Home » Archived » ATF » ATF Debugging question
ATF Debugging question [message #563046] Tue, 08 June 2010 19:55 Go to next message
Arin Lipman is currently offline Arin LipmanFriend
I'm trying out ATF, and I have an HTML file that I included into a project through Eclipse. When I debug through Mozilla, it doesn't use the breakpoints that I entered into the editor. I need to load up the source file (by double clicking on the file in scripts) and put in the breakpoints in that file.
Should the debug in Mozilla detect these breakpoints? Also I need to actually run the HTM file from a full URL (since my script includes are coded for that), so I won't be able to use the Project File option to run (and will need to use URL), will that support loaded breakpoints?
Arin
Re: ATF Debugging question [message #563118 is a reply to message #563046] Wed, 30 June 2010 20:27 Go to previous messageGo to next message
vlad.balan Missing name is currently offline vlad.balan Missing nameFriend
Member
what do you mean by
- "since my script includes are coded for that"
- and by "will that support loaded breakpoints"
Try and see the URL debug config type.
Re: ATF Debugging question [message #563194 is a reply to message #563118] Thu, 01 July 2010 17:29 Go to previous message
By : "since my script includes are coded for that" I mean that the <script src=xxx > points to the location on the Web server, which is not the same as the file system
By: "will that support loaded breakpoints" I mean that I want to put a breakpoint in foo.htm and when I run http://blah/foo.htm I want that breakpoint to be active instead of needing to open the source of the "downloaded" file and put the breakpoint in that version, and then reload the page.
Arin
Previous Topic:ATF Debugging question
Next Topic:Mirror of mozilla xpcom update site
Current Time: Fri Feb 23 03:12:43 GMT 2018
Powered by FUDForum. Page generated in 0.01364 seconds
