| All Models r10673 (part 1) [message #577888] |
Wed, 23 September 2009 12:13 |
Henrik Lindberg Messages: 2428 Registered: July 2009 |
--------------040101040007080806050005
Things are starting to come together...
Attached are all of the models (r10673).
In this revision:
- PointCut not needed as Advice has reference to nodes in the Context.
The idea is to use XPath (or comparable) to address the nodes.
- Context is now defined (advice sees the context in a way comparable to
how a html document is seen by CSS in a web browser)
- The package called "resolution" is removed (the few thing described
there are now in "context".
- Closure can now have advice (this advice is in effect when the closure
is).
- Advice grouping is now possible (with relative address, relative to
the parent advice's address)
- Instantiation advice was made into an Advice group (it had
initializers earlier which were the same as the grouping).
- henrik
Content-Type: application/pdf;
name="Build.pdf"
Content-Disposition: inline;
filename="Build.pdf"
JVBERi0xLjQKJaqrrK0KNCAwIG9iago8PCAvVHlwZSAvSW5mbwovUHJvZHVj ZXIgPEZFRkYw
MDQxMDA3MDAwNjEwMDYzMDA2ODAwNjUwMDIwMDA0NjAwNEYwMDUwMDAzQTAw MjAwMDUzMDA1
NjAwNDcwMDIwMDA3NDAwNkYwMDIwMDA1MDAwNDQwMDQ2MDAyMDAwNTQwMDcy MDA2MTAwNkUw
MDczMDA2MzAwNkYwMDY0MDA2NTAwNzI+Ci9DcmVhdGlvbkRhdGUgPEZFRkYw MDQ0MDAzQTAw
MzIwMDMwMDAzMDAwMzkwMDMwMDAzOTAwMzIwMDMzMDAzMTAwMzcwMDM1MDAz NzAwMzEwMDMy
MDAyQjAwMzAwMDMyMDAyNzAwMzAwMDMwMDAyNz4KPj4KZW5kb2JqCjYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMQovTGVuZ3Ro IDcgMCBSCi9X
aWR0aCAyMTcKL0hlaWdodCA3OQovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
ZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0K eJztwTEBAAAA
wqBs61/KFl5AAQAAAAAAAAAAAAAAAAAAAMDdAJB2AbcKZW5kc3RyZWFtCmVu ZG9iago3IDAg
b2JqCjQxCmVuZG9iago4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5 cGUgL0ltYWdl
Ci9OYW1lIC9JbTIKL0xlbmd0aCA5IDAgUgovV2lkdGggMjE3Ci9IZWlnaHQg NzkKL0JpdHNQ
ZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsy NTUgMjU1IDI1
NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDYgMCBSCi9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJztwjERAAAMAyHpHd92VWSDoytVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVdfAB8CTfFQplbmRzdHJlYW0KZW5k b2JqCjkgMCBv
YmoKNzYKZW5kb2JqCjEwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5 cGUgL0ltYWdl
Ci9OYW1lIC9JbTMKL0xlbmd0aCAxMSAwIFIKL1dpZHRoIDIxNwovSGVpZ2h0 IDc5Ci9CaXRz
UGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRl ciBbIC9GbGF0
ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oWXkABAAAAAAAA AAAAAAAAAAAA
wN0AkHYBtwplbmRzdHJlYW0KZW5kb2JqCjExIDAgb2JqCjQxCmVuZG9iagox MiAwIG9iago8
PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW00Ci9M ZW5ndGggMTMg
MCBSCi9XaWR0aCAyMTcKL0hlaWdodCA3OQovQml0c1BlckNvbXBvbmVudCA4 Ci9Db2xvclNw
YWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1 XQovU01hc2sg
MTAgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJzt wjERAAAMAyHp
Hd92VWSDoytVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVdfAB8CTfFQplbmRzdHJlYW0KZW5kb2JqCjEzIDAgb2JqCjc2CmVuZG9i agoxNCAwIG9i
ago8PCAKL0Z1bmN0aW9uVHlwZSAyIAovRG9tYWluIFsgMCAxIF0gCi9DMCBb IDEgMSAwLjgx
OTYwIF0gCi9DMSBbIDEgMSAxIF0gCi9OIDEgCj4+IAplbmRvYmoKMTUgMCBv YmoKPDwgCi9G
dW5jdGlvblR5cGUgMyAKL0RvbWFpbiBbIDAgMSBdIAovRnVuY3Rpb25zIFsg MTQgMCBSIF0g
Ci9FbmNvZGUgWyAwIDEgXSAKL0JvdW5kcyBbIF0gCj4+IAplbmRvYmoKMTYg MCBvYmoKPDwg
Ci9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29v cmRzIFsgMjIx
IDYxNyAyMjEgNjk2IF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRy dWUgdHJ1ZSBd
IAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjE3IDAgb2JqCjw8IAov VHlwZSAvUGF0
dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5nIDE2IDAgUiAKPj4gCgpl bmRvYmoKMTgg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltNQovTGVu
Z3RoIDE5IDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1BlckNvbXBv bmVudCA4Ci9D
b2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJxjYCAM/kMAGhcm8P8/igAy/R9B/6cmH9l8dPsx3IfhfhQAAMZ3foIK ZW5kc3RyZWFt
CmVuZG9iagoxOSAwIG9iago0MQplbmRvYmoKMjAgMCBvYmoKPDwvVHlwZSAv WE9iamVjdAov
U3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNgovTGVuZ3RoIDIxIDAgUgovV2lk dGggMTYKL0hl
aWdodCAxNgovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZp Y2VSR0IKL01h
c2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTggMCBSCi9G aWx0ZXIgWyAv
RmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJxjYKAfOHPsyfSOY0UJGwviNhTG bwCygSK4FC+c
egaorDZnR3/DIQgCsoEiQHGsilNDVvY1HFw68/y6pVcgCMgGigDF0bTcuf4m 0X95Z9X+FXMu
IItfv/gSKNJdux8oC1QDFwe6szZne3PJHiCaN/E0RPDongcQESBqKto5p/8k XH1x4sbMyDX5
sesgCCK4c8MtCDc7eg0QAdXA1ScFLI/xXBDrtTDSfR4QQQTXLbkI4QLFo9zn J/ovQzY/wX9Z
rPfCKI/5QARVv/QSkA1RH+O1ANl8oNtSg1ckBSxN8F8U57cQIrhx+RUgGygC RClByxdNQwTR
o3sfQp3m58eta6vYjRw+R/feA4oUJmwEyiKHDxDMn3Q61mtJRdqWrpp9yCgn Zk1K0AqgLGaU
AQXjvJeUpmwqTdkIQ5uAIlgVQwAwtUxtP5oTvRbofSA5o+s4nvRDJAAAuCHW TwplbmRzdHJl
YW0KZW5kb2JqCjIxIDAgb2JqCjM0NgplbmRvYmoKMjIgMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNwovTGVuZ3RoIDIzIDAgUgov V2lkdGggMTYK
L0hlaWdodCAxNgovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9E ZXZpY2VHcmF5
Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJxjYKA9+A8D VOJTEwAABSMs
1AplbmRzdHJlYW0KZW5kb2JqCjIzIDAgb2JqCjE5CmVuZG9iagoyNCAwIG9i ago8PC9UeXBl
IC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW04Ci9MZW5ndGgg MjUgMCBSCi9X
aWR0aCAxNgovSGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9y U3BhY2UgL0Rl
dmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFz ayAyMiAwIFIK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgGAXEgrk1 +rgQVvVTKwx/
/LyIiYDiWNV3FZliVQ8Ux6q+Nsfy+49rQPTjJxj9gJJAcazqi9Jss5LsMRFQ nLwAGQYAALIK
VikKZW5kc3RyZWFtCmVuZG9iagoyNSAwIG9iago3NQplbmRvYmoKMjYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltOQovTGVuZ3Ro IDI3IDAgUgov
V2lkdGggMTQ5Ci9IZWlnaHQgOTUKL0JpdHNQZXJDb21wb25lbnQgOAovQ29s b3JTcGFjZSAv
RGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFt Cnic7cEBDQAA
AMKgbO9fyh4OKAAAAAAAAAAAAAAAAAC4NqMtCt4KZW5kc3RyZWFtCmVuZG9i agoyNyAwIG9i
agozNwplbmRvYmoKMjggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltMTAKL0xlbmd0aCAyOSAwIFIKL1dpZHRoIDE0OQovSGVpZ2h0 IDk1Ci9CaXRz
UGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBb MjU1IDI1NSAy
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayAyNiAwIFIKL0ZpbHRlciBbIC9GbGF0 ZURlY29kZSBd
Cj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZtZICjK1VVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVVXVyQ/dr8RLCmVuZHN0cmVhbQplbmRvYmoKMjkg MCBvYmoKNjcK
ZW5kb2JqCjMwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTExCi9MZW5ndGggMzEgMCBSCi9XaWR0aCAxNDkKL0hlaWdodCA5NQov Qml0c1BlckNv
bXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAv RmxhdGVEZWNv
ZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHg4oAAAAAAAAAAAAAAAA ALg2oy0K3gpl
bmRzdHJlYW0KZW5kb2JqCjMxIDAgb2JqCjM3CmVuZG9iagozMiAwIG9iago8 PC9UeXBlIC9Y
T2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xMgovTGVuZ3RoIDMz IDAgUgovV2lk
dGggMTQ5Ci9IZWlnaHQgOTUKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNr IDMwIDAgUgov
RmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh 6R3fdm1kgKMr
