Problem with FirstJSFApp Tutorial [message #581817] |
Mon, 30 January 2006 16:55 |
Ted Fritsch Messages: 4 Registered: July 2009 |
Junior Member |
Greetings,
I am trying to work through the JSF tutorial for WTP and am running into
some issues. I am unable to deploy and run my JSP on a server - when I
try to right click on the login.jsp and select 'Run on Server', I get the
following error:
No launchable artifact could be found in the selection.
It seems like some sort of project configuration issue, but I am unable to
determine the cause. I beleive that I have set up my environment as
described in the tutorial (except I am using a 1.5 jdk, instead of 1.4),
and am using the following environment:
Windows XP Pro
Eclipse 3.1.1
JDK 1.5.0_01
WTP 1.0
JSF Tools Milestone 1
Apache Tomcat 5.5
JSF RI 1.1_01
jakarta-taglibs-standard-1.1.2
I am able to launch JSPs in other dynamic web projects, so it seems to be
related to something JSF. I have tried deleting and re-adding the project
from the server, and even deleteing and re-adding the Tomcat server
itself, but with no success.
Any thoughts anyone? Thanks in advance...
Ted Fritsch
FUDForum. Page generated in 0.02444 seconds
