
http://www.eclipse.org/newsportal/article.php?id=56&grou p=eclipse.technology.m2e#56
[2] http://jira.codehaus.org/browse/MNGECLIPSE
ossipetz wrote:
> Hallo
> m2eclipse related.
> regards
> ossi
Re: m2eclipse / wtp: filter web.xml [message #7015 is a reply to message #6881] Thu, 15 May 2008 16:20 Go to previous message
Hallo
1st class wtp integration sounds great! cant wait to get it :)
i created an issue in Jira:
http://jira.codehaus.org/browse/MNGECLIPSE-602
(a small example project is attached)
if more input is needed please tell me
thanks!
regards
ossi
Igor Fedorenko schrieb:
> ossi,
> information in [1]
> [1]
> ossipetz wrote:
>> Hallo
>> m2eclipse related.
>> regards
>> ossi
Previous Topic:resource folders in package explorer
Next Topic:pom xml editor and additional ideas for contribution
Current Time: Fri Feb 23 15:05:43 GMT 2018
Powered by FUDForum. Page generated in 0.01780 seconds
