Home » Eclipse Projects » Linux Tools Project » Building problem
Building problem [message #568620] Fri, 26 March 2010 08:43 Go to next message
Martin Jakl is currently offline Martin JaklFriend
I've upgraded to the latest version of Linux Tools and now every build calls make distclean first. It's very annoying. Does somebody know if there is a way to switch it back to normal incremental build? It's unusable now.
Re: Building problem [message #568705 is a reply to message #568620] Tue, 06 April 2010 19:17 Go to previous messageGo to next message
Jeff Johnston is currently offline Jeff JohnstonFriend
This is a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=308261 which I have just fixed. It will be in the next nightly update and will also be in the next releaseL 0.5.1.
Re: Building problem [message #568743 is a reply to message #568705] Thu, 08 April 2010 18:44 Go to previous message
Note that updates-nightly is now for Helios so you would need to use updates-nightly-galileo.
Previous Topic:SystemTap Dashboard broken?
Next Topic:Building problem
Current Time: Wed May 23 01:37:13 GMT 2018
Powered by FUDForum. Page generated in 0.01674 seconds