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVdXJD92v xEsKZW5kc3Ry
ZWFtCmVuZG9iagozMyAwIG9iago2NwplbmRvYmoKMzQgMCBvYmoKPDwgCi9T aGFkaW5nVHlw
ZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgMTQ5IDMy MCAxNDkgNDE1
IF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAov RnVuY3Rpb24g
MTUgMCBSIAo+PiAKZW5kb2JqCjM1IDAgb2JqCjw8IAovVHlwZSAvUGF0dGVy biAKL1BhdHRl
cm5UeXBlIDIgCi9TaGFkaW5nIDM0IDAgUiAKPj4gCgplbmRvYmoKMzYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTMKL0xlbmd0 aCAzNyAwIFIK
L1dpZHRoIDEwMAovSGVpZ2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0Nv bG9yU3BhY2Ug
L0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nO3BMQEA
AADCoGzrX8oO3kABAAAAwGeTs6mZCmVuZHN0cmVhbQplbmRvYmoKMzcgMCBv YmoKMjgKZW5k
b2JqCjM4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTE0Ci9MZW5ndGggMzkgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0NwovQml0 c1BlckNvbXBv
bmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUg MjU1IDI1NSAy
NTUgMjU1XQovU01hc2sgMzYgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJztwsEJAAAMA6HR+7y1O0dAsStVVVVVVVVVVVVVVVVVXfiYw3pRCmVu ZHN0cmVhbQpl
bmRvYmoKMzkgMCBvYmoKMzkKZW5kb2JqCjQwIDAgb2JqCjw8L1R5cGUgL1hP YmplY3QKL1N1
YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTE1Ci9MZW5ndGggNDEgMCBSCi9XaWR0 aCAxMDAKL0hl
aWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZp Y2VHcmF5Ci9G
aWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs 61/KDt5AAQAA
AMBnk7OpmQplbmRzdHJlYW0KZW5kb2JqCjQxIDAgb2JqCjI4CmVuZG9iago0 MiAwIG9iago8
PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xNgov TGVuZ3RoIDQz
IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQg OAovQ29sb3JT
cGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1 NV0KL1NNYXNr
IDQwIDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic 7cLBCQAADAOh
0fu8tTtHQLErVVVVVVVVVVVVVVVVVV34mMN6UQplbmRzdHJlYW0KZW5kb2Jq CjQzIDAgb2Jq
CjM5CmVuZG9iago0NCAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xv clNwYWNlIC9E
ZXZpY2VSR0IgCi9Db29yZHMgWyA3NzkgNDQ2IDc3OSA0OTMgXSAKL0RvbWFp biBbIDAgMSBd
IAovRXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+ IAplbmRvYmoK
NDUgMCBvYmoKPDwgCi9UeXBlIC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAK L1NoYWRpbmcg
NDQgMCBSIAo+PiAKCmVuZG9iago0NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW0xNwovTGVuZ3RoIDQ3IDAgUgovV2lkdGggMTAw Ci9IZWlnaHQg
NDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3Jh eQovRmlsdGVy
IFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+ QAEAAABvA26O
984KZW5kc3RyZWFtCmVuZG9iago0NyAwIG9iagoyOAplbmRvYmoKNDggMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTgKL0xlbmd0 aCA0OSAwIFIK
L1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0Nv bG9yU3BhY2Ug
L0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9T TWFzayA0NiAw
IFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREA AAwDIekd33Zl
ZIGjK1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKNDkgMCBv YmoKMzcKZW5k
b2JqCjUwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTE5Ci9MZW5ndGggNTEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0 c1BlckNvbXBv
bmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxh dGVEZWNvZGUg
XQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRz dHJlYW0KZW5k
b2JqCjUxIDAgb2JqCjI4CmVuZG9iago1MiAwIG9iago8PC9UeXBlIC9YT2Jq ZWN0Ci9TdWJ0
eXBlIC9JbWFnZQovTmFtZSAvSW0yMAovTGVuZ3RoIDUzIDAgUgovV2lkdGgg MTAwCi9IZWln
aHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNl UkdCCi9NYXNr
IFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDUwIDAgUgovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVV VVVVVVVVVVVd
f1PJPIkKZW5kc3RyZWFtCmVuZG9iago1MyAwIG9iagozNwplbmRvYmoKNTQg MCBvYmoKPDwg
Ci9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29v cmRzIFsgNzQz
IDY5OCA3NDMgNzM4IF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRy dWUgdHJ1ZSBd
IAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjU1IDAgb2JqCjw8IAov VHlwZSAvUGF0
dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5nIDU0IDAgUiAKPj4gCgpl bmRvYmoKNTYg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltMjEKL0xl
bmd0aCA1NyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29t cG9uZW50IDgK
L0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29k ZSBdCj4+CnN0
cmVhbQp4nO3BMQEAAADCoGzrX8oYPkABAAAAbwNujvfOCmVuZHN0cmVhbQpl bmRvYmoKNTcg
MCBvYmoKMjgKZW5kb2JqCjU4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTIyCi9MZW5ndGggNTkgMCBSCi9XaWR0aCAxMDAKL0hl aWdodCA0MAov
Qml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01h c2sgWzI1NSAy
NTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgNTYgMCBSCi9GaWx0ZXIgWyAv RmxhdGVEZWNv
ZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92ZWSBoytVVVVVVVVVVVVV VV1/U8k8iQpl
bmRzdHJlYW0KZW5kb2JqCjU5IDAgb2JqCjM3CmVuZG9iago2MCAwIG9iago8 PC9UeXBlIC9Y
T2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0yMwovTGVuZ3RoIDYx IDAgUgovV2lk
dGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic 7cExAQAAAMKg
bOtfyhg+QAEAAABvA26O984KZW5kc3RyZWFtCmVuZG9iago2MSAwIG9iagoy OAplbmRvYmoK
NjIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05h bWUgL0ltMjQK
L0xlbmd0aCA2MyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVy Q29tcG9uZW50
IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUg MjU1IDI1NSAy
NTVdCi9TTWFzayA2MCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+ CnN0cmVhbQp4
nO3CMREAAAwDIekd33ZlZIGjK1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVh bQplbmRvYmoK
NjMgMCBvYmoKMzcKZW5kb2JqCjY0IDAgb2JqCjw8IAovU2hhZGluZ1R5cGUg MiAKL0NvbG9y
U3BhY2UgL0RldmljZVJHQiAKL0Nvb3JkcyBbIDk4NiA2OTggOTg2IDczOCBd IAovRG9tYWlu
IFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRydWUgXSAKL0Z1bmN0aW9uIDE1 IDAgUiAKPj4g
CmVuZG9iago2NSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJu VHlwZSAyIAov
U2hhZGluZyA2NCAwIFIgCj4+IAoKZW5kb2JqCjY2IDAgb2JqCjw8L1R5cGUg L1hPYmplY3QK
L1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTI1Ci9MZW5ndGggNjcgMCBSCi9X aWR0aCAxNDYK
L0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9E ZXZpY2VHcmF5
Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAA wqBs61/KGh5A
AQAAAAAAwKsB0gjOqQplbmRzdHJlYW0KZW5kb2JqCjY3IDAgb2JqCjMxCmVu ZG9iago2OCAw
IG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAv SW0yNgovTGVu
Z3RoIDY5IDAgUgovV2lkdGggMTQ2Ci9IZWlnaHQgNDcKL0JpdHNQZXJDb21w b25lbnQgOAov
Q29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUg MjU1IDI1NV0K
L1NNYXNrIDY2IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3Ry ZWFtCnic7cJB
DQAADAMh6Xue7floIHSlqqqqqqqqqqqqqqqqqqqqqqqqqq58m4eT3gplbmRz dHJlYW0KZW5k
b2JqCjY5IDAgb2JqCjQ1CmVuZG9iago3MCAwIG9iago8PC9UeXBlIC9YT2Jq ZWN0Ci9TdWJ0
eXBlIC9JbWFnZQovTmFtZSAvSW0yNwovTGVuZ3RoIDcxIDAgUgovV2lkdGgg MTQ2Ci9IZWln
aHQgNDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNl R3JheQovRmls
dGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtf yhoeQAEAAAAA
AMCrAdIIzqkKZW5kc3RyZWFtCmVuZG9iago3MSAwIG9iagozMQplbmRvYmoK NzIgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjgK L0xlbmd0aCA3
MyAwIFIKL1dpZHRoIDE0NgovSGVpZ2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50 IDgKL0NvbG9y
U3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAy NTVdCi9TTWFz
