Home » Eclipse Projects » Buckminster » An internal error occurred during: "Refreshing external folders"
An internal error occurred during: "Refreshing external folders" [message #558153] Fri, 10 September 2010 11:15 Go to next message
Thorsten Meinl is currently offline Thorsten MeinlFriend
Member
Hi all,
After upgrading to the latest headless Buckminster I'm getting errors
such as
ERROR: An internal error occurred during: "Refreshing external folders".
org.eclipse.jdt.internal.core.ExternalFoldersManager$Refresh Job.run(ExternalFoldersManager.java:387)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
when building in Hudson. This looks identical to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321358
However, this bug is about Eclipse 3.7 so I'm wondering why I'm getting
the error with 3.6? Also Buckminster the build inside the Eclipse IDE
(3.6.0) still works fine.
Thorsten
Re: An internal error occurred during: "Refreshing external folders" [message #558157 is a reply to message #558153] Fri, 10 September 2010 11:22 Go to previous messageGo to next message
Member
More info on this: I have an older headless Buckminster that is working
and the important difference seems to be
org.eclipse.jdt.core_3.6.0.v_A58.jar vs.
org.eclipse.jdt.core_3.6.1.v_A66_R36x.jar
Re: An internal error occurred during: "Refreshing external folders" [message #558315 is a reply to message #558153] Sat, 11 September 2010 06:31 Go to previous messageGo to next message
Peter Kullmann is currently offline Peter KullmannFriend
I have the same errors from time to time but I think the builds are
still ok. I didn't investigate further because I have no external
folders (I think). What are external folders anyway?
Peter
Thorsten Meinl schrieb:
> Hi all,
> such as
> java.lang.NullPointerException
> at
> Cheers,
> Thorsten
Re: An internal error occurred during: "Refreshing external folders" [message #558334 is a reply to message #558315] Sat, 11 September 2010 09:52 Go to previous messageGo to next message
Member
Am 11.09.2010 08:31, schrieb Peter Kullmann:
External folders are used if you let Hudson checkout the sources and let
Buckminster import these projects via an appropriate CQUERY.
Unfortunately, in my case these error messages also prevent the
workspace from being built, so it's a more serious problem.
I worked around the problem by first installing org.eclipse.jdt.core in
version 3.6.0 into headless Buckminster and after that
org.eclipse.buckminster.pde.feature. This works because the latter
depends on a version range of jdt. The faulty 3.6.1-version is installed
because the Buckminster-US ships it.
Thorsten
Re: An internal error occurred during: "Refreshing external folders" [message #633748 is a reply to message #558334] Tue, 19 October 2010 08:58 Go to previous message
Silvano is currently offline SilvanoFriend
I had the same issue too after the most recent Eclipse update. I started refreshing my projects one by one until I found the one which was raising the NPE, Closing and reopening the proj resolved the problem in my case.
Silvano
Previous Topic:URL parse doesn't find link?
Next Topic:NPE in P2Materializer
Current Time: Mon Apr 23 21:41:09 GMT 2018
Powered by FUDForum. Page generated in 0.02415 seconds
