Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build fails with optional dependencies
PDE build fails with optional dependencies [message #590464] Sun, 25 January 2009 18:24
Andreas Goetz is currently offline Andreas GoetzFriend
I'm trying to build an RCP application that contains a couple of JUnit
tests and org.junit4 as optional dependency.
Build fails due to missing org.junit4, even if the test cases themselves
are not copied to the build folder:
[java] [eclipse.generateFeature] Some inter-plug-in dependencies
have not been satisfied.
[java] [eclipse.generateFeature] Bundle tchok.sudoku.core:
[java] [eclipse.generateFeature] Missing Constraint:
Bundle-RequiredExecutionEnvironment: JavaSE-1.5
[java] [eclipse.generateFeature] Optional plug-in
org.junit4_0.0.0 is not available.
[java] [eclipse.generateFeature] Bundle tchok.sudoku.rcp:
[java] [eclipse.generateFeature] Missing required plug-in
tchok.sudoku.core_0.0.0.
Is there a way to build the current setup without the tests or do I need
to move the tests to their own plugin (which would also be possible)?
Andi
Previous Topic:[newbie] Accessing selected file
Next Topic:IEHS subsystem as Service
Current Time: Mon Feb 19 14:14:52 GMT 2018
Powered by FUDForum. Page generated in 0.01519 seconds
