Home » Eclipse Projects » eRCP » Re: Java vm running eRCP
Re: Java vm running eRCP [message #563173] Sat, 20 June 2009 22:47
Matthias Schoettle is currently offline Matthias SchoettleFriend
How is your application configured? Do you use eWorkbench or your own workbench?
Is there an error when you try to start your application?
> Might it even be possible to run eRCP using a Midlet setup? Right now
> I'm struggeling with EclispeME and eRCP, since there are some
> unavailable classes like NoSuchMethodException etc.
> Is it simply impossible to run eRCP with midlets?
Please read this wiki article:
P.S.: The eRCP newsgroup has moved to eclipse.ercp.
Previous Topic:Re: Java vm running eRCP
Next Topic:Question regarding build process
Current Time: Wed Mar 21 03:39:09 GMT 2018
Powered by FUDForum. Page generated in 0.02313 seconds
