Home » Eclipse Projects » Buckminster » Having cspec and cspex in one feature
Having cspec and cspex in one feature [message #554268] Fri, 20 August 2010 16:41 Go to next message
Alex Kravets is currently offline Alex Kravets
I followed bucky book to create legacy update site project - everything works. My question is, is it possible to incorporate cspec from update site project to another project that includes cspex? I tried copying cspec, index.html and site.xml to my other project but get error that site.p2 could not be found, renaming from buckminster.cspec to another name stopped the error, but when I bring up actions in the project I don't site build.site action.
How does buckminster know for example to make build.site available in the update site project and not in another that contains cspec and updated .project properties that includes update site nature (not sure if .project is important here though)?
I am not sure what I did is correct or allowed, was just trying different things to make this work.
thanks,
Alex
Re: Having cspec and cspex in one feature [message #554277 is a reply to message #554268] Fri, 20 August 2010 17:17 Go to previous message
Henrik Lindberg is currently offline Henrik Lindberg
Buckminster generates actions based on the component type and the meta
data it discovers. You can see what is generated per component type in
the reference section of the Bucky Book (or just view the cspec for a
component).
Any component with a generated cspec can have a cspex that "decorates"
the generated specification. In a component of type "buckminster"
everything is placed in the cspec manually (and a cspex is superfluous
in this case).
The rmap is the starting point - it is here buckminster is told how it
should find, discover and generate a cspec given a name, type, and
version of a component.
- henrik
On 8/20/10 10:41 PM, Alex wrote:
> don't site build.site action. How does buckminster know for example to
> thanks,
> Alex
Previous Topic:org.eclipse.jdt.core issue - groovy support
Next Topic:materializing a component: ".bundle" not found.....
Current Time: Sat May 25 11:48:14 EDT 2013
Powered by FUDForum. Page generated in 0.01420 seconds
