| SWTbot and XMind [message #558730] |
Tue, 14 September 2010 04:47  |
Originally posted by: wycieruch.gmail.com
It's my first post on this newsgroup so hello everybody :)
I have an issue with SWTbot, which I was going to use to test my
application based on Xmind. And Xmind is GEF based mind map editor.
I installed SWTbot for GEF plugin and I wrote my first test class.
However when I want to get access to the gef editor I get un error. The
label of the editor is ok and everything is like in tutorial. I'm sure
that editor was found by SWTbot but in the end I got null pointer
exception. Can somebody tell me what is wrong?
My eclipse version: 3.5
My SWTbot version: 2.0
Thanks for any help
Marek.
package com.nglogic.xmindlook.testing.tests;
import org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot;
import org.eclipse.swtbot.eclipse.gef.finder.SWTGefBot;
import org.eclipse.swtbot.eclipse.gef.finder.widgets.SWTBotGefEdito r;
import org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner;
import org.junit.AfterClass;
import org.junit.BeforeClass;
import org.junit.Test;
import org.junit.runner.RunWith;
@RunWith(SWTBotJunit4ClassRunner.class)
public class MyFirstTest {
private static SWTWorkbenchBot bot;
private static SWTGefBot gefBot;
@BeforeClass
public static void beforeClass() throws Exception {
bot = new SWTWorkbenchBot();
gefBot = new SWTGefBot();
@Test
public void canCreateANewJavaProject() throws Exception {
//the line below gives un error
SWTBotGefEditor editor = gefBot.gefEditor("Workbook 1");
@AfterClass
public static void sleep() {
bot.sleep(2000);
| Re: SWTbot and XMind [message #559175 is a reply to message #558735] |
Wed, 15 September 2010 16:18   |
--------------000102030803010306060308
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Mariot,
The trace is in the attached text file.
Marek
W dniu 2010-09-14 11:02, Mariot Chauvin pisze:
> Hi Marek,
> Can you give us the stacktrace ?
> Mariot
> Marek Adamek a écrit :
>> Thanks for any help
>> Marek.
>> @BeforeClass
>> @Test
>> @AfterClass
>> bot.sleep(2000);
name="trace.txt"
Content-Disposition: attachment;
filename="trace.txt"
b3JnLmVjbGlwc2Uuc3d0LlNXVEV4Y2VwdGlvbjogRmFpbGVkIHRvIGV4ZWN1 dGUgcnVubmFi
bGUgKGphdmEubGFuZy5OdWxsUG9pbnRlckV4Y2VwdGlvbikNCglhdCBvcmcu ZWNsaXBzZS5z
d3QuU1dULmVycm9yKFNXVC5qYXZhOjM4ODQpDQoJYXQgb3JnLmVjbGlwc2Uu c3d0LlNXVC5l
