Home » Archived » OHF » Getting document consumer working with ohf 0.3.0?
Getting document consumer working with ohf 0.3.0? [message #586176] Wed, 23 July 2008 21:46
Frank is currently offline FrankFriend
I took a code snippet from
org.eclipse.ohf.ihe.xds.consumer.test.IBMLswin10RetrieveTest .testRetrieve().
I used the following info:
patientid - 139158
affinity domain -
assigning authority name - HIMSS2005
registry url - egistry
I got this info from the following url: tathonHIMSS2007.htm
When I run the test, I get no documents returned ... and no errors. I
suspect that some of the information I'm using is not correct, because
if I use the "Blue Panther Administration Portal" at, I can query on
the patient id above and get 193 document references returned.
Can someone verify the consumer information I listed above?
Previous Topic:STEM : Can we visualise at street level?
Next Topic:Error parsing response from ebxmlrr
Current Time: Thu Mar 22 08:20:51 GMT 2018
Powered by FUDForum. Page generated in 0.01535 seconds
