| can't install m2eclipse on Helios [message #553215] |
Mon, 16 August 2010 13:09  |
Adam Monsen Messages: 8 Registered: March 2010 |
Junior Member |
I'm using Helios 20100617-1415 (64-bit Java EE version). When I try to install the Maven Integration plugin, I get:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,ch.qos.logback.classic,0.9.19.v20100519-1505
No repository found containing: osgi.bundle,ch.qos.logback.core,0.9.19.v20100419-1216
No repository found containing: osgi.bundle,ch.qos.logback.slf4j,0.9.19.v20100519-1910
No repository found containing: osgi.bundle,org.eclipse.net4j.jms.api,3.0.0.v20100614-1655
No repository found containing: osgi.bundle,org.eclipse.zest.core,1.2.0.v20100525-1225
No repository found containing: osgi.bundle,org.eclipse.zest.layouts,1.1.0.v20100616-1515
No repository found containing: osgi.bundle,org.slf4j.api,1.5.11.v20100519-1910
Any ideas?
Platform: Ubuntu 10.04, 64-bit
$ java -version
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
| I have a similar problem [message #635721 is a reply to message #635563] |
Wed, 27 October 2010 16:10  |
Ezequiel Messages: 1 Registered: October 2010 |
Junior Member |
Hello!
I'm new at Eclipse Forums, and I've came here because of the same problem.
I'm using Eclipse Helios (64 bit) on Windows 7, but I cannot perform the installation of M2Eclipse. The message I get is the following:
Cannot complete the install because one or more required items could not be found.
Software being installed: Maven Integration for Eclipse (Required) 0.10.2.20100623-1649 (org.maven.ide.eclipse.feature.feature.group 0.10.2.20100623-1649)
Missing requirement: Maven Integration for Eclipse (Required) 0.10.2.20100623-1649 (org.maven.ide.eclipse.feature.feature.group 0.10.2.20100623-1649) requires 'org.eclipse.emf.ecore 0.0.0' but it could not be found
It seems a bit strange that the installation requires org.eclipse.emf.ecore 0.0.0 (why that version?).
I've been looking for a place to find that requirement, but I couldn't.
Do you know where I can find that requirement, or if there is any other solution to this problem?
Thank you!
FUDForum. Page generated in 0.01591 seconds
