Home » Archived » AM3 » problem with extract ecore metamodel to KM3
problem with extract ecore metamodel to KM3 [message #575026] Mon, 30 November 2009 22:35 Go to next message
farah Mising name is currently offline farah Mising nameFriend
Member
I have install the deprecated version of AM3 for the ATL developers.
But I can't see the "extract ecore metamodel to KM3" action!!
Thanks for your help.
Re: problem with extract ecore metamodel to KM3 [message #575057 is a reply to message #575026] Tue, 01 December 2009 09:07 Go to previous messageGo to next message
Guillaume Doux is currently offline Guillaume DouxFriend
Member
Hello Farah,
To see this action you have to be in the view called "AM3 Resource navigator". To open this view, go to "Window" -> "Show view" -> "other" -> "ATL" -> "AM3 Resource navigator".
In this view, it should work.
B.R.
Guillaume.
Re: problem with extract ecore metamodel to KM3 [message #575096 is a reply to message #575026] Sun, 06 December 2009 15:47 Go to previous message
Member
hello, thank you for your help, I have installed eclipse, the modeling plugins with source and the svn plugin.
after pressing "checkout", I have got "build successful"
once I opened " plug-in developpement perspective" many errors and warnings appeared on folders
I couldn't understand where the problem is ??!!!
I also couldn't accomplish the launch a Run-time workbench (Click on Run -> Run as -> Run-time workbench).
when I open "Window" -> "Show view" -> "other" -> I don't find "ATL".
thank you
Farah
Previous Topic:problem with extract ecore metamodel to KM3
Next Topic:installing KM3
Current Time: Fri May 25 22:45:42 GMT 2018
Powered by FUDForum. Page generated in 0.01899 seconds
