Home » Modeling » TMF (Xtext) » Node Model outline
Node Model outline [message #558431] Sun, 12 September 2010 19:16 Go to next message
Ralf Ebert is currently offline Ralf EbertFriend
Member
I wrote a little plug-in that allows to see the node model:
http://www.ralfebert.de/blog/xtext/node_outline/
I hope I didn't reinvented the wheel here; if not, would you consider
this as contribution to Xtext? (the code needs to be polished and
cleaned up of course)
Ralf
Re: Node Model outline [message #558481 is a reply to message #558431] Mon, 13 September 2010 08:02 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Hi Ralf,
this looks nice. We're currently redesigning the outline and we will
allow multiple view points (outline trees) on the same model. One of
these could be your node view. But IMHO the node model is rather
technical so we might not want to activate it by default. To discuss
this further, would you open a bug?
Jan
Am 12.09.10 22:16, schrieb Ralf Ebert:
> Ralf
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Get professional support from the Xtext committers at www.typefox.io
Re: Node Model outline [message #558493 is a reply to message #558481] Mon, 13 September 2010 09:00 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
Seems to me the full node model outline is particularly useful if you need to do something with the hidden token streams -like with Ralf's indentation-aware languages.
Usually, visualizing the AST/semantic model would/should be enough and you can get that by opening the DSL instance with the "Sample Reflective Ecore Model Editor" or the "Generic EMF Editor" as well (see http://dslmeinte.wordpress.com/2010/09/06/tricks-for-impleme nting-scoping/, under "Visualizing the AST").
Re: Node Model outline [message #558715 is a reply to message #558481] Tue, 14 September 2010 08:05 Go to previous messageGo to next message
Member
> To discuss
325165: Node Model Outline
http://bugs.eclipse.org/325165
Re: Node Model outline [message #1007078 is a reply to message #558481] Mon, 04 February 2013 11:05 Go to previous messageGo to next message
Pawel Pogorzelski is currently offline Pawel PogorzelskiFriend
Member
Jan,
is it already released? I queried Bugzilla but couldn't find anything.
Jan Kohnlein wrote on Mon, 13 September 2010 04:02
Hi Ralf,
Re: Node Model outline [message #1007252 is a reply to message #1007078] Tue, 05 February 2013 09:28 Go to previous message
The node model outline has not made it into Xtext yet, but the bugzilla is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325165
Am 04.02.13 12:05, schrieb Pawel Pogorzelski:
> Jan,
>> Hi Ralf,
Previous Topic:Firing command after perspective is changed
Next Topic:Documentation View
Current Time: Tue Jun 19 01:07:55 GMT 2018
Powered by FUDForum. Page generated in 0.02172 seconds