ayA3MCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nO3CQQ0AAAwD
Iel7nu35aCB0paqqqqqqqqqqqqqqqqqqqqqqqqqufJuHk94KZW5kc3RyZWFt CmVuZG9iago3
MyAwIG9iago0NQplbmRvYmoKNzQgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAy IAovQ29sb3JT
cGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgOTk1IDQ0NiA5OTUgNDkzIF0g Ci9Eb21haW4g
WyAwIDEgXSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUg MCBSIAo+PiAK
ZW5kb2JqCjc1IDAgb2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5U eXBlIDIgCi9T
aGFkaW5nIDc0IDAgUiAKPj4gCgplbmRvYmoKNzYgMCBvYmoKPDwvVHlwZSAv WE9iamVjdAov
U3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjkKL0xlbmd0aCA3NyAwIFIKL1dp ZHRoIDIyNQov
SGVpZ2h0IDg2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZUdyYXkK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BgQAAAADD ILb5Sx3kVQEA
AAAAAAAAAAAAAAAAAAAAAMC7AYFPMjQKZW5kc3RyZWFtCmVuZG9iago3NyAw IG9iago0Mgpl
bmRvYmoKNzggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1h Z2UKL05hbWUg
L0ltMzAKL0xlbmd0aCA3OSAwIFIKL1dpZHRoIDIyNQovSGVpZ2h0IDg2Ci9C aXRzUGVyQ29t
cG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1 NSAyNTUgMjU1
IDI1NSAyNTVdCi9TTWFzayA3NiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29k ZSBdCj4+CnN0
cmVhbQp4nO3CMREAAAwDIekd33aFBI6uVFVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVW3PzYCPnoKZW5kc3RyZWFtCmVu ZG9iago3OSAw
IG9iago4MQplbmRvYmoKODAgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3Vi dHlwZSAvSW1h
Z2UKL05hbWUgL0ltMzEKL0xlbmd0aCA4MSAwIFIKL1dpZHRoIDIyNQovSGVp Z2h0IDg2Ci9C
aXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BgQAAAADDILb5Sx3kVQEAAAAA AAAAAAAAAAAA
AAAAAMC7AYFPMjQKZW5kc3RyZWFtCmVuZG9iago4MSAwIG9iago0MgplbmRv YmoKODIgMCBv
YmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0lt MzIKL0xlbmd0
aCA4MyAwIFIKL1dpZHRoIDIyNQovSGVpZ2h0IDg2Ci9CaXRzUGVyQ29tcG9u ZW50IDgKL0Nv
bG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1 NSAyNTVdCi9T
TWFzayA4MCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nO3CMREA
AAwDIekd33aFBI6uVFVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVW3PzYCPnoKZW5kc3RyZWFtCmVuZG9iago4MyAwIG9i ago4MQplbmRv
YmoKODQgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAv RGV2aWNlUkdC
IAovQ29vcmRzIFsgMzI5IDMyMCAzMjkgNDA2IF0gCi9Eb21haW4gWyAwIDEg XSAKL0V4dGVu
ZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2Jq Cjg1IDAgb2Jq
Cjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5n IDg0IDAgUiAK
Pj4gCgplbmRvYmoKODYgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltMzMKL0xlbmd0aCA4NyAwIFIKL1dpZHRoIDE2Ci9IZWlnaHQg MTYKL0JpdHNQ
ZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVy IFsgL0ZsYXRl
RGVjb2RlIF0KPj4Kc3RyZWFtCnicY2AgC/z//x+V9x9ZBI3//z+qACE+IfMw 7KcAAABKeDzE
CmVuZHN0cmVhbQplbmRvYmoKODcgMCBvYmoKMzUKZW5kb2JqCjg4IDAgb2Jq Cjw8L1R5cGUg
L1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTM0Ci9MZW5ndGgg ODkgMCBSCi9X
dmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFz ayA4NiAwIFIK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgGALAPr6e gaEBTBIEDfb2
8UBq2akPII0gdgM+k4GGzt8PVAxEEAZEO25ngEwG6gEygCRQC1wcq2MgJgNZ /3+DSKB6sBbs
ToKYA1RAtPkg90NcDkFALXjcD3ESRAHUZELhg+QwIsN/iAEAtI5FqwplbmRz dHJlYW0KZW5k
b2JqCjg5IDAgb2JqCjExMwplbmRvYmoKOTAgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltMzUKL0xlbmd0aCA5MSAwIFIKL1dpZHRo IDExNQovSGVp
Z2h0IDYzCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rldmlj ZUdyYXkKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BgQAAAADDILb5 S13gCFUBAAAA
AAAAHAMGkC/3CmVuZHN0cmVhbQplbmRvYmoKOTEgMCBvYmoKMzEKZW5kb2Jq CjkyIDAgb2Jq
Cjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTM2 Ci9MZW5ndGgg
OTMgMCBSCi9XaWR0aCAxMTUKL0hlaWdodCA2MwovQml0c1BlckNvbXBvbmVu dCA4Ci9Db2xv
clNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUg MjU1XQovU01h
c2sgOTAgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0K eJztwjERAAAM
AyHpHd92RWSFoytVVVVVVVVVVVVVVVVVVVVVVVVVVdXhA8zM5e8KZW5kc3Ry ZWFtCmVuZG9i
ago5MyAwIG9iago0NwplbmRvYmoKOTQgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltMzcKL0xlbmd0aCA5NSAwIFIKL1dpZHRoIDEx NQovSGVpZ2h0
IDYzCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdy YXkKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BgQAAAADDILb5S13g CFUBAAAAAAAA
HAMGkC/3CmVuZHN0cmVhbQplbmRvYmoKOTUgMCBvYmoKMzEKZW5kb2JqCjk2 IDAgb2JqCjw8
L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTM4Ci9M ZW5ndGggOTcg
MCBSCi9XaWR0aCAxMTUKL0hlaWdodCA2MwovQml0c1BlckNvbXBvbmVudCA4 Ci9Db2xvclNw
OTQgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJzt wjERAAAMAyHp
Hd92RWSFoytVVVVVVVVVVVVVVVVVVVVVVVVVVdXhA8zM5e8KZW5kc3RyZWFt CmVuZG9iago5
NyAwIG9iago0NwplbmRvYmoKOTggMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAy IAovQ29sb3JT
cGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgMTAwNCAxNDAgMTAwNCAyMDMg XSAKL0RvbWFp
biBbIDAgMSBdIAovRXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAx NSAwIFIgCj4+
IAplbmRvYmoKOTkgMCBvYmoKPDwgCi9UeXBlIC9QYXR0ZXJuIAovUGF0dGVy blR5cGUgMiAK
L1NoYWRpbmcgOTggMCBSIAo+PiAKCmVuZG9iagoxMDAgMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMzkKL0xlbmd0aCAxMDEgMCBS Ci9XaWR0aCAx
MDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNl IC9EZXZpY2VH
cmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEB AAAAwqBs61/K
GD5AAQAAAG8Dbo73zgplbmRzdHJlYW0KZW5kb2JqCjEwMSAwIG9iagoyOApl bmRvYmoKMTAy
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTQwCi9M
ZW5ndGggMTAzIDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJD b21wb25lbnQg
OAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAy NTUgMjU1IDI1
NV0KL1NNYXNrIDEwMCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+ CnN0cmVhbQp4
MTAzIDAgb2JqCjM3CmVuZG9iagoxMDQgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltNDEKL0xlbmd0aCAxMDUgMCBSCi9XaWR0aCAx MDAKL0hlaWdo
dCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VH cmF5Ci9GaWx0
ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/K GD5AAQAAAG8D
bo73zgplbmRzdHJlYW0KZW5kb2JqCjEwNSAwIG9iagoyOAplbmRvYmoKMTA2 IDAgb2JqCjw8
L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTQyCi9M ZW5ndGggMTA3
IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQg OAovQ29sb3JT
IDEwNCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nO3CMREAAAwD
Iekd33ZlZIGjK1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoK MTA3IDAgb2Jq
CjM3CmVuZG9iagoxMDggMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29s b3JTcGFjZSAv
RGV2aWNlUkdCIAovQ29vcmRzIFsgODYwIDY5OCA4NjAgNzM4IF0gCi9Eb21h aW4gWyAwIDEg
XSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+ PiAKZW5kb2Jq
CjEwOSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAy IAovU2hhZGlu
ZyAxMDggMCBSIAo+PiAKCmVuZG9iagoxMTAgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltNDMKL0xlbmd0aCAxMTEgMCBSCi9XaWR0 aCAxNDgKL0hl
aWdodCAxMTEKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlR3JheQov
RmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cEBDQAAAMKg bO9fyhxuQAEA
AAAAAAAAAAAAAAAAAABPBv+4TB0KZW5kc3RyZWFtCmVuZG9iagoxMTEgMCBv YmoKNDAKZW5k
b2JqCjExMiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFn ZQovTmFtZSAv
SW00NAovTGVuZ3RoIDExMyAwIFIKL1dpZHRoIDE0OAovSGVpZ2h0IDExMQov Qml0c1BlckNv
bXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAy NTUgMjU1IDI1
NSAyNTUgMjU1XQovU01hc2sgMTEwIDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVj b2RlIF0KPj4K
c3RyZWFtCnic7cIxDQAAAMMg6Ttre0YgtFJVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVVVVVdcBhpiKCgplbmRzdHJlYW0KZW5kb2JqCjEx MyAwIG9iago3
MgplbmRvYmoKMTE0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUg L0ltYWdlCi9O
YW1lIC9JbTQ1Ci9MZW5ndGggMTE1IDAgUgovV2lkdGggMTQ4Ci9IZWlnaHQg MTExCi9CaXRz
ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BAQ0AAADCoGzvX8ocbkABAAAAAAAA AAAAAAAAAAAA
Twb/uEwdCmVuZHN0cmVhbQplbmRvYmoKMTE1IDAgb2JqCjQwCmVuZG9iagox MTYgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNDYK L0xlbmd0aCAx
MTcgMCBSCi9XaWR0aCAxNDgKL0hlaWdodCAxMTEKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
b3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1 IDI1NV0KL1NN
YXNrIDExNCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nO3CMQ0A
AADDIOk7a3tGILRSVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVXXAYaYigoKZW5kc3RyZWFtCmVuZG9iagoxMTcgMCBvYmoKNzIKZW5k b2JqCjExOCAw
IG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZpY2VS R0IgCi9Db29y
ZHMgWyA2MjYgNTAgNjI2IDE2MSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRl bmQgWyB0cnVl
IHRydWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxMTkgMCBv YmoKPDwgCi9U
eXBlIC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTE4IDAg UiAKPj4gCgpl
bmRvYmoKMTIwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTQ3Ci9MZW5ndGggMTIxIDAgUgovV2lkdGggMTAxCi9IZWlnaHQgNDAK L0JpdHNQZXJD
b21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsg L0ZsYXRlRGVj
b2RlIF0KPj4Kc3RyZWFtCnic7cEBDQAAAMKgbO9fyhxuQAEAAAAvBvk7AgUK ZW5kc3RyZWFt
CmVuZG9iagoxMjEgMCBvYmoKMjgKZW5kb2JqCjEyMiAwIG9iago8PC9UeXBl IC9YT2JqZWN0
Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW00OAovTGVuZ3RoIDEyMyAwIFIK L1dpZHRoIDEw
MQovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2Ug L0RldmljZVJH
QgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMjAg MCBSCi9GaWx0
ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92 hQSOrlRVVVVV
VVVVVVVVdfUDX2p6kQplbmRzdHJlYW0KZW5kb2JqCjEyMyAwIG9iagozNwpl bmRvYmoKMTI0
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTQ5Ci9M
ZW5ndGggMTI1IDAgUgovV2lkdGggMTAxCi9IZWlnaHQgNDAKL0JpdHNQZXJD b21wb25lbnQg
OAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVj b2RlIF0KPj4K
c3RyZWFtCnic7cEBDQAAAMKgbO9fyhxuQAEAAAAvBvk7AgUKZW5kc3RyZWFt CmVuZG9iagox
MjUgMCBvYmoKMjgKZW5kb2JqCjEyNiAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW01MAovTGVuZ3RoIDEyNyAwIFIKL1dpZHRoIDEw MQovSGVpZ2h0
IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJH QgovTWFzayBb
MjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMjQgMCBSCi9GaWx0 ZXIgWyAvRmxh
dGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92hQSOrlRVVVVV VVVVVVVVdfUD
X2p6kQplbmRzdHJlYW0KZW5kb2JqCjEyNyAwIG9iagozNwplbmRvYmoKMTI4 IDAgb2JqCjw8
IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nv b3JkcyBbIDc3
MCAyMjEgNzcwIDI2MSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0 cnVlIHRydWUg
XSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxMjkgMCBvYmoKPDwg Ci9UeXBlIC9Q
YXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTI4IDAgUiAKPj4g CgplbmRvYmoK
MTMwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9O YW1lIC9JbTUx
Ci9MZW5ndGggMTMxIDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1Bl ckNvbXBvbmVu
dCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJxjYCAM/sPAMOEjAwClUnSMCmVuZHN0cmVhbQplbmRvYmoK MTMxIDAgb2Jq
CjE4CmVuZG9iagoxMzIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltNTIKL0xlbmd0aCAxMzMgMCBSCi9XaWR0aCAxNgovSGVpZ2h0 IDE2Ci9CaXRz
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMzAgMCBSCi9GaWx0ZXIgWyAvRmxh dGVEZWNvZGUg
XQo+PgpzdHJlYW0KeJxjYKAfmFujjwvhUv/j50VMhEv97GoDrOqB4ljVT68w +P7jGhD9+AlG
P6AkUByr+snlRgtn5CzAQEBxrOr7Sk2wugcojlV9Z5EZVvVAcazqm/PNsbof KI5VfV2ORVNb
Y1MrOgKKY1VfmWWF1T1AcazqSzJssKoHimNVX5Bqi9X9QHGs6nNT7LOSsCCg OFb1xAAA1hfz
RwplbmRzdHJlYW0KZW5kb2JqCjEzMyAwIG9iagoxNTEKZW5kb2JqCjEzNCAw IG9iago8PC9U
eXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW01MwovTGVu Z3RoIDEzNSAw
IFIKL1dpZHRoIDEwNQovSGVpZ2h0IDYzCi9CaXRzUGVyQ29tcG9uZW50IDgK L0NvbG9yU3Bh
Y2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0 cmVhbQp4nO3B
AQ0AAADCoGzvX8ocbkABAAAAAABwYIT/j/IKZW5kc3RyZWFtCmVuZG9iagox MzUgMCBvYmoK
MzAKZW5kb2JqCjEzNiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBl IC9JbWFnZQov
TmFtZSAvSW01NAovTGVuZ3RoIDEzNyAwIFIKL1dpZHRoIDEwNQovSGVpZ2h0 IDYzCi9CaXRz
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMzQgMCBSCi9GaWx0ZXIgWyAvRmxh dGVEZWNvZGUg
XQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92hQSOrlRVVVVVVVVVVVVVVVVV VVVVVVVnPj85
FMQKZW5kc3RyZWFtCmVuZG9iagoxMzcgMCBvYmoKNDQKZW5kb2JqCjEzOCAw IG9iago8PC9U
eXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW01NQovTGVu Z3RoIDEzOSAw
AQ0AAADCoGzvX8ocbkABAAAAAABwYIT/j/IKZW5kc3RyZWFtCmVuZG9iagox MzkgMCBvYmoK
MzAKZW5kb2JqCjE0MCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBl IC9JbWFnZQov
TmFtZSAvSW01NgovTGVuZ3RoIDE0MSAwIFIKL1dpZHRoIDEwNQovSGVpZ2h0 IDYzCi9CaXRz
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMzggMCBSCi9GaWx0ZXIgWyAvRmxh dGVEZWNvZGUg
FMQKZW5kc3RyZWFtCmVuZG9iagoxNDEgMCBvYmoKNDQKZW5kb2JqCjE0MiAw IG9iago8PCAK
L1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29y ZHMgWyA3MDcg
ODYwIDcwNyA5MjMgXSAKL0RvbWFpbiBbIDAgMSBdIAovRXh0ZW5kIFsgdHJ1 ZSB0cnVlIF0g
Ci9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoKMTQzIDAgb2JqCjw8IAov VHlwZSAvUGF0
dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5nIDE0MiAwIFIgCj4+IAoK ZW5kb2JqCjE0
NCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW01Nwov
TGVuZ3RoIDE0NSAwIFIKL1dpZHRoIDE2Ci9IZWlnaHQgMTYKL0JpdHNQZXJD b21wb25lbnQg
c3RyZWFtCnicY2CgHPyHASrxMU1HZvwHI0w+zAgMeRAFhthsAACEWlKuCmVu ZHN0cmVhbQpl
bmRvYmoKMTQ1IDAgb2JqCjM1CmVuZG9iagoxNDYgMCBvYmoKPDwvVHlwZSAv WE9iamVjdAov
U3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNTgKL0xlbmd0aCAxNDcgMCBSCi9X aWR0aCAxNgov
SGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZVJHQgov
TWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxNDQgMCBS Ci9GaWx0ZXIg
WyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJxjYBg+YG6NPi6EVf3UCsMf Py9iIqA4VvVd
RaZY1QPFsaqvzbH8/uMaEP34CUY/oCRQHKv6ojTbrCR7TAQUJy9A4GD+vteS 9mVABGSgSQEF
j974DERABrIgGgMOICohugiqh6hERuSZj+Z+iC44iel+4gEAkoiItQplbmRz dHJlYW0KZW5k
b2JqCjE0NyAwIG9iagoxMjEKZW5kb2JqCjE0OCAwIG9iago8PC9UeXBlIC9Y T2JqZWN0Ci9T
dWJ0eXBlIC9JbWFnZQovTmFtZSAvSW01OQovTGVuZ3RoIDE0OSAwIFIKL1dp ZHRoIDEwMAov
SGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZUdyYXkK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADC oGzrX8oYPkAB
AAAAbwNujvfOCmVuZHN0cmVhbQplbmRvYmoKMTQ5IDAgb2JqCjI4CmVuZG9i agoxNTAgMCBv
YmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0lt NjAKL0xlbmd0
aCAxNTEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBv bmVudCA4Ci9D
b2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAy NTUgMjU1XQov
U01hc2sgMTQ4IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3Ry ZWFtCnic7cIx
EQAADAMh6R3fdmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVu ZG9iagoxNTEg
