SWT AWT Bridge Issues [message #574579] |
Tue, 28 October 2008 08:12 |
Rahul Kamdar Messages: 63 Registered: July 2009 |
Member |
I am making use of SWT_AWT bridge in order to bring panels from my Swing/AWT
application into Eclipse SWT environment. I cannot make use of Albireo since
I have a restriction to stick to Eclipse 3.2 and can't go for Eclipse 3.3 or
higher.
I have broken down my Swing application's window into panels and then
embedded each of these into a JApplet which is added to the frame returned
by SWT_AWT. Some of the problems I am encountering are as follows:
1] Label/buttons within the panel often is not visible until the user moves
his mouse over the area where this label/buttons are located
2] On fast switching between the Eclipse views, often the panel/applet area
embedded inside the Eclipse view appears/becomes blank (anything related to
explicit setFocus?)
For these issues are there any possible resolutions or are these known
issues with the SWT_AWT Bridge framework?
I would be really grateful for any help/direction.
Rahul
FUDForum. Page generated in 0.02845 seconds
