| New EclipseUML 2008 for Java [message #566464] |
Sat, 03 January 2009 06:11 |
Vlad Varnica Messages: 546 Registered: July 2009 Location: Milton Keynes - UK |
The new EclipseUML Studio 2008 for Eclipse Ganymede is available for
download at: http://www.ejb3.org/download_studio_eclipse_3.4.html
Changelog since our latest post in July 2008:
EclipseUML_E340_2008_studioEdition_3.4.1.v20081211 - December 11th 2008
* Sequence diagram PNG and JPG images export don't show message fixed
* Image export of the composite structure diagram New
* Open Xmi and Property View contextual menu in the Sequence Diagram
New
* Manually move Instance having coming from a creation message layout
Fixed
* Unify connection link is nicer enhancement
* Actor is possible in component diagram fixed
* Format Group Menu in all diagram if same elements are selected New
* Alignment contextual menu New
* Action can have more than one line in the Activity diagram New
* XMI Back : This option will recreate full project information and
backup it inside the xmi model. New
* Model Merge : This option will merge existing model with the latest
java code. It means that you can reverse a project at the beginning, and
then update your model without deleting any existing information. New
* Show Hide Multiplicity inside Component and Deployment diagram New
* Delete java classifiers from your project code > all classifiers
will immediately become MDA (e.g. only related to the Model and not
anymore to java) New
* Paste and copy diagrams inside another project > All existing
elements will become read only New
* Paste and copy diagrams + model of a reversed java project > all
classifiers will become MDA New
* EMF compare integration for SVN and CVS New
* Eannotions in the XMI Model should use relative path fixed
* Format menu in deployment; communication and object diagrams fixed
EclipseUML_E340_2008_studioEdition_3.4.1.v20081030 - October 30th 2008
* Projects full refresh and cleaning at Eclipse start up in order to
avoid license problem Enhancement
* Multiple project merge NEW
* few non blocking bug fixed on class, sequence, usecase diagrams
Enhancement
* UseCase Diagram show hide association multiplicity NEW
* Deployment diagram new elements "Device & execution environment" New
* Drag and drop inner elements in and out inside other elements at
multiple deployment diagram graphical traceability fixed
* Export image truncating of methods and attributes fixed
* Component diagram having lollipop interfaces in an inner component
fixed
* Keywords on action Enhancement
* Add required interface on component in the deployment diagram New
* Return message with a Label inside sequence diagram New
* State value is now saved in the model New
* Node can be created inside an existing node Enhancement
* Add a note in the communication diagram Fixed
* save is now synchronized in the Project Explorer View between UML
model tree navigation and UML diagrams New
* delete from model elements and clean metamodel fixed
* drag and drop communication diagram elements New
* insert Interface supertypes in the diagram fixed
* link thickness in the communication diagram fixed
* associations in the usecase diagram fixed
* interface as lolipop in component, usecase and deployment diagram New
* automatic creation of dependencies with stereotype fixed
* Model full merge after drag and drop
* Drag and drop of RSA 7 and Eclipse Modeling elements NEW
* EclipseUML multiple projects Merge New
* RSA 7 projects Merge New
* Eclipse Modeling Tools project Merge New
* All Java annotations are live syncrhonized with model and UML Editor
New
* method truncated in export image fixed
* Dimension on methods and attributes not displayed in the diagram
fixed
* Arrange All without changing package inner layout New
The sequence diagram has also been improved:
* Move label on a message in the sequence diagram (This is a
regression in the September 5th build fixed:oops::oops: )
* Straight line on a message in the Sequence Diagram in order to
change anchors New
* Message wizard New button in the sequence diagram message fixed
* resize activation bar
* Straight Message Line (New)
* Resize Frame
* Move Frame
* Name of the Frame
* Return element
* a regression in the reverse of inner Frames inside the Sequence
diagram fixed
* the frame should be moving with the activation bar is it is moving
below the frame fixed
* Note can't be added to sequence diagram fixed
* Instance of a creation message can't move if you create a frame fixed
* lifelane layout New
* Move frame synchronized with UML2 New
* New instance synchronized with Frame New
* Move inner frame fixed
* Reverse method fixed
* Reverse multiple inner frames fixed
EclipseUML_E340_2008_studioEdition_3.4.0.v20080905 - September 5th 2008
* Template signature creation on class and interface New
* Port inside the class diagram New
* Slow down reverse engineering display New
* Keywords extended to all UML elements New
* Reverse of Legacy Jar file New
* Multiple project modeling New
* Object Diagram upgrade to UML 2.1 metamodel and UML Editor and many
goodies New
* Communication Diagram upgrade to UML 2.1 metamodel and UML Editor
and many goodies New
* Sequence diagram reverse enhancement fixed
* Sequence diagram reverse of multiple legacy project New
* Dynamic navigation New
* Diagram explorer New
Vlad
Omondo
FUDForum. Page generated in 0.01506 seconds
