Home » Modeling » Papyrus » UML class diagram generation to java
UML class diagram generation to java [message #555219] Wed, 25 August 2010 22:04 Go to next message
Alexander  is currently offline Alexander Friend
An old version of papyrus project had the add-ins with the code generators including java generator.
How can we generate java code from the UML class diagram?
Do the papyrus have an technology to reengineer java code to papyrus UML class diagram?
Do the papyrus team have in plans such both engineer / reengineer methods?
[Updated on: Wed, 25 August 2010 22:06]
Report message to a moderator
Re: UML class diagram generation to java [message #731837 is a reply to message #555219] Mon, 03 October 2011 09:21 Go to previous messageGo to next message
Federico Tomassetti is currently offline Federico TomassettiFriend
I am looking to an answer for this one. Still nothing?
Re: UML class diagram generation to java [message #758946 is a reply to message #731837] Fri, 25 November 2011 11:23 Go to previous message
Cedric Dumoulin is currently offline Cedric DumoulinFriend
Member
We have plugins to generate Java code and to reverse Java code.
These plugins are experimentals, and can/should be improved. But they
work well for our purpose (reverse Papyrus, generate class skeletons),
and I suppose they should also work for you.
They are available in the Papyrus svn and also as an update site
svn:
svn+ssh://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/extraplugins/java
updatesite:
http://www.lifl.fr/~dumoulin/papyrus-update/org.eclipse.papyrus.java-updatesite/
Hope this help,
Cedric
Previous Topic:Load resuorce
Next Topic:How to model a provided/required connexion with SoaML
Current Time: Sat Apr 21 12:03:44 GMT 2018
Powered by FUDForum. Page generated in 0.01922 seconds
