OUTPUT parameters represented as INOUT for SQL Stored Procedures. [message #597043] |
Thu, 21 January 2010 13:18 |
Ravikanth Somayaji Messages: 49 Registered: July 2009 Location: Oxford |
Member |
I have this sql stored procedure
> drop procedure "amxbpm"."allElems"
> GO
> CREATE PROCEDURE "allElems" (
> @id int,@outvalue1 VARCHAR(20) OUTPUT,@outvalue2 decimal OUTPUT
> AS
> BEGIN
> select @outvalue1="id"
> FROM "amxbpm"."de_humanresource"
> return 0;
> END
when i load it in the Data Sources Explorer and Edit the stored
procedure i end up with this
> CREATE PROCEDURE allElems (
> IN @RETURN_VALUE INTEGER,
> IN @id INTEGER,
> INOUT @outvalue1 VARCHAR(20),
> INOUT @outvalue2 DECIMAL(18 , 0))
> NOT DETERMINISTIC
> NO_SQL
> BEGIN
> return 0;
> END
The outcome of which isn't very pleasant. When I use the DTP API to retrieve the Input parameter I get "outValue1" and "outValue2" as input parameters. Now, that isn't what i expect...
Can anyone please advice.
FUDForum. Page generated in 0.02839 seconds
