Home » Eclipse Projects » BIRT » connecting to kdb
connecting to kdb [message #553399] Tue, 17 August 2010 08:16 Go to next message
ivan  is currently offline ivan
I want to connect to a kdb database but having no luck.
KDB offers both web based connection or jdbc but I can't get it working either. So far I have downloaded jdbc.jar from kx but I get the following error:
Could not connect to asd.
Error creating ODA Connection Factory connection to asd. (Error: There is an error in get connection, No suitable driver found for jdbc:kx://t[hostnae]:[port].)
There is an error in get connection, No suitable driver found for jdbc:kx://[hostname]:[port].
I guess that my connection string is bad or else the jdbc.jar is not the correect one...
Anyway please share with me how I can connect to a kdb database.
Thank you!
Re: connecting to kdb [message #553536 is a reply to message #553399] Tue, 17 August 2010 16:28 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Can you check to verify that the jdbc.jar driver is actually copied to
the designer's
plugins/org.eclipse.birt.report.data.oda.jdbc_version/driver s directory.
I am not familiar with KDB but do you not have to put the db in the url
like this:
jdbc:mysql://localhost/mydb
Jason
> following error:
> correect one...
> Thank you!
Jason Weathersby
BIRT Exchange
Re: connecting to kdb [message #553553 is a reply to message #553536] Tue, 17 August 2010 19:44 Go to previous messageGo to next message
Jason, thank you for the reply. I have checked that the driver is indeed copied as follows:
Directory of C:\Program Files\eclipse\plugins\org.eclipse.birt.report.data.oda.
jdbc_2.6.0.v20100524\drivers
17/08/2010 08:20 PM <DIR> .
17/08/2010 08:20 PM <DIR> ..
17/08/2010 08:20 PM 41,358 jdbc.jar
13/08/2010 09:53 AM 173,714 nzjdbc.jar
12/08/2010 11:59 PM 1,996,228 ojdbc5.jar
13/08/2010 08:12 AM 2,111,220 ojdbc6.jar
09/06/2010 08:07 PM 80 readme.txt
Also, I had the connection string from the below site:
http://www.kx.com/a/kdb/connect/jdbc/jdbc.txt
> jdbc:kx://host[:port] ('kx' is a registered sub-domain.)
Re: connecting to kdb [message #553747 is a reply to message #553553] Wed, 18 August 2010 12:11 Go to previous messageGo to next message
Where do you specify the db at?
Jason
> copied as follows:
Jason Weathersby
BIRT Exchange
Re: connecting to kdb [message #725521 is a reply to message #553747] Thu, 15 September 2011 00:49 Go to previous message
bvinnu is currently offline bvinnu
just to check if this has been resolved and if YES , can you please advise on the steps please
Previous Topic:Chart engine: load XML file
Next Topic:How to save report to excel or pdf silently in server or client PC
Current Time: Sat May 18 14:36:43 EDT 2013
Powered by FUDForum. Page generated in 0.07658 seconds