cnJvcihTV1QuamF2YTozNzk5KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLlN5bmNo
cm9uaXplci5zeW5jRXhlYyhTeW5jaHJvbml6ZXIuamF2YToxOTUpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuVUlTeW5jaHJvbml6ZXIuc3luY0V4ZWMoVUlTeW5j aHJvbml6ZXIu
amF2YToxNTApDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxh eS5zeW5jRXhl
YyhEaXNwbGF5LmphdmE6NDM0MikNCglhdCBvcmcuZWNsaXBzZS5zd3Rib3Qu c3d0LmZpbmRl
ci5maW5kZXJzLlVJVGhyZWFkUnVubmFibGUucnVuKFVJVGhyZWFkUnVubmFi bGUuamF2YTo3
NikNCglhdCBvcmcuZWNsaXBzZS5zd3Rib3Quc3d0LmZpbmRlci5maW5kZXJz LlVJVGhyZWFk
UnVubmFibGUuc3luY0V4ZWMoVUlUaHJlYWRSdW5uYWJsZS5qYXZhOjE5OCkN CglhdCBvcmcu
ZWNsaXBzZS5zd3Rib3Quc3d0LmZpbmRlci5maW5kZXJzLlVJVGhyZWFkUnVu bmFibGUuc3lu
Y0V4ZWMoVUlUaHJlYWRSdW5uYWJsZS5qYXZhOjE4MykNCglhdCBvcmcuZWNs aXBzZS5zd3Ri
b3QuZWNsaXBzZS5nZWYuZmluZGVyLndpZGdldHMuU1dUQm90R2VmRWRpdG9y LmluaXQoU1dU
Qm90R2VmRWRpdG9yLmphdmE6OTIpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0Ym90 LmVjbGlwc2Uu
Z2VmLmZpbmRlci53aWRnZXRzLlNXVEJvdEdlZkVkaXRvci48aW5pdD4oU1dU Qm90R2VmRWRp
dG9yLmphdmE6ODEpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0Ym90LmVjbGlwc2Uu Z2VmLmZpbmRl
ci5TV1RHZWZCb3QuY3JlYXRlRWRpdG9yKFNXVEdlZkJvdC5qYXZhOjY1KQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dGJvdC5lY2xpcHNlLmdlZi5maW5kZXIuU1dUR2VmQm90Lmdl ZkVkaXRvcihT
V1RHZWZCb3QuamF2YTo1NSkNCglhdCBvcmcuZWNsaXBzZS5zd3Rib3QuZWNs aXBzZS5nZWYu
ZmluZGVyLlNXVEdlZkJvdC5nZWZFZGl0b3IoU1dUR2VmQm90LmphdmE6Mzcp DQoJYXQgY29t
Lm5nbG9naWMueG1pbmRsb29rLnRlc3RpbmcudGVzdHMuTXlGaXJzdFRlc3Qu Y2FuQ3JlYXRl
QU5ld0phdmFQcm9qZWN0KE15Rmlyc3RUZXN0LmphdmE6MjYpDQoJYXQgc3Vu LnJlZmxlY3Qu
TmF0aXZlTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZTAoTmF0aXZlIE1ldGhv ZCkNCglhdCBz
dW4ucmVmbGVjdC5OYXRpdmVNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVu a25vd24gU291
cmNlKQ0KCWF0IHN1bi5yZWZsZWN0LkRlbGVnYXRpbmdNZXRob2RBY2Nlc3Nv ckltcGwuaW52
b2tlKFVua25vd24gU291cmNlKQ0KCWF0IGphdmEubGFuZy5yZWZsZWN0Lk1l dGhvZC5pbnZv
a2UoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmp1bml0LnJ1bm5lcnMubW9k ZWwuRnJhbWV3
b3JrTWV0aG9kJDEucnVuUmVmbGVjdGl2ZUNhbGwoRnJhbWV3b3JrTWV0aG9k LmphdmE6NDQp
DQoJYXQgb3JnLmp1bml0LmludGVybmFsLnJ1bm5lcnMubW9kZWwuUmVmbGVj dGl2ZUNhbGxh
YmxlLnJ1bihSZWZsZWN0aXZlQ2FsbGFibGUuamF2YToxNSkNCglhdCBvcmcu anVuaXQucnVu
bmVycy5tb2RlbC5GcmFtZXdvcmtNZXRob2QuaW52b2tlRXhwbG9zaXZlbHko RnJhbWV3b3Jr
TWV0aG9kLmphdmE6NDEpDQoJYXQgb3JnLmp1bml0LmludGVybmFsLnJ1bm5l cnMuc3RhdGVt
