Home » Archived » Visual Editor (VE) » Problems editing menus
Problems editing menus [message #573605] Wed, 10 December 2003 18:51
Eclipse User
Originally posted by: withheld.example.com
Hi there, I've been playing with the VE and I'm very impressed.
I've got a frame to which I've added a JMenuBar, and I've added a few
JMenu's but I'm having no luck adding JMenuItems. I saw the post about
using add bean, but I've tried building from beans, and the behaviour's
the same.
Am I doing something daft? I can manually add code, and the menu works
fine. I've been dropping the jMenuItems elsewhere then fixing the code
(moving add calls), and the result's fine.
And one final plea. Could anyone reccomend a good site or book that would
explain the java/swing way of doing things? The creations of objects per
command and the construction methods etc. I'm from C++/MFC land, (more C++
than MFC) so I guess I'm looking for a guide to best practices before I do
too much hacking.
Thanks for your time.
Pete
Previous Topic:What's the cvs repository path?
Next Topic:N00b install problems
Current Time: Wed Jun 19 19:47:24 EDT 2013
Powered by FUDForum. Page generated in 0.02004 seconds
