| Connection profile store location [message #554420] |
Mon, 23 August 2010 01:15  |
Kavitha Messages: 10 Registered: August 2010 |
Junior Member |
Dear friends,
I am designing reports on Windows and for development purpose we are just using
Run --> View Report ->In WebWiewer/PDF for testing.For each report we are creating data source with db connection.When we changed db for production.Now I have to change in all my reports to modify the connection information in them.
So hard coding connection info in rptdesign file seems to be bad idea and I want to change this by the way.So I created Connection profile XML and using this file in data source Connection Profile.
In my rptdesign file, XML source shows
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc.dbprofile " name="SampleDS" id="2178">
<list-property name="privateDriverProperties">
<ex-property>
<name> org.eclipse.datatools.connectivity.oda.profile.db.provider.i d </name>
<value>org.eclipse.datatools.enablement.oracle.connectionProfile </value>
</ex-property>
</list-property>
<property name="OdaConnProfileName">New Oracle(0)</property>
<property name="OdaConnProfileStorePath">D:\workspace\reports\WebContent\Oracle_Profile </property>
</oda-data-source>
</data-sources>
how to change OdaConnProfileStorePath to relative path?
While googling i got something like The Javascript expression can refer to a BIRT config[] variable. For
example,
config[ "birt.viewer.working.path" ] + "../../data/myData.csv" .When i gave this script in data source --> property binding --> connection profile store url.I got some error like ,
+ Error evaluating Javascript expression. Script engine error: birt.viewer.resource.path not found
Script source: <inline>, line: 0, text:
config[ "birt.viewer.resource.path" ] + "/Oracle_Profile"
Please Provide me steps what should I do to be able to use this file by my reports? Please Help me i am in crucial stage.
Kavitha
[Updated on: Mon, 23 August 2010 01:17] Report message to a moderator
| Re: Connection profile store location [message #554594 is a reply to message #554420] |
Mon, 23 August 2010 12:06   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
You can set the location also in the beforeOpen script of the dataset like:
this.setExtensionProperty("OdaConnProfileStorePath",
"c:/work/styles/mysqlclassic.txt");
To make it relative use a combination of these scripts:
var rp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getRealPath( "/MyConnectionProfiles");
if( rp != null ){
this.setExtensionProperty("OdaConnProfileStorePath",rp);
You can get an init parameter like:
var mrp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getInitParameter( "BIRT_RESOURCE_PATH");
Jason
On 8/23/2010 1:15 AM, Kavitha wrote:
> Dear friends,
> just using
> <data-sources>
> <oda-data-source
> name="SiteMonVisitsDS" id="2178">
> <ex-property>
> </name>
> </ex-property>
> </list-property>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> example,
> Kavitha
Jason Weathersby
BIRT Exchange
| Re: Connection profile store location [message #556962 is a reply to message #554420] |
Fri, 03 September 2010 07:29   |
Junior Member |
I don't know why its not working for me or i am doing some thing wrong.
Come to dynamic data source creation,
I have created a JDBC data source & given default development db and in the report beforeFactory i given like,
importPackage(Packages.java.util.Properties);
importPackage(Packages.java.io);
ds = reportContext.getDesignHandle().getDesign().findDataSource("Data Source");
property = new Properties();
property.load(new FileInputStream(reportContext.getDesignHandle().getResourceF older()+ "/Oracle_Profile"));
ds.setProperty( "odaDriverClass",property.getValue("odaDriverClass"));
ds.setProperty( "odaURL", property.getValue("odaURL"));
ds.setProperty( "odaUser", property.getValue("odaUser"));
ds.setProperty( "odaPassword", property.getValue("odaPassword"));
reportContext.getDesignHandle().getDesign().add(ds);
In while running report at run time i am reading from property file which has different db property.I am getting exceptions like below,
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "importPackage(Packages.java.util.Properties); importPackage(Packages.java.io); ds = reportContext.getDesignHandle().getDesign().findDataSource("Data Source"); property = new Properties(); property.load(new FileInputStream(reportContext.getDesignHandle().getResourceF older()+ "/Oracle_Profile")); ds.setProperty( "odaDriverClass",property.getValue("odaDriverClass")); ds.setProperty( "odaURL", property.getValue("odaURL")); ds.setProperty( "odaUser", property.getValue("odaUser")); ds.setProperty( "odaPassword", property.getValue("odaPassword")); ": Function importPackage must be called with a package; had "[JavaClass java.util.Properties]" instead. (/report/method[@name="beforeFactory"]#1)
what could be the problem??????
Thank you,
Kavitha
| Re: Connection profile store location [message #557015 is a reply to message #556962] |
Fri, 03 September 2010 11:25   |
This line:
should be
importPackage(Packages.java.util);
Jason
On 9/3/2010 7:29 AM, Kavitha wrote:
> Source");
> property.load(new
> Thank you,
> Kavitha
Jason Weathersby
BIRT Exchange
| Re: Connection profile store location [message #557201 is a reply to message #554420] |
Mon, 06 September 2010 00:55   |
Junior Member |
Hi Jason,
I am getting some exception like below,
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc. org.eclipse.birt.report.data.oda.jdbc.JDBCException: Missing properties in Connection.open(Properties).
What could be the problem?
I created data source and i am using dev mode connections. before factory method of design i am reading connections from property file for production mode connections.
i have added one table and while executing i am getting above exception.
I am having few doubts about connection profile property binding please can you clear it.
1.While creating connection profile data source by default we need to give connection file name with out giving default connection file data source will not get created. how can i change it to accept dynamic file name.
[Updated on: Mon, 06 September 2010 06:46] Report message to a moderator
| Re: Connection profile store location [message #557460 is a reply to message #557201] |
Tue, 07 September 2010 09:54  |
I did not see where you set the
OdaConnProfileStorePath property in your script.
Jason
On 9/6/2010 12:56 AM, Kavitha wrote:
> Hi Jason,
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.02444 seconds