ZW50cy5JbnZva2VNZXRob2QuZXZhbHVhdGUoSW52b2tlTWV0aG9kLmphdmE6 MjApDQoJYXQg
b3JnLmp1bml0LmludGVybmFsLnJ1bm5lcnMuc3RhdGVtZW50cy5SdW5CZWZv cmVzLmV2YWx1
YXRlKFJ1bkJlZm9yZXMuamF2YToyOCkNCglhdCBvcmcuanVuaXQuaW50ZXJu YWwucnVubmVy
cy5zdGF0ZW1lbnRzLlJ1bkFmdGVycy5ldmFsdWF0ZShSdW5BZnRlcnMuamF2 YTozMSkNCglh
dCBvcmcuanVuaXQucnVubmVycy5CbG9ja0pVbml0NENsYXNzUnVubmVyLnJ1 bkNoaWxkKEJs
b2NrSlVuaXQ0Q2xhc3NSdW5uZXIuamF2YTo3MykNCglhdCBvcmcuanVuaXQu cnVubmVycy5C
bG9ja0pVbml0NENsYXNzUnVubmVyLnJ1bkNoaWxkKEJsb2NrSlVuaXQ0Q2xh c3NSdW5uZXIu
amF2YTo0NikNCglhdCBvcmcuanVuaXQucnVubmVycy5QYXJlbnRSdW5uZXIu cnVuQ2hpbGRy
ZW4oUGFyZW50UnVubmVyLmphdmE6MTgwKQ0KCWF0IG9yZy5qdW5pdC5ydW5u ZXJzLlBhcmVu
dFJ1bm5lci5hY2Nlc3MkMDAwKFBhcmVudFJ1bm5lci5qYXZhOjQxKQ0KCWF0 IG9yZy5qdW5p
dC5ydW5uZXJzLlBhcmVudFJ1bm5lciQxLmV2YWx1YXRlKFBhcmVudFJ1bm5l ci5qYXZhOjE3
MykNCglhdCBvcmcuanVuaXQuaW50ZXJuYWwucnVubmVycy5zdGF0ZW1lbnRz LlJ1bkJlZm9y
ZXMuZXZhbHVhdGUoUnVuQmVmb3Jlcy5qYXZhOjI4KQ0KCWF0IG9yZy5qdW5p dC5pbnRlcm5h
bC5ydW5uZXJzLnN0YXRlbWVudHMuUnVuQWZ0ZXJzLmV2YWx1YXRlKFJ1bkFm dGVycy5qYXZh
OjMxKQ0KCWF0IG9yZy5qdW5pdC5ydW5uZXJzLlBhcmVudFJ1bm5lci5ydW4o UGFyZW50UnVu
bmVyLmphdmE6MjIwKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dGJvdC5zd3QuZmlu ZGVyLmp1bml0
LlNXVEJvdEp1bml0NENsYXNzUnVubmVyLnJ1bihTV1RCb3RKdW5pdDRDbGFz c1J1bm5lci5q
YXZhOjU0KQ0KCWF0IG9yZy5lY2xpcHNlLmpkdC5pbnRlcm5hbC5qdW5pdDQu cnVubmVyLkpV
bml0NFRlc3RSZWZlcmVuY2UucnVuKEpVbml0NFRlc3RSZWZlcmVuY2UuamF2 YTo0NikNCglh
dCBvcmcuZWNsaXBzZS5qZHQuaW50ZXJuYWwuanVuaXQucnVubmVyLlRlc3RF eGVjdXRpb24u
cnVuKFRlc3RFeGVjdXRpb24uamF2YTozOCkNCglhdCBvcmcuZWNsaXBzZS5q ZHQuaW50ZXJu
YWwuanVuaXQucnVubmVyLlJlbW90ZVRlc3RSdW5uZXIucnVuVGVzdHMoUmVt b3RlVGVzdFJ1
bm5lci5qYXZhOjQ2NykNCglhdCBvcmcuZWNsaXBzZS5qZHQuaW50ZXJuYWwu anVuaXQucnVu
bmVyLlJlbW90ZVRlc3RSdW5uZXIucnVuVGVzdHMoUmVtb3RlVGVzdFJ1bm5l ci5qYXZhOjY4
MykNCglhdCBvcmcuZWNsaXBzZS5qZHQuaW50ZXJuYWwuanVuaXQucnVubmVy LlJlbW90ZVRl
c3RSdW5uZXIucnVuKFJlbW90ZVRlc3RSdW5uZXIuamF2YTozOTApDQoJYXQg b3JnLmVjbGlw
c2Uuc3d0Ym90LmVjbGlwc2UuY29yZS5SZW1vdGVQbHVnaW5UZXN0UnVubmVy Lm1haW4oUmVt
b3RlUGx1Z2luVGVzdFJ1bm5lci5qYXZhOjY0KQ0KCWF0IG9yZy5lY2xpcHNl LnN3dGJvdC5l
Y2xpcHNlLmNvcmUuVUlUZXN0QXBwbGljYXRpb24ucnVuVGVzdHMoVUlUZXN0 QXBwbGljYXRp
b24uamF2YToxMTcpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwudGVz dGluZy5Xb3Jr
YmVuY2hUZXN0YWJsZSQxLnJ1bihXb3JrYmVuY2hUZXN0YWJsZS5qYXZhOjcx KQ0KCWF0IGph
dmEubGFuZy5UaHJlYWQucnVuKFVua25vd24gU291cmNlKQ0KQ2F1c2VkIGJ5 OiBqYXZhLmxh
