Home » Eclipse Projects » Virgo » Deployment order based on the artifact type
Deployment order based on the artifact type [message #577137] Fri, 28 May 2010 14:30 Go to next message
Dmitry Sklyut is currently offline Dmitry SklyutFriend
Hi All,
I wonder if there is some benefit in ordering deployment based on the artifact type. I see benefit for config-admin property files to be deployed prior to bundles that need that config. A simple use case is to bootstrap spring application with cm-properties, where config admin entries must be present before app context start up.
Re: Deployment order based on the artifact type [message #577164 is a reply to message #577137] Fri, 28 May 2010 14:47 Go to previous message
Glyn Normington is currently offline Glyn NormingtonFriend
Yes, you're right. In general, when the user needs to control deployment ordering, they either need to deploy artifacts in separate groups or, preferably, use a suitably structured plan which therefore controls the order in which artifacts are started.
Make sense?
Previous Topic:Deployment order based on the artifact type
Next Topic:Build Virgo
Current Time: Tue Mar 20 02:30:57 GMT 2018
Powered by FUDForum. Page generated in 0.01277 seconds
