Home » Archived » COSMOS » Failed trying to regenerate the samples - some handholding required...
Failed trying to regenerate the samples - some handholding required... [message #569847] Fri, 03 August 2007 12:10
Michael Moser is currently offline Michael MoserFriend
Hi all,
I tried to regenerate and execute the sample as described in
http://wiki.eclipse.org/COSMOSEnd2EndSample and I am currently in the
nested subroutine, sorry, "subdocument"
http://wiki.eclipse.org/COSMOSDataCollectorEnvironment Specifically I
was trying to run the build.xml scripts to generate the database (see
http://wiki.eclipse.org/COSMOSDataCollectorEnvironment#Set_u p_database).
These scripts both fail on me with a message "Java Virtual Machine
Launcher: Could not find main class. Program will exit". Any idea, what
I am missing here? This is on WinXP.
Michael
PS.: I have seen that I could instead download the provided and
pre-populated sample database here (which is what I am going to do until
someone responds to this append) but that is not the point, here. I
would like to be able to regenerate this entire demo natively.
Previous Topic:COSMOS 0.4 is now available
Next Topic:example database mainly empty?
Current Time: Thu Feb 22 03:56:30 GMT 2018
Powered by FUDForum. Page generated in 0.01414 seconds
