Home » Eclipse Projects » DTP » Sharing embedded Derby with other plugins
Sharing embedded Derby with other plugins [message #596102] Tue, 21 July 2009 21:43
No real name is currently offline No real nameFriend
I am using OpenJPA, DTP and Derby in my Eclipse RCP app. Before I added
OpenJPA, I was using my own JDBC layer and obtained the JDBC connection
from DTP profile manager.
Now, when I use OepnJPA, I cannot connect to the database in the DSE and
navigate the tables, schemas, etc. Instead, I must stop the OpenJPA
processing, then I can connect to DSE. While DSE is connected, OpenJPA
cannot access the Derby instance.
Ideally, I could use OpenJPA and DSE simultaenously (ie, two
connections) without going Derby Client/Server. I currently use the
Derby embedded driver.
Is there a way two components such as these can access the same Derby
instance? I understand that only one can "boot" Derby.
Has anyone else come across this situation already?
Previous Topic:Property for "Connect every time the workbench is started" ?
Next Topic:Sharing embedded Derby with other plugins
Current Time: Mon Mar 19 22:41:32 GMT 2018
Powered by FUDForum. Page generated in 0.01695 seconds