bmcuTnVsbFBvaW50ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNsaXBzZS5zd3Ri b3QuZWNsaXBz
ZS5nZWYuZmluZGVyLndpZGdldHMuU1dUQm90R2VmRWRpdG9yJDEucnVuKFNX VEJvdEdlZkVk
aXRvci5qYXZhOjk2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dGJvdC5zd3QuZmlu ZGVyLmZpbmRl
cnMuVUlUaHJlYWRSdW5uYWJsZSQ0LmRvUnVuKFVJVGhyZWFkUnVubmFibGUu amF2YToxOTYp
DQoJYXQgb3JnLmVjbGlwc2Uuc3d0Ym90LnN3dC5maW5kZXIuZmluZGVycy5V SVRocmVhZFJ1
bm5hYmxlJDEucnVuKFVJVGhyZWFkUnVubmFibGUuamF2YTo4OSkNCglhdCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5SdW5uYWJsZUxvY2sucnVuKFJ1bm5hYmxlTG9jay5q YXZhOjM1KQ0K
CWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLlN5bmNocm9uaXplci5ydW5B c3luY01lc3Nh
Z2VzKFN5bmNocm9uaXplci5qYXZhOjEzNCkNCglhdCBvcmcuZWNsaXBzZS5z d3Qud2lkZ2V0
cy5EaXNwbGF5LnJ1bkFzeW5jTWVzc2FnZXMoRGlzcGxheS5qYXZhOjM4ODUp DQoJYXQgb3Jn
LmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFkQW5kRGlzcGF0Y2go RGlzcGxheS5q
YXZhOjM1MDYpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2Jl bmNoLnJ1bkV2
ZW50TG9vcChXb3JrYmVuY2guamF2YToyNDA1KQ0KCWF0IG9yZy5lY2xpcHNl LnVpLmludGVy
bmFsLldvcmtiZW5jaC5ydW5VSShXb3JrYmVuY2guamF2YToyMzY5KQ0KCWF0 IG9yZy5lY2xp
cHNlLnVpLmludGVybmFsLldvcmtiZW5jaC5hY2Nlc3MkNChXb3JrYmVuY2gu amF2YToyMjIx
KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaCQ1LnJ1 bihXb3JrYmVu
Y2guamF2YTo1MDApDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5kYXRhYmluZGlu Zy5vYnNlcnZh
YmxlLlJlYWxtLnJ1bldpdGhEZWZhdWx0KFJlYWxtLmphdmE6MzMyKQ0KCWF0 IG9yZy5lY2xp
cHNlLnVpLmludGVybmFsLldvcmtiZW5jaC5jcmVhdGVBbmRSdW5Xb3JrYmVu Y2goV29ya2Jl
bmNoLmphdmE6NDkzKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLlBsYXRmb3JtVUku Y3JlYXRlQW5k
UnVuV29ya2JlbmNoKFBsYXRmb3JtVUkuamF2YToxNDkpDQoJYXQgb3JnLnht aW5kLmNhdGh5
LmludGVybmFsLkNhdGh5QXBwbGljYXRpb24uc3RhcnQoQ2F0aHlBcHBsaWNh dGlvbi5qYXZh
OjQ2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dGJvdC5lY2xpcHNlLmNvcmUuVUlU ZXN0QXBwbGlj
YXRpb24uc3RhcnQoVUlUZXN0QXBwbGljYXRpb24uamF2YTo1NCkNCglhdCBv cmcuZWNsaXBz
ZS5lcXVpbm94LmludGVybmFsLmFwcC5FY2xpcHNlQXBwSGFuZGxlLnJ1bihF Y2xpcHNlQXBw
SGFuZGxlLmphdmE6MTk0KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGlt ZS5pbnRlcm5h
bC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVuY2hlci5ydW5BcHBsaWNhdGlvbihF Y2xpcHNlQXBw
TGF1bmNoZXIuamF2YToxMTApDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5ydW50 aW1lLmludGVy
