Home » Modeling » Papyrus » Problem creating view
Problem creating view [message #559824] Sun, 19 September 2010 16:28
123star  is currently offline 123star Friend
Member
I'm trying to create the view of semantic elements, but I encountered an exception:
Here's the code:
public static void createNodeView(EObject element){
PapyrusMultiDiagramEditor editor = (PapyrusMultiDiagramEditor) PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor();
ViewDescriptor viewDescriptor = new ViewDescriptor(
new EObjectAdapter(element), Node.class, String.valueOf(ViewUtil.APPEND), editor.getDiagramEditPart().getDiagramPreferencesHint());
CreateViewRequest req = new CreateViewRequest(viewDescriptor);
Command comm = editor.getDiagramEditPart().getCommand(req);
comm.execute();
Here's the exception:
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:failed to create a view
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:150)
at org.eclipse.gmf.runtime.diagram.ui.commands.ICommandProxy.ex ecute(ICommandProxy.java:68)
at org.eclipse.gef.commands.CompoundCommand.execute(CompoundCom mand.java:107)
at main.Shared.createNodeView(Shared.java:274)
I can't see the error, any suggestion?
Thanks in advance, 123star
Previous Topic:Actor in Block Definition Diagram?
Next Topic:Change Shape of Collaboration in UML2 Composite Diagram
Current Time: Fri May 25 09:19:12 GMT 2018
Powered by FUDForum. Page generated in 0.01686 seconds