MCBvYmoKMzcKZW5kb2JqCjE1MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9T dWJ0eXBlIC9J
bWFnZQovTmFtZSAvSW02MQovTGVuZ3RoIDE1MyAwIFIKL1dpZHRoIDEwMAov SGVpZ2h0IDQw
Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkK L0ZpbHRlciBb
IC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oYPkAB AAAAbwNujvfO
CmVuZHN0cmVhbQplbmRvYmoKMTUzIDAgb2JqCjI4CmVuZG9iagoxNTQgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNjIKL0xlbmd0 aCAxNTUgMCBS
Ci9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9D b2xvclNwYWNl
IC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQov U01hc2sgMTUy
IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIx EQAADAMh6R3f
dmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iagoxNTUg MCBvYmoKMzcK
ZW5kb2JqCjE1NiAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNw YWNlIC9EZXZp
Y2VSR0IgCi9Db29yZHMgWyA5OTUgNzg4IDk5NSA4MjggXSAKL0RvbWFpbiBb IDAgMSBdIAov
RXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IApl bmRvYmoKMTU3
IDAgb2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9T aGFkaW5nIDE1
NiAwIFIgCj4+IAoKZW5kb2JqCjE1OCAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW02MwovTGVuZ3RoIDE1OSAwIFIKL1dpZHRoIDEw MAovSGVpZ2h0
IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdy YXkKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oY PkABAAAAbwNu
jvfOCmVuZHN0cmVhbQplbmRvYmoKMTU5IDAgb2JqCjI4CmVuZG9iagoxNjAg MCBvYmoKPDwv
VHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNjQKL0xl bmd0aCAxNjEg
MCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4 Ci9Db2xvclNw
MTU4IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic 7cIxEQAADAMh
6R3fdmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iagox NjEgMCBvYmoK
MzcKZW5kb2JqCjE2MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBl IC9JbWFnZQov
TmFtZSAvSW02NQovTGVuZ3RoIDE2MyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0 IDQwCi9CaXRz
ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oYPkABAAAAbwNu jvfOCmVuZHN0
cmVhbQplbmRvYmoKMTYzIDAgb2JqCjI4CmVuZG9iagoxNjQgMCBvYmoKPDwv VHlwZSAvWE9i
amVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNjYKL0xlbmd0aCAxNjUg MCBSCi9XaWR0
aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNw YWNlIC9EZXZp
Y2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sg MTYyIDAgUgov
RmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh 6R3fdmVkgaMr
VVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iagoxNjUgMCBvYmoK MzcKZW5kb2Jq
CjE2NiAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9E ZXZpY2VSR0Ig
Ci9Db29yZHMgWyAxMTEyIDY5OCAxMTEyIDczOCBdIAovRG9tYWluIFsgMCAx IF0gCi9FeHRl
bmQgWyB0cnVlIHRydWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9i agoxNjcgMCBv
YmoKPDwgCi9UeXBlIC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRp bmcgMTY2IDAg
UiAKPj4gCgplbmRvYmoKMTY4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTY3Ci9MZW5ndGggMTY5IDAgUgovV2lkdGggMTAwCi9I ZWlnaHQgNDAK
L0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQov RmlsdGVyIFsg
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+QAEA AABvA26O984K
ZW5kc3RyZWFtCmVuZG9iagoxNjkgMCBvYmoKMjgKZW5kb2JqCjE3MCAwIG9i ago8PC9UeXBl
IC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW02OAovTGVuZ3Ro IDE3MSAwIFIK
L0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9T TWFzayAxNjgg
MCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjER AAAMAyHpHd92
ZWSBoytVVVVVVVVVVVVVVV1/U8k8iQplbmRzdHJlYW0KZW5kb2JqCjE3MSAw IG9iagozNwpl
bmRvYmoKMTcyIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTY5Ci9MZW5ndGggMTczIDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAK L0JpdHNQZXJD
b2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984K ZW5kc3RyZWFt
CmVuZG9iagoxNzMgMCBvYmoKMjgKZW5kb2JqCjE3NCAwIG9iago8PC9UeXBl IC9YT2JqZWN0
Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW03MAovTGVuZ3RoIDE3NSAwIFIK L1dpZHRoIDEw
MAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2Ug L0RldmljZVJH
QgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxNzIg MCBSCi9GaWx0
ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92 ZWSBoytVVVVV
VVVVVVVVVV1/U8k8iQplbmRzdHJlYW0KZW5kb2JqCjE3NSAwIG9iagozNwpl bmRvYmoKMTc2
IDAgb2JqCjw8IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0Rldmlj ZVJHQiAKL0Nv
b3JkcyBbIDExMTIgODc4IDExMTIgOTE4IF0gCi9Eb21haW4gWyAwIDEgXSAK L0V4dGVuZCBb
IHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjE3 NyAwIG9iago8
PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyAx NzYgMCBSIAo+
PiAKCmVuZG9iagoxNzggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltNzEKL0xlbmd0aCAxNzkgMCBSCi9XaWR0aCAxMDAKL0hlaWdo dCA0MAovQml0
c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0 ZXIgWyAvRmxh
dGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8D bo73zgplbmRz
dHJlYW0KZW5kb2JqCjE3OSAwIG9iagoyOAplbmRvYmoKMTgwIDAgb2JqCjw8 L1R5cGUgL1hP
YmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTcyCi9MZW5ndGggMTgx IDAgUgovV2lk
aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNr IDE3OCAwIFIK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwD Iekd33ZlZIGj
K1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKMTgxIDAgb2Jq CjM3CmVuZG9i
agoxODIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UK L05hbWUgL0lt
NzMKL0xlbmd0aCAxODMgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0 c1BlckNvbXBv
b2JqCjE4MyAwIG9iagoyOAplbmRvYmoKMTg0IDAgb2JqCjw8L1R5cGUgL1hP YmplY3QKL1N1
YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTc0Ci9MZW5ndGggMTg1IDAgUgovV2lk dGggMTAwCi9I
ZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCCi9N
YXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDE4MiAwIFIK L0ZpbHRlciBb
IC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZlZIGj K1VVVVVVVVVV
VVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKMTg1IDAgb2JqCjM3CmVuZG9i agoxODYgMCBv
YmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdC IAovQ29vcmRz
IFsgOTUwIDU3MiA5NTAgNjEyIF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVu ZCBbIHRydWUg
dHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjE4NyAwIG9i ago8PCAKL1R5
cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyAxODYgMCBS IAo+PiAKCmVu
ZG9iagoxODggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1h Z2UKL05hbWUg
L0ltNzUKL0xlbmd0aCAxODkgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAov Qml0c1BlckNv
ZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgpl bmRzdHJlYW0K
ZW5kb2JqCjE4OSAwIG9iagoyOAplbmRvYmoKMTkwIDAgb2JqCjw8L1R5cGUg L1hPYmplY3QK
L1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTc2Ci9MZW5ndGggMTkxIDAgUgov V2lkdGggMTAw
Ci9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAv RGV2aWNlUkdC
Ci9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDE4OCAw IFIKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33Zl ZIGjK1VVVVVV
VVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKMTkxIDAgb2JqCjM3CmVu ZG9iagoxOTIg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltNzcKL0xl
bmd0aCAxOTMgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNv bXBvbmVudCA4
Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNv ZGUgXQo+Pgpz
dHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRzdHJlYW0K ZW5kb2JqCjE5
