Home » Modeling » Modeling (top-level project) » Use of Eclipse Comparaison Tool after JMerge
Use of Eclipse Comparaison Tool after JMerge [message #589935] Mon, 05 March 2007 14:01
Originally posted by:
I'm studing the way of using Eclipse Comparaison Tool after an incremental
generation made with EMF and JMerge.
I would like to show to the user a display that looks like a CVS or SVN
merge result. This fonctionnality should reassure the user when he uses
tags to customize generated code.
Is there a simple way of reusing Eclipse Compare Tools ? Do you know if
there is an article about compare tool programming ?
Thanks in advance,
JB Volta.
Previous Topic:IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource
Next Topic:Use of Eclipse Comparaison Tool after JMerge
Current Time: Thu Mar 22 12:17:50 GMT 2018
Powered by FUDForum. Page generated in 0.01280 seconds
