Home » Eclipse Projects » OSEE » Install problems
Install problems [message #572549] |
Sat, 18 April 2009 02:53 |
Rob Messages: 8 Registered: July 2009 |
Junior Member |
I am looking for a requirements management/ configuration management tools
and osee seemed to be just the sort of thing I was looking for.
I am relatively new to the eclipse world and can't seem to get osee
running.
I am using Windows XP.
I have downloaded postgresql and installed successfully.
I added the osee user and created the database as per these instructions:
http://www.eclipse.org/osee/documentation/installation/postg resql_install.php
I have downloaded eclipse, and it starts fine.
I have downloaded OSEE 0.7.0 Integration build and installed the
dependencies listed here:
http://www.eclipse.org/osee/documentation/installation/requi rements.php
When I try to initialize the database with the DbInit application as
indicated here
http://www.eclipse.org/osee/documentation/installation/db_in it.php
I get a Runtime error that DbInit is not found. The log file is below.
Can anyone help me?
Thanks in advance.
!SESSION 2009-04-17 20:12:54.250
eclipse.buildId=M20090211-1700
java.version=1.6.0_13
Framework arguments: -application
org.eclipse.osee.framework.application.server.DbInit
Command-line arguments: -os win32 -ws win32 -arch x86 -application
org.eclipse.osee.framework.application.server.DbInit -console
!ENTRY org.eclipse.osgi 4 0 2009-04-17 20:12:59.390
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.osee.framework.application.server.DbInit" could not be found
in the registry. The applications available are:
org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.director.app.application,
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.equinox.p2.reconciler.application,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer, org.eclipse.ant.ui.antRunner,
org.eclipse.birt.report.debug.core.ReportDebugger,
org.eclipse.birt.report.engine.ReportExecutor,
org.eclipse.datatools.connectivity.console.profile.StorageFi leEditor,
org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger,
org.eclipse.emf.codegen.ecore.Generator,
org.eclipse.emf.importer.ecore.Ecore2GenModel,
org.eclipse.emf.importer.java.Java2GenModel,
org.eclipse.emf.importer.rose.Rose2GenModel,
org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter,
org.eclipse.pde.build.Build,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.coretestapplicationnonmain,
org.eclipse.wst.jsdt.core.JavaCodeFormatter,
org.eclipse.wst.server.preview.preview,
org.eclipse.osee.framework.database.configClient,
org.eclipse.osee.framework.database.availableDbTasks,
org.eclipse.osee.framework.jini.JiniLookup,
org.eclipse.osee.framework.messaging.event.skynet.EventServi ce.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Current Time: Thu Apr 25 15:42:37 GMT 2024
Powered by FUDForum. Page generated in 0.03399 seconds