MyAwIG9iagoyOAplbmRvYmoKMTk0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QK L1N1YnR5cGUg
L0ltYWdlCi9OYW1lIC9JbTc4Ci9MZW5ndGggMTk1IDAgUgovV2lkdGggMTAw Ci9IZWlnaHQg
NDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdC Ci9NYXNrIFsy
NTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDE5MiAwIFIKL0ZpbHRl ciBbIC9GbGF0
ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZlZIGjK1VVVVVV VVVVVVVVXX9T
yTyJCmVuZHN0cmVhbQplbmRvYmoKMTk1IDAgb2JqCjM3CmVuZG9iagoxOTYg MCBvYmoKPDwg
Ci9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29v cmRzIFsgNTU0
IDIyMSA1NTQgMjYxIF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRy dWUgdHJ1ZSBd
IAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjE5NyAwIG9iago8PCAK L1R5cGUgL1Bh
dHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyAxOTYgMCBSIAo+PiAK CmVuZG9iagox
OTggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05h bWUgL0ltNzkK
L0xlbmd0aCAxOTkgMCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0MgovQml0c1Bl ckNvbXBvbmVu
PgpzdHJlYW0KeJztwTEBAAAAwqBs61/K3wxAAQAAAAAA8AZ9fGqfCmVuZHN0 cmVhbQplbmRv
YmoKMTk5IDAgb2JqCjMwCmVuZG9iagoyMDAgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltODAKL0xlbmd0aCAyMDEgMCBSCi9XaWR0 aCAxNTQKL0hl
aWdodCA0MgovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZp Y2VSR0IKL01h
c2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTk4IDAgUgov RmlsdGVyIFsg
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdjVkh6Mr VVVVVVVVVVVV
VVVVVVVVVVVVdf9rOTC+CmVuZHN0cmVhbQplbmRvYmoKMjAxIDAgb2JqCjQ0 CmVuZG9iagoy
MDIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05h bWUgL0ltODEK
L0xlbmd0aCAyMDMgMCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0MgovQml0c1Bl ckNvbXBvbmVu
YmoKMjAzIDAgb2JqCjMwCmVuZG9iagoyMDQgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltODIKL0xlbmd0aCAyMDUgMCBSCi9XaWR0 aCAxNTQKL0hl
c2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMjAyIDAgUgov RmlsdGVyIFsg
VVVVVVVVVVVVdf9rOTC+CmVuZHN0cmVhbQplbmRvYmoKMjA1IDAgb2JqCjQ0 CmVuZG9iagoy
MDYgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCIAov
Q29vcmRzIFsgMTUzNyAxNTIgMTUzNyAxOTQgXSAKL0RvbWFpbiBbIDAgMSBd IAovRXh0ZW5k
IFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoK MjA3IDAgb2Jq
Cjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5n IDIwNiAwIFIg
Cj4+IAoKZW5kb2JqCjIwOCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW04MwovTGVuZ3RoIDIwOSAwIFIKL1dpZHRoIDE2Ci9IZWln aHQgMTYKL0Jp
dHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnicY2AgA/z/DyNg3P9gjJD9DyGwymPq R6dhgEp8fAAA
gkBLtQplbmRzdHJlYW0KZW5kb2JqCjIwOSAwIG9iagozNgplbmRvYmoKMjEw IDAgb2JqCjw8
L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTg0Ci9M ZW5ndGggMjEx
IDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1BlckNvbXBvbmVudCA4 Ci9Db2xvclNw
MjA4IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic Y2AY1KC07YSW
eTqcC2QDRQgqhjAgKnFpQTYZyIAg/LaQZD4EbNrzAM39QBFcipvzzUkSr8ux aGprbGpFR0Bx
rOors6x+/LyIiYDiWNWXZNhgVQ8Ux6q+INX2+49rQPTjJxj9gJJAcazqc1Ps s5KwIKA4VvW0
AADnY37KCmVuZHN0cmVhbQplbmRvYmoKMjExIDAgb2JqCjEyNQplbmRvYmoK MjEyIDAgb2Jq
Cjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTg1 Ci9MZW5ndGgg
MjEzIDAgUgovV2lkdGggMTU0Ci9IZWlnaHQgNDIKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
b3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0K Pj4Kc3RyZWFt
Cnic7cExAQAAAMKgbOtfyt8MQAEAAAAAAPAGfXxqnwplbmRzdHJlYW0KZW5k b2JqCjIxMyAw
IG9iagozMAplbmRvYmoKMjE0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTg2Ci9MZW5ndGggMjE1IDAgUgovV2lkdGggMTU0Ci9I ZWlnaHQgNDIK
L0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9N YXNrIFsyNTUg
MjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDIxMiAwIFIKL0ZpbHRlciBb IC9GbGF0ZURl
Y29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33Y1ZIejK1VVVVVVVVVV VVVVVVVVVVVV
VXX/azkwvgplbmRzdHJlYW0KZW5kb2JqCjIxNSAwIG9iago0NAplbmRvYmoK MjE2IDAgb2Jq
Cjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTg3 Ci9MZW5ndGgg
MjE3IDAgUgovV2lkdGggMTU0Ci9IZWlnaHQgNDIKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
Cnic7cExAQAAAMKgbOtfyt8MQAEAAAAAAPAGfXxqnwplbmRzdHJlYW0KZW5k b2JqCjIxNyAw
IG9iagozMAplbmRvYmoKMjE4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTg4Ci9MZW5ndGggMjE5IDAgUgovV2lkdGggMTU0Ci9I ZWlnaHQgNDIK
MjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDIxNiAwIFIKL0ZpbHRlciBb IC9GbGF0ZURl
VXX/azkwvgplbmRzdHJlYW0KZW5kb2JqCjIxOSAwIG9iago0NAplbmRvYmoK MjIwIDAgb2Jq
Cjw8IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAK L0Nvb3JkcyBb
IDE1NDUgMjI3IDE1NDUgMjY5IF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVu ZCBbIHRydWUg
dHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjIyMSAwIG9i ago8PCAKL1R5
cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyAyMjAgMCBS IAo+PiAKCmVu
ZG9iagoyMjIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1h Z2UKL05hbWUg
L0ltODkKL0xlbmd0aCAyMjMgMCBSCi9XaWR0aCAxMTUKL0hlaWdodCA0MAov Qml0c1BlckNv
ZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHg4oAAAAAB4NOTKQNQpl bmRzdHJlYW0K
ZW5kb2JqCjIyMyAwIG9iagoyOAplbmRvYmoKMjI0IDAgb2JqCjw8L1R5cGUg L1hPYmplY3QK
L1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTkwCi9MZW5ndGggMjI1IDAgUgov V2lkdGggMTE1
Ci9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDIyMiAw IFIKL0ZpbHRl
VVVVVVVVVVV3H87q3y4KZW5kc3RyZWFtCmVuZG9iagoyMjUgMCBvYmoKMzkK ZW5kb2JqCjIy
NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW05MQov
TGVuZ3RoIDIyNyAwIFIKL1dpZHRoIDExNQovSGVpZ2h0IDQwCi9CaXRzUGVy Q29tcG9uZW50
IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURl Y29kZSBdCj4+
CnN0cmVhbQp4nO3BAQ0AAADCoGzvX8oeDigAAAAAHg05MpA1CmVuZHN0cmVh bQplbmRvYmoK
MjI3IDAgb2JqCjI4CmVuZG9iagoyMjggMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltOTIKL0xlbmd0aCAyMjkgMCBSCi9XaWR0aCAx MTUKL0hlaWdo
dCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VS R0IKL01hc2sg
WzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMjI2IDAgUgovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVV VVVVVVVVVVVV
VXcfzurfLgplbmRzdHJlYW0KZW5kb2JqCjIyOSAwIG9iagozOQplbmRvYmoK MjMwIDAgb2Jq
IDk0MSA4NzggOTQxIDkxOCBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQg WyB0cnVlIHRy
dWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoyMzEgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMjMwIDAgUiAK Pj4gCgplbmRv
YmoKMjMyIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTkzCi9MZW5ndGggMjMzIDAgUgovV2lkdGggMTIyCi9IZWlnaHQgNzkKL0Jp dHNQZXJDb21w
b25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0Zs YXRlRGVjb2Rl
IF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhR+QAEAAAAAAAAAAPAzIZqP rgplbmRzdHJl
YW0KZW5kb2JqCjIzMyAwIG9iagozMwplbmRvYmoKMjM0IDAgb2JqCjw8L1R5 cGUgL1hPYmpl
Y3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTk0Ci9MZW5ndGggMjM1IDAg UgovV2lkdGgg
MTIyCi9IZWlnaHQgNzkKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFj ZSAvRGV2aWNl
UkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDIz MiAwIFIKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd 33bneICjK1VV
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVdX9dhhl1QplbmRzdHJlYW0KZW5k b2JqCjIzNSAw
IG9iago1MwplbmRvYmoKMjM2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTk1Ci9MZW5ndGggMjM3IDAgUgovV2lkdGggMTIyCi9I ZWlnaHQgNzkK
