Home » Archived » IAM (Eclipse Integration for Apache Maven) » Problems with Maven Eclipse Plugin
Problems with Maven Eclipse Plugin [message #565922] Tue, 13 May 2008 14:58
Harrison Curtis is currently offline Harrison CurtisFriend
This may be the wrong place to ask this question, if so please advise
where the issue should be reported.
When Eclipse starts up I encounter the following error:
___________
5/12/08 12:11:07 PM MDT: Downloaded [central] ->
http://repo1.maven.org/maven2/.index/nexus-maven-repository- index.zip
5/12/08 12:11:08 PM MDT: Unable to update index for central
___________
However, I have no problem using the same URL in my browser to download
the nexus-maven-repository-index.zip.
Then when I attempt to build (The POM has an ant generate-sources phase
to generate using JAXB some source) with in Eclipse I get the following
errors reported:
___________
5/12/08 12:28:14 PM MDT: [INFO] Executing tasks
5/12/08 12:28:14 PM MDT: [FATAL ERROR]
org.apache.maven.plugin.antrun.AntRunMojo#execute() caused a linkage
error (java.lang.NoSuchMethodError) and may be out-of-date. Check the
realms:
5/12/08 12:28:14 PM MDT: [FATAL ERROR] Plugin realm =
/plugins/org.apache.maven.plugins:maven-antrun-plugin:1.1@48/thread:Worker-10
urls[0] =
file:/C:/Documents%20and%20Settings/harrison.curtis/.m2/repo sitory/org/apache/maven/plugins/maven-antrun-plugin/1.1/mave n-antrun-plugin-1.1.jar
urls[1] =
file:/C:/Documents%20and%20Settings/harrison.curtis/.m2/repo sitory/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1 .jar
urls[2] =
file:/C:/Documents%20and%20Settings/harrison.curtis/.m2/repo sitory/junit/junit/3.8.1/junit-3.8.1.jar
urls[3] =
file:/C:/Documents%20and%20Settings/harrison.curtis/.m2/repo sitory/ant/ant/1.6.5/ant-1.6.5.jar
urls[4] =
file:/C:/Documents%20and%20Settings/harrison.curtis/.m2/repo sitory/ant/ant-launcher/1.6.5/ant-launcher-1.6.5.jar
5/12/08 12:28:14 PM MDT: [FATAL ERROR] Container realm = plexus.core
5/12/08 12:28:14 PM MDT: ERROR mojo-execute : antrun:run :
org.apache.maven.settings.Settings.setRuntimeInfo(Lorg/apach e/maven/settings/RuntimeInfo;)V
5/12/08 12:28:14 PM MDT: Build error for /SSRListener/pom.xml;
java.lang.NoSuchMethodError:
___________
If I run Maven outside of Eclipse it runs fine with no error. Can
someone suggest what the problem is.
Previous Topic:Re: Adding Lukáš Křečan as a committer on m2eclipse
Next Topic:Problems with Maven Eclipse Plugin
Current Time: Sat Feb 24 04:54:36 GMT 2018
Powered by FUDForum. Page generated in 0.01489 seconds
