Home » Language IDEs » CDT » Wierd console behaviour for C projects.(Input, then prompts?)
Wierd console behaviour for C projects. [message #558210] Fri, 10 September 2010 10:16 Go to next message
Devon Bain is currently offline Devon Bain
So I have an interesting problem with Eclipse Galileo. I use it for Java, C++ and C programming. The first two work flawlessly: everything runs just like it should. C is where I have issues.
1.) I can't ever get it to build a binary, ever. So I've taken to using the included HelloWorld.c template and building whatever I'm doing off of that. If I use the template, everything works. If I don't, it can't build a binary. I have no idea why. C++ projects build just fine.
2.) When running C programs, it will take ALL input for the entire program (I've just been building simple stuff) BEFORE it displays any text at all. This is making it exceptionally difficult to debug my code. How do I get it to run like it does in the actual console, i.e. text, prompt, entry, execute?
Thank you all in advance, I appreciate any help you can give me. This is the first time I've really coded C, but I've developed in Java , VB and C++ for years and been using Eclipse for about a year - something I'd like to continue doing, since the other C IDEs really, really suck.
Again, my thanks!
Devon
Re: Wierd console behaviour for C projects. [message #558243 is a reply to message #558210] Fri, 10 September 2010 12:01 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
Does this help http://wiki.eclipse.org/CDT/User/FAQ#Eclipse_console_does_no t_show_output_on_Windows
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Wierd console behaviour for C projects. [message #558265 is a reply to message #558243] Fri, 10 September 2010 13:04 Go to previous messageGo to next message
Sadly, no. I see output just fine, let me see if I can make this clearer.
If I have a main with the following code:
Int main ()
{ int input;
Printf("press y then enter");
Scanf("%c", &input);
return 0;}
Then the console output in Eclipse will be blank until I enter a character and press return, at which point it will display the printf() and finish. It doesn't matter what order I list anything in, if I have it nested in a called function, whatever. The scanf functions of the entire program have to have input before ANY output is generated in console.
And I have no idea why.
Re: Wierd console behaviour for C projects. [message #558266 is a reply to message #558210] Fri, 10 September 2010 13:11 Go to previous messageGo to next message
No real name is currently offline No real name
You didn't actually capitalize the Printf, Scanf, and Int did you?
[Updated on: Fri, 10 September 2010 13:11]
Report message to a moderator
Re: Wierd console behaviour for C projects. [message #558267 is a reply to message #558266] Fri, 10 September 2010 13:15 Go to previous messageGo to next message
No. I'm replying on my mobile and it likes to capitalize every new line. I just wanted to give some sort of reference point for visualization purposes.
Re: Wierd console behaviour for C projects. [message #558308 is a reply to message #558265] Fri, 10 September 2010 20:27 Go to previous message
David Wegener is currently offline David Wegener
> Int main ()
> { int input;
> return 0;}
This is precisely the behavior that the FAQ referenced by Alex refers.
Follow the suggestions in the FAQ.
Previous Topic:Editor does not recognize some include files
Next Topic:printf and scanf behave poorly in Eclipse 3.5 on Windows
Current Time: Thu Jun 20 08:36:28 EDT 2013
Powered by FUDForum. Page generated in 0.02325 seconds