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhR+QAEA AAAAAAAAAPAz
IZqPrgplbmRzdHJlYW0KZW5kb2JqCjIzNyAwIG9iagozMwplbmRvYmoKMjM4 IDAgb2JqCjw8
L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTk2Ci9M ZW5ndGggMjM5
IDAgUgovV2lkdGggMTIyCi9IZWlnaHQgNzkKL0JpdHNQZXJDb21wb25lbnQg OAovQ29sb3JT
IDIzNiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nO3CMREAAAwD
Iekd33bneICjK1VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVdX9dhhl1Qpl bmRzdHJlYW0K
ZW5kb2JqCjIzOSAwIG9iago1MwplbmRvYmoKMjQwIDAgb2JqCjw8IAovU2hh ZGluZ1R5cGUg
MiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3JkcyBbIDQ1NSA4NiA0 NTUgMTY1IF0g
Ci9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVu Y3Rpb24gMTUg
MCBSIAo+PiAKZW5kb2JqCjI0MSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4g Ci9QYXR0ZXJu
VHlwZSAyIAovU2hhZGluZyAyNDAgMCBSIAo+PiAKCmVuZG9iagoyNDIgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltOTcKL0xlbmd0 aCAyNDMgMCBS
Ci9XaWR0aCAxNTQKL0hlaWdodCA0MgovQml0c1BlckNvbXBvbmVudCA4Ci9D b2xvclNwYWNl
IC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJl YW0KeJztwTEB
AAAAwqBs61/K3wxAAQAAAAAA8AZ9fGqfCmVuZHN0cmVhbQplbmRvYmoKMjQz IDAgb2JqCjMw
CmVuZG9iagoyNDQgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAv SW1hZ2UKL05h
bWUgL0ltOTgKL0xlbmd0aCAyNDUgMCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0 MgovQml0c1Bl
ckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1 NSAyNTUgMjU1
IDI1NSAyNTUgMjU1XQovU01hc2sgMjQyIDAgUgovRmlsdGVyIFsgL0ZsYXRl RGVjb2RlIF0K
Pj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdjVkh6MrVVVVVVVVVVVVVVVVVVVV VVVVdf9rOTC+
CmVuZHN0cmVhbQplbmRvYmoKMjQ1IDAgb2JqCjQ0CmVuZG9iagoyNDYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltOTkKL0xlbmd0 aCAyNDcgMCBS
AAAAwqBs61/K3wxAAQAAAAAA8AZ9fGqfCmVuZHN0cmVhbQplbmRvYmoKMjQ3 IDAgb2JqCjMw
CmVuZG9iagoyNDggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAv SW1hZ2UKL05h
bWUgL0ltMTAwCi9MZW5ndGggMjQ5IDAgUgovV2lkdGggMTU0Ci9IZWlnaHQg NDIKL0JpdHNQ
NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDI0NiAwIFIKL0ZpbHRlciBbIC9GbGF0 ZURlY29kZSBd
Cj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33Y1ZIejK1VVVVVVVVVVVVVVVVVV VVVVVXX/azkw
vgplbmRzdHJlYW0KZW5kb2JqCjI0OSAwIG9iago0NAplbmRvYmoKMjUwIDAg b2JqCjw8IAov
U2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3Jk cyBbIDE1NTAg
MzExIDE1NTAgMzUzIF0gCi9Eb21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRy dWUgdHJ1ZSBd
IAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjI1MSAwIG9iago8PCAK L1R5cGUgL1Bh
dHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyAyNTAgMCBSIAo+PiAK CmVuZG9iagoy
NTIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05h bWUgL0ltMTAx
Ci9MZW5ndGggMjUzIDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQ ZXJDb21wb25l
bnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRl RGVjb2RlIF0K
Pj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984KZW5kc3Ry ZWFtCmVuZG9i
agoyNTMgMCBvYmoKMjgKZW5kb2JqCjI1NCAwIG9iago8PC9UeXBlIC9YT2Jq ZWN0Ci9TdWJ0
eXBlIC9JbWFnZQovTmFtZSAvSW0xMDIKL0xlbmd0aCAyNTUgMCBSCi9XaWR0 aCAxMDAKL0hl
aWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZp Y2VSR0IKL01h
c2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMjUyIDAgUgov RmlsdGVyIFsg
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMr VVVVVVVVVVVV
VVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iagoyNTUgMCBvYmoKMzcKZW5kb2Jq CjI1NiAwIG9i
ago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0x MDMKL0xlbmd0
aCAyNTcgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBv bmVudCA4Ci9D
YW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRzdHJlYW0KZW5k b2JqCjI1NyAw
IG9iagoyOAplbmRvYmoKMjU4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTEwNAovTGVuZ3RoIDI1OSAwIFIKL1dpZHRoIDEwMAov SGVpZ2h0IDQw
Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgov TWFzayBbMjU1
IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAyNTYgMCBSCi9GaWx0ZXIg WyAvRmxhdGVE
ZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92ZWSBoytVVVVVVVVV VVVVVV1/U8k8
iQplbmRzdHJlYW0KZW5kb2JqCjI1OSAwIG9iagozNwplbmRvYmoKMjYwIDAg b2JqCjw8IAov
U2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3Jk cyBbIDg3OCA3
ODggODc4IDgyOCBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVl IHRydWUgXSAK
L0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoyNjEgMCBvYmoKPDwgCi9U eXBlIC9QYXR0
ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMjYwIDAgUiAKPj4gCgpl bmRvYmoKMjYy
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTEwNQov
TGVuZ3RoIDI2MyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVy Q29tcG9uZW50
CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oYPkABAAAAbwNujvfOCmVuZHN0cmVh bQplbmRvYmoK
MjYzIDAgb2JqCjI4CmVuZG9iagoyNjQgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltMTA2Ci9MZW5ndGggMjY1IDAgUgovV2lkdGgg MTAwCi9IZWln
IFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDI2MiAwIFIKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZlZIGjK1VV VVVVVVVVVVVV
XX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKMjY1IDAgb2JqCjM3CmVuZG9iagoy NjYgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTA3 Ci9MZW5ndGgg
MjY3IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
Cnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984KZW5kc3RyZWFtCmVuZG9i agoyNjcgMCBv
YmoKMjgKZW5kb2JqCjI2OCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW0xMDgKL0xlbmd0aCAyNjkgMCBSCi9XaWR0aCAxMDAKL0hl aWdodCA0MAov
NTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMjY2IDAgUgovRmlsdGVyIFsg L0ZsYXRlRGVj
b2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVVVVVVVVVV VVVdf1PJPIkK
ZW5kc3RyZWFtCmVuZG9iagoyNjkgMCBvYmoKMzcKZW5kb2JqCjI3MCAwIG9i ago8PCAKL1No
YWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29yZHMg WyA1MTggNDQ2
IDUxOCA0ODYgXSAKL0RvbWFpbiBbIDAgMSBdIAovRXh0ZW5kIFsgdHJ1ZSB0 cnVlIF0gCi9G
dW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoKMjcxIDAgb2JqCjw8IAovVHlw ZSAvUGF0dGVy
biAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5nIDI3MCAwIFIgCj4+IAoKZW5k b2JqCjI3MiAw
IG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAv SW0xMDkKL0xl
bmd0aCAyNzMgMCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0MgovQml0c1BlckNv bXBvbmVudCA4
dHJlYW0KeJztwTEBAAAAwqBs61/K3wxAAQAAAAAA8AZ9fGqfCmVuZHN0cmVh bQplbmRvYmoK
MjczIDAgb2JqCjMwCmVuZG9iagoyNzQgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltMTEwCi9MZW5ndGggMjc1IDAgUgovV2lkdGgg MTU0Ci9IZWln
aHQgNDIKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNl UkdCCi9NYXNr
IFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDI3MiAwIFIKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33Y1ZIejK1VV VVVVVVVVVVVV
VVVVVVVVVXX/azkwvgplbmRzdHJlYW0KZW5kb2JqCjI3NSAwIG9iago0NApl bmRvYmoKMjc2
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTExMQov
TGVuZ3RoIDI3NyAwIFIKL1dpZHRoIDE1NAovSGVpZ2h0IDQyCi9CaXRzUGVy Q29tcG9uZW50
CnN0cmVhbQp4nO3BMQEAAADCoGzrX8rfDEABAAAAAADwBn18ap8KZW5kc3Ry ZWFtCmVuZG9i
agoyNzcgMCBvYmoKMzAKZW5kb2JqCjI3OCAwIG9iago8PC9UeXBlIC9YT2Jq ZWN0Ci9TdWJ0
eXBlIC9JbWFnZQovTmFtZSAvSW0xMTIKL0xlbmd0aCAyNzkgMCBSCi9XaWR0 aCAxNTQKL0hl
c2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMjc2IDAgUgov RmlsdGVyIFsg
