Re: Outline refresh question [message #631243 is a reply to message #631220] |
Wed, 06 October 2010 16:16 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Henrik,
yes that would be very helpful (with you hack attached). Please log
other issues that you had with the Save As impl as well.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 06.10.10 17:07, schrieb Henrik Lindberg:
> Any input ?
> Should I just go ahead and log an issue?
> - henrik
> On 10/6/10 3:04 AM, Henrik Lindberg wrote:
>> On 8/28/10 11:05 PM, Sebastian Zarnekow wrote:
>>> Hi Henrik,
>>> you could try to make
>>> org.eclipse.xtext.ui.editor.outline.XtextContentOutlinePage. refresh()
>>> public and obtain the outline-page from the editor via
>>> editor#getAdapter(IContentOutlinePage.class).
>> I got that working fine for the root node change. I later discovered
>> that the outline page stops refreshing after a "save as" because the
>> outline page continues to listen to "the old model".
>> Hacking around this was not easy because it was not possible to just
>> create an alternative implementation and bind with guice as the toolbar
>> configurer used expects an instance of XtextContentOutlinePage - I was
>> not sure if I should just replace that as well, but it seemed quicker to
>> just hack up a solution (as I by that time understood what was going on
>> in the outline page).
>> I ended up with a class derived from XtextContentOutlinePage that
>> overrides everything (just to make it work as an equivalent
>> replacement), and then adding:
>> * Special method that should be called from performSavedAs
>> public void externalRefresh() {
>> // Must drop old listener (should ideally get rid of the listener, but
>> since the document changed already (??)
>> // it will probably not unregister for the correct document.
>> modelListener = null;
>> // Install a model listener for the current document
>> installModelListener();
>> refresh();
>> This was the only way I could figure out to reset the (private)
>> modelListener.
>> At first I thought I would need to hang on to the xtextDocument (so I
>> could unregister using the correct instance, but that is probably bad as
>> it then holds on to that object. My hack seems to work - but may have
>> some other surprises in store...
>> Since the outline management things are changing, I don't know how to go
>> from here - log an issue? Attatch my hacked class? or just describe the
>> issue.
>> Regards
>> - henrik
FUDForum. Page generated in 0.04603 seconds