bmFsLmFkYXB0b3IuRWNsaXBzZUFwcExhdW5jaGVyLnN0YXJ0KEVjbGlwc2VB cHBMYXVuY2hl
ci5qYXZhOjc5KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5hZGFw dG9yLkVjbGlw
c2VTdGFydGVyLnJ1bihFY2xpcHNlU3RhcnRlci5qYXZhOjM2OCkNCglhdCBv cmcuZWNsaXBz
ZS5jb3JlLnJ1bnRpbWUuYWRhcHRvci5FY2xpcHNlU3RhcnRlci5ydW4oRWNs aXBzZVN0YXJ0
ZXIuamF2YToxNzkpDQoJYXQgc3VuLnJlZmxlY3QuTmF0aXZlTWV0aG9kQWNj ZXNzb3JJbXBs
Lmludm9rZTAoTmF0aXZlIE1ldGhvZCkNCglhdCBzdW4ucmVmbGVjdC5OYXRp dmVNZXRob2RB
Y2Nlc3NvckltcGwuaW52b2tlKFVua25vd24gU291cmNlKQ0KCWF0IHN1bi5y ZWZsZWN0LkRl
bGVnYXRpbmdNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVua25vd24gU291 cmNlKQ0KCWF0
IGphdmEubGFuZy5yZWZsZWN0Lk1ldGhvZC5pbnZva2UoVW5rbm93biBTb3Vy Y2UpDQoJYXQg
b3JnLmVjbGlwc2UuZXF1aW5veC5sYXVuY2hlci5NYWluLmludm9rZUZyYW1l d29yayhNYWlu
LmphdmE6NTU5KQ0KCWF0IG9yZy5lY2xpcHNlLmVxdWlub3gubGF1bmNoZXIu TWFpbi5iYXNp
Y1J1bihNYWluLmphdmE6NTE0KQ0KCWF0IG9yZy5lY2xpcHNlLmVxdWlub3gu bGF1bmNoZXIu
TWFpbi5ydW4oTWFpbi5qYXZhOjEzMTEpDQoJYXQgb3JnLmVjbGlwc2UuZXF1 aW5veC5sYXVu
Y2hlci5NYWluLm1haW4oTWFpbi5qYXZhOjEyODcpDQoNCg==
--------------000102030803010306060308--
| Re: SWTbot and XMind [message #559289 is a reply to message #559175] |
Thu, 16 September 2010 05:35   |
Mariot Chauvin Messages: 174 Registered: July 2009 |
Hi Marek,
I assume this line throws the Exception : "final Control control = graphicalViewer.getControl();"
It means that in your case "editor.getAdapter(GraphicalViewer.class)" returns null, which is not expected.
Could you confirm this, or at least give me the version of SWTBot you use ?
Mariot
> Hi Mariot,
> Marek
>> Hi Marek,
>> Thanks,
>> Mariot
>>> Hi,
>>> Thanks for any help
>>> Marek.
>>> @BeforeClass
>>> @Test
>>> @AfterClass
>>> bot.sleep(2000);
| Re: SWTbot and XMind [message #630183 is a reply to message #559289] |
Thu, 30 September 2010 18:41  |
Hi Mariot.
I am so sorry I made you waiting for the response so long. I should have
done it earlier - sorry once again.
You were right. The method editor.getAdapter(GraphicalViewer.class)
returns null. I will let the XMind team know about this issue. Thanks a lot!
Sincerely,
Marek.
W dniu 2010-09-16 11:35, Mariot Chauvin pisze:
> Hi Marek,
> Mariot
>> Hi Mariot,
>> Regards,
>> Marek
>>> Hi Marek,
>>> Thanks,
>>> Mariot
>>>> Hi,
>>>> Thanks for any help
>>>> Marek.
>>>> @BeforeClass
>>>> @Test
>>>> @AfterClass
>>>> bot.sleep(2000);
FUDForum. Page generated in 0.01655 seconds
