Home » Modeling » Epsilon » Re running Eugenia Example- help required
Re running Eugenia Example- help required [message #585232] Wed, 27 January 2010 15:11 Go to next message
saad bin abid is currently offline saad bin abidFriend
Member
Hello Epsilon experts,
I am very new to epsilon stuff especially to Eugenia. I am trying to re run the example given in screen cast (filesystem project) on official website. I can sucessfully create filesystem.gmfgraph, filesystem.gmfmap, filesystem.gmftool. for generating filesystem.gmfgen i run the wizard. In example video the transformation step is done automatically and no qvto transformations (prepost-reconcile) is required. yet the filesystem.gmfgen model is created. I how ever tried to workout without qvto transformation by selecting java i get this error message
i get the following error message:
" org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.compi le(Ljava/lang/String;Lorg/eclipse/m2m/internal/qvt/oml/compi ler/QvtCompilerOptions;Lorg/eclipse/emf/common/util/Monitor; )Lorg/eclipse/m2m/internal/qvt/oml/compiler/CompiledUnit; "
I don't know how to continue from here or is there a complete project with qvto transformations which i can understand as a starter example with and without qvto transformation.
best regards
saad
Re: Re running Eugenia Example- help required [message #585264 is a reply to message #585232] Wed, 27 January 2010 22:32 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Saad,
I must admit I've never encountered anything similar before. Which
version of Eclipse/GMF are you using?
Dimitris
Please see comments below.
> error message
> best regards
> saad
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Re running Eugenia Example- help required [message #853949 is a reply to message #585232] Mon, 23 April 2012 13:57 Go to previous messageGo to next message
Julian Johnson is currently offline Julian JohnsonFriend
(Hi, my first post to this forum, so apologies if I've not used correctly.
Running Eclipse Epsilon, from the epsilon-0.9.1-win32.zip build.)
I have attempted to run the Eugenia 'filesystem' example, second screencast example. Two questions:
Q1 is there an insistency between the filesystem.emf code as listed in the screencast, versus that available in the cvs filesystem? For instance, first 12 lines of the file code reads:
@namespace(uri="filesystem", prefix="filesystem")
package filesystem;
@gmf.diagram(foo="bar")
class Filesystem {
val Drive[*] drives;
val Sync[*] syncs;
class Drive extends Folder {
while on the screencast, the first 3 lines read:
@gmf
package filesystem;
i.e. there is an extra '@gmf' line?
Q2 When I put my code in Eclipse following the example, but exactly as the cvs file, I get an error highlighed with red x at line 12:
"Encountering "Class" at line 14, column 1.
Was expecting on of:
<EOF>
(etc) "
Q3 What in the screencast is the GMF project given such a long/esoteric name:
"gmf.eclipse.epsilon.eugenia.examples.filesystem"
-Is this simple because of how you are organising your examples, rather than literally how a user might need to name it to get it to work?
thanks
Julian
Re: Re running Eugenia Example- help required [message #853983 is a reply to message #853949] Mon, 23 April 2012 14:35 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Hi Julian,
Q1: The @gmf line is not used by the current version of EuGENia and can be removed.
Q2: The version of Emfatic that is bundled in the Epsilon distribution does not support detail-less annotations. As such, even when no details are needed for an annotation, a dummy detail needs to be added (e.g. foo="bar")
Q3: That's just the the naming convention we use for our examples.
Dimitris
Re: Re running Eugenia Example- help required [message #854652 is a reply to message #853983] Tue, 24 April 2012 06:00 Go to previous messageGo to next message
Dimitris Kolovos wrote on Mon, 23 April 2012 10:35
Hi Julian,
Dimitris
Thanks for your quick reply.
Q1 OK
Q3 OK
Q2 I understand your reply, but don't know how it relates to the problem (the error) I described. I just re-ran up the same point (loaded the annotated filesystem.emf) on a different PC, and that is not flagging up an error. I'll investigate further...
Julian.
Re: Re running Eugenia Example- help required [message #854726 is a reply to message #854652] Tue, 24 April 2012 07:34 Go to previous messageGo to next message
Hi Julian,
Different behaviour in 2 PCs most probably indicates either different versions of Emfatic or a bug. I'd add at least one detail to each annotation just to be on the safe side.
Dimitris
Re: Re running Eugenia Example- help required [message #855084 is a reply to message #854726] Tue, 24 April 2012 14:01 Go to previous messageGo to next message
All gmf lines have at least one annotation, if I understand your suggestion.
Attached (if I'd done it right) is a screen dump of what I see on my company PC. The hover text over the red 'x' reads:
Encountered "Class" at line 14, column 1.
Was expecting one of:
<EOF>
"package" ...
"abstract" ...
"class" ...
"interface" ...
"transient" ...
"datatype" ...
What now (to get this working)?
Julian.
Re: Re running Eugenia Example- help required [message #855267 is a reply to message #855084] Tue, 24 April 2012 16:58 Go to previous message
Ivo(sh) Musil is currently offline Ivo(sh) MusilFriend
Hi Julian
just my 0.38 CZK (2c) - probably EMF is case sensitive and you have some class defined with capital C.
Ivo(sh)
Previous Topic:How to make a user-defined operation available to all my templates?
Next Topic:Using ETL transform models which are based on UML Profiles
Current Time: Thu Apr 26 05:59:27 GMT 2018
Powered by FUDForum. Page generated in 0.02176 seconds
