Home » Modeling » Epsilon » Problem while creating GMF models from xsd.
Problem while creating GMF models from xsd. [message #589328] Thu, 27 May 2010 04:47 Go to next message
login is currently offline loginFriend
Hi All,
I am new to GMF. I have been trying to understand the concept of generating Ecore model from xsd.
I generated a Ecore model from xsd and used the same ecore file to generate genmodel. gen model created successfully.
But when i tried generating the "gmfgen" model out of genmodel.
It throws an error.
I need to know the following :
1.)Does GMF supports a Ecore model generated out of xsd.
2) I tried using Eugenia to generate gmfgen and gmf diagram from sample .emf model it works fine.But when i tried generating the ecore from "xsd" .It has some issues.
Does any body know how to go about it?
Thanks in advance,
Re: Problem while creating GMF models from xsd. [message #589356 is a reply to message #589328] Thu, 27 May 2010 08:53 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Could you please confirm that you've added @gmf.xxx annotations to your metamodel as per http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf- tutorial/?
Dimitris
Re: Problem while creating GMF models from xsd. [message #589392 is a reply to message #589356] Thu, 27 May 2010 10:48 Go to previous message
Thanks for the response.
I was unable to find the link given.
I am trying to google out some of the samples to add GMF annotation to the the metamodel.I dint get it.
and
Should we always use emf instead xsd for Eugenia sample.?
Previous Topic:Re: Importing ETL files from other projects
Next Topic:Problem while creating GMF models from xsd.
Current Time: Wed Apr 25 22:18:50 GMT 2018
Powered by FUDForum. Page generated in 0.01783 seconds
