Home » Language IDEs » ServerTools (WTP) » Extending the Annotation Properties view
Extending the Annotation Properties view [message #557789] Wed, 08 September 2010 22:09 Go to next message
Brian Fitzpatrick is currently offline Brian FitzpatrickFriend
Hi all wise and powerful WTP developers...
We recently discovered the cool Annotation Properties view
(org.eclipse.jst.ws.internal.jaxws.ui.views.AnnotationsView) and would
like to use/extend it for annotations other than JAX-WS.
Is there any way to extend/modify this view so that it recognizes other
annotation types? Eventually it would be great to add JAX-RS
annotations, which we'd like to have at some point. But obviously web
services isn't the only area that would benefit from a common UI for
adding/modifying annotations.
Thanks in advance for any info!
--Fitz
Re: Extending the Annotation Properties view [message #558031 is a reply to message #557789] Thu, 09 September 2010 20:52 Go to previous messageGo to next message
Shane Clarke is currently offline Shane ClarkeFriend
Member
Hi Brian
Brian Fitzpatrick wrote on Wed, 08 September 2010 23:09
annotation types?
Yes there is. Unfortunately there is no tutorial on how to do this at the moment.
But the extension points are documented in the JAX-WS Tools User Guide and JAX-WS tools ships with two plug-ins that serve as examples on how to consume those extension points.
Have a look at the org.eclipse.jst.ws.annotations.core.annotationCategory
& org.eclipse.jst.ws.annotations.core.annotationDefinition extension points.
and the org.eclipse.jst.ws.jaxws.core and org.eclipse.jst.ws.jaxb.core plug-ins.
Basically define your annotation category and your annotation definitions.
Ensure the annotations are on the plug-ins classpath.
And add the following to your plug-ins MANIFEST.MF
Eclipse-RegisterBuddy: org.eclipse.jst.ws.annotations.core
Once installed or running in a runtime workspace create a Java based project that has the annotations you wish to use on it's classpath and open the annotation properties view.
You can then filter the view by category to only display the annotations you are interested in.
Let me know if you have any questions or need any help.
Shane
Re: Extending the Annotation Properties view [message #558206 is a reply to message #558031] Fri, 10 September 2010 13:53 Go to previous messageGo to next message
Thanks for the info Shane, I'll give it a shot! :)
--Fitz
Shane Clarke wrote:
> Hi Brian
>> other annotation types?
> the moment.
> points.
> plug-ins.
> Shane
Re: Extending the Annotation Properties view [message #558680 is a reply to message #558031] Mon, 13 September 2010 21:49 Go to previous message
Hey Shane,
Just wanted to let you know I wrote a blog post about extending the view
and have some suggestions... If I get a chance, I'll create two or three
bugzillas and see if I can maybe get a patch together.
Here's the post:
http://community.jboss.org/en/jbosstools/blog/2010/09/13/ext ending-the-eclipse-annotation-properties-view
Thanks for the help!
--Fitz
Shane Clarke wrote:
> Hi Brian
> the moment.
> points.
> plug-ins.
> Shane
Previous Topic:XML Catalog and validation
Next Topic:Is there a way to extend the Web Editor for RCP
Current Time: Tue Jan 16 17:14:09 GMT 2018
Powered by FUDForum. Page generated in 0.02003 seconds
