Home » Archived » IMP » errors in LEGHoverHelper.java
errors in LEGHoverHelper.java [message #576729] Thu, 08 October 2009 21:37
Bob Frankel is currently offline Bob FrankelFriend
hi,
i just downloaded the latest release, synthesized all of the stock LEG
classes using the wizards, but ran into one compiler error that i can't
seem to resolve.... otherwise, everything else works just fine (under
Eclipse 3.5)....
specifically, the synthesized LEGHoverHelper.java class has a reference
to a getNodeLocator() method being applied to variable of type
IParserController; this class apparently has no such method.
there was a similar problem with a getParseStream() method being applied
to an IParser object; but a quick fix suggestion to use getIPrsStream()
at least resolved the compiler error....
bob
[FYI -- i'm a committer on the 'Real-Time Software Components' (RTSC)
project here at eclipse.org, and am exploring using IMP to generate
support for our component specification language; so far, IMP looks
quite promising -- not withstanding the aforemention compiler issues....
i'll no doubt have more questions, some of a broader nature once i
explore a little more....]
Previous Topic:Toggle comment behavior in LPG editor
Next Topic:errors in LEGHoverHelper.java
Current Time: Sun Feb 18 09:28:29 GMT 2018
Powered by FUDForum. Page generated in 0.01672 seconds
