Home » Archived » B3 » only imported models - issue with generated code
only imported models - issue with generated code [message #595808] Thu, 04 February 2010 23:20 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
After using only imported models in my grammar, I get an issue with the
following generated code:
public void register(Injector injector) {
if
(!EPackage.Registry.INSTANCE.containsKey("http://www.eclipse.org/b3/BeeLang"))
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/b3/BeeLang",
org.eclipse.b3.beeLang.BeeLangPackage.eINSTANCE);
There is no longer a BeeLang model and package. Uncommenting the
offending lines works. I wonder how I can get rid of the generation of
this. What have I missed?
- henrik
Re: only imported models - issue with generated code [message #595820 is a reply to message #595808] Thu, 04 February 2010 23:22 Go to previous message
Sorry - wrong newsgroup...
- henrik
> if
> Regards
> - henrik
Previous Topic:Heads up - trunk for b3 (engine) moving to 3.6M5
Next Topic:Heads up - trunk for b3 (engine) moving to 3.6M5
Current Time: Mon May 28 09:49:26 GMT 2018
Powered by FUDForum. Page generated in 0.02021 seconds