VVVVVVVVVVVVdf9rOTC+CmVuZHN0cmVhbQplbmRvYmoKMjc5IDAgb2JqCjQ0 CmVuZG9iagoy
ODAgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCIAov
Q29vcmRzIFsgMTU1NyAzOTcgMTU1NyA0MzkgXSAKL0RvbWFpbiBbIDAgMSBd IAovRXh0ZW5k
IFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoK MjgxIDAgb2Jq
Cjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5n IDI4MCAwIFIg
Cj4+IAoKZW5kb2JqCjI4MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW0xMTMKL0xlbmd0aCAyODMgMCBSCi9XaWR0aCAxNTQKL0hl aWdodCA0Mgov
Qml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9G aWx0ZXIgWyAv
RmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/K3wxAAQAA AAAA8AZ9fGqf
CmVuZHN0cmVhbQplbmRvYmoKMjgzIDAgb2JqCjMwCmVuZG9iagoyODQgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTE0Ci9MZW5n dGggMjg1IDAg
UgovV2lkdGggMTU0Ci9IZWlnaHQgNDIKL0JpdHNQZXJDb21wb25lbnQgOAov Q29sb3JTcGFj
ZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0K L1NNYXNrIDI4
MiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3C MREAAAwDIekd
33Y1ZIejK1VVVVVVVVVVVVVVVVVVVVVVVXX/azkwvgplbmRzdHJlYW0KZW5k b2JqCjI4NSAw
IG9iago0NAplbmRvYmoKMjg2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTExNQovTGVuZ3RoIDI4NyAwIFIKL1dpZHRoIDE1NAov SGVpZ2h0IDQy
IC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8rfDEAB AAAAAADwBn18
ap8KZW5kc3RyZWFtCmVuZG9iagoyODcgMCBvYmoKMzAKZW5kb2JqCjI4OCAw IG9iago8PC9U
eXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xMTYKL0xl bmd0aCAyODkg
MCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0MgovQml0c1BlckNvbXBvbmVudCA4 Ci9Db2xvclNw
Mjg2IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic 7cIxEQAADAMh
6R3fdjVkh6MrVVVVVVVVVVVVVVVVVVVVVVVVdf9rOTC+CmVuZHN0cmVhbQpl bmRvYmoKMjg5
IDAgb2JqCjQ0CmVuZG9iagoyOTAgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAy IAovQ29sb3JT
cGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgMTU1NiA1MDEgMTU1NiA1NDMg XSAKL0RvbWFp
IAplbmRvYmoKMjkxIDAgb2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRl cm5UeXBlIDIg
Ci9TaGFkaW5nIDI5MCAwIFIgCj4+IAoKZW5kb2JqCjI5MiAwIG9iago8PC9U eXBlIC9YT2Jq
ZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xMTcKL0xlbmd0aCAyOTMg MCBSCi9XaWR0
aCAxNTQKL0hlaWdodCA0MgovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNw YWNlIC9EZXZp
Y2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJzt wTEBAAAAwqBs
61/K3wxAAQAAAAAA8AZ9fGqfCmVuZHN0cmVhbQplbmRvYmoKMjkzIDAgb2Jq CjMwCmVuZG9i
agoyOTQgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UK L05hbWUgL0lt
MTE4Ci9MZW5ndGggMjk1IDAgUgovV2lkdGggMTU0Ci9IZWlnaHQgNDIKL0Jp dHNQZXJDb21w
b25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1 IDI1NSAyNTUg
MjU1IDI1NV0KL1NNYXNrIDI5MiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29k ZSBdCj4+CnN0
cmVhbQp4nO3CMREAAAwDIekd33Y1ZIejK1VVVVVVVVVVVVVVVVVVVVVVVXX/ azkwvgplbmRz
dHJlYW0KZW5kb2JqCjI5NSAwIG9iago0NAplbmRvYmoKMjk2IDAgb2JqCjw8 L1R5cGUgL1hP
YmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTExOQovTGVuZ3RoIDI5 NyAwIFIKL1dp
ZHRoIDE1NAovSGVpZ2h0IDQyCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9y U3BhY2UgL0Rl
dmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nO3BMQEAAADC
oGzrX8rfDEABAAAAAADwBn18ap8KZW5kc3RyZWFtCmVuZG9iagoyOTcgMCBv YmoKMzAKZW5k
b2JqCjI5OCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFn ZQovTmFtZSAv
SW0xMjAKL0xlbmd0aCAyOTkgMCBSCi9XaWR0aCAxNTQKL0hlaWdodCA0Mgov Qml0c1BlckNv
NSAyNTUgMjU1XQovU01hc2sgMjk2IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVj b2RlIF0KPj4K
c3RyZWFtCnic7cIxEQAADAMh6R3fdjVkh6MrVVVVVVVVVVVVVVVVVVVVVVVV df9rOTC+CmVu
ZHN0cmVhbQplbmRvYmoKMjk5IDAgb2JqCjQ0CmVuZG9iagozMDAgMCBvYmoK PDwgCi9TaGFk
aW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsg MTU0MCA5MyAx
NTQwIDEzNSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRy dWUgXSAKL0Z1
bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagozMDEgMCBvYmoKPDwgCi9UeXBl IC9QYXR0ZXJu
IAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMzAwIDAgUiAKPj4gCgplbmRv YmoKMzAyIDAg
b2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9J bTEyMQovTGVu
Z3RoIDMwMyAwIFIKL1dpZHRoIDE0OAovSGVpZ2h0IDQ3Ci9CaXRzUGVyQ29t cG9uZW50IDgK
cmVhbQp4nO3BgQAAAADDILb5Sx3kVQEAAAAAAMCnASaG5ocKZW5kc3RyZWFt CmVuZG9iagoz
MDMgMCBvYmoKMzAKZW5kb2JqCjMwNCAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW0xMjIKL0xlbmd0aCAzMDUgMCBSCi9XaWR0aCAx NDgKL0hlaWdo
dCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VS R0IKL01hc2sg
WzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMzAyIDAgUgovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cJBDQAADAMh6Xue7floIHSlqqqq qqqqqqqqqqqq
qqqqqqqqqrr+AR9QJbMKZW5kc3RyZWFtCmVuZG9iagozMDUgMCBvYmoKNDYK ZW5kb2JqCjMw
NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW0xMjMK
L0xlbmd0aCAzMDcgMCBSCi9XaWR0aCAxNDgKL0hlaWdodCA0NwovQml0c1Bl ckNvbXBvbmVu
PgpzdHJlYW0KeJztwYEAAAAAwyC2+Usd5FUBAAAAAADApwEmhuaHCmVuZHN0 cmVhbQplbmRv
YmoKMzA3IDAgb2JqCjMwCmVuZG9iagozMDggMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltMTI0Ci9MZW5ndGggMzA5IDAgUgovV2lk dGggMTQ4Ci9I
ZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCCi9N
YXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDMwNiAwIFIK L0ZpbHRlciBb
IC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CQQ0AAAwDIel7nu35aCB0 paqqqqqqqqqq
qqqqqqqqqqqqqqq6/gEfUCWzCmVuZHN0cmVhbQplbmRvYmoKMzA5IDAgb2Jq CjQ2CmVuZG9i
agozMTAgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAv RGV2aWNlUkdC
IAovQ29vcmRzIFsgMjIxIDk1IDIyMSAxNDIgXSAKL0RvbWFpbiBbIDAgMSBd IAovRXh0ZW5k
IFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoK MzExIDAgb2Jq
Cjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5n IDMxMCAwIFIg
Cj4+IAoKZW5kb2JqCjMxMiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW0xMjUKL0xlbmd0aCAzMTMgMCBSCi9XaWR0aCAxMDAKL0hl aWdodCAzOAov
RmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHG5AAQAA wK8BiCjFBgpl
bmRzdHJlYW0KZW5kb2JqCjMxMyAwIG9iagoyOAplbmRvYmoKMzE0IDAgb2Jq Cjw8L1R5cGUg
L1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTEyNgovTGVuZ3Ro IDMxNSAwIFIK
L1dpZHRoIDEwMAovSGVpZ2h0IDM4Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0Nv bG9yU3BhY2Ug
L0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9T TWFzayAzMTIg
NWSHoytVVVVVVVVVVVVV1eUDW3AGUgplbmRzdHJlYW0KZW5kb2JqCjMxNSAw IG9iagozNwpl
bmRvYmoKMzE2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTEyNwovTGVuZ3RoIDMxNyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDM4 Ci9CaXRzUGVy
Q29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBb IC9GbGF0ZURl
Y29kZSBdCj4+CnN0cmVhbQp4nO3BAQ0AAADCoGzvX8ocbkABAADArwGIKMUG CmVuZHN0cmVh
bQplbmRvYmoKMzE3IDAgb2JqCjI4CmVuZG9iagozMTggMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTI4Ci9MZW5ndGggMzE5IDAg UgovV2lkdGgg
MTAwCi9IZWlnaHQgMzgKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFj ZSAvRGV2aWNl
UkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDMx NiAwIFIKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd 33Y1ZIejK1VV
VVVVVVVVVVXV5QNbcAZSCmVuZHN0cmVhbQplbmRvYmoKMzE5IDAgb2JqCjM3 CmVuZG9iagoz
MjAgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCIAov
Q29vcmRzIFsgMTIzOCA0NDYgMTIzOCA0ODQgXSAKL0RvbWFpbiBbIDAgMSBd IAovRXh0ZW5k
IFsg
FUDForum. Page generated in 0.06529 seconds
