Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #569542] |
Sun, 04 May 2003 09:09 |
Originally posted by: dirk.schesmer.divos.de
Hi there,
when trying to execute XSDFindTypesMissingFacets.java in the Eclipse 2.1
using the environment emf/xsd 1.1.0, the system reports thje errors printed
below. Can please anyone give me a hint what to do?
Thanks for help,
Dirk V. Schesmer
Shane, please try to update the compile parameters - especially names ans
locations of jars - when you have some time left over, thanks!
* <br/>set ECLIPSE=BASEDIR
* <br/>set
_CP=%CLASSPATH%;%ECLIPSE%/plugins/org.eclipse.core.boot/boot .jar;%
ECLIPSE%/plugins/org.eclipse.core.runtime/runtime.jar;%ECLIP SE%/plugins/org.
apache.xerces/xerces.jar;%ECLIPSE%/plugins/org.eclipse.core. resources/resour
ces.jar;%ECLIPSE%/plugins/org.eclipse.emf/emf.jar;%ECLIPSE%/ plugins/org.ecli
pse.xsd/xsd.jar;path-or-jar-containing-XSDFindTypesMissingFa cet
* <br/>java -classpath %_CP% -DECLIPSE=%ECLIPSE%
org.eclipse.xsd.util.XSDFindTypesMissingFacet [schema.xsd]
* </code>
* </p>
The error message produced when executing the software in Eclipe 2.1:
java.lang.VerifyError: (class: org/eclipse/xsd/util/XSDParser$2, method:
xmlDecl signature:
(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/ apache/xerces/xn
i/Augmentations;)V) Illegal use of nonvirtual function call
at org.eclipse.xsd.util.XSDParser$1.<init>(XSDParser.java:206)
org.eclipse.xsd.util.XSDParser$1$GiantHack.newSAXParser(XSDP arser.java:197)
at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:386)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:282)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
pl.java:220)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
mpl.java:286)
org.eclipse.xsd.util.XSDFindTypesMissingFacets.loadSchemaUsi ngResourceSet(Un
known Source)
at org.eclipse.xsd.util.XSDFindTypesMissingFacets.main(Unknown Source)
Exception in thread "main"
FUDForum. Page generated in 0.01890 seconds
