Re: How to find which version of Java Eclipse is running under? [message #552041 is a reply to message #552038] |
Tue, 10 August 2010 15:26 |
On 8/10/2010 9:22 AM, ysa wrote:
> HI, How to find which version of Java Eclipse is running under? Is it
> possible to set any different one? Thank you in advance,
> YSA
What is "Java Eclipse"? Java is Java, Eclipse is Eclipse. Eclipse runs
on Java and its version is obtained by Help -> About Eclipse Platform.
The version of Java you're running depends on what you installed prior
to installing and running Eclipse. If you just let Eclipse run on
whatever JRE is installed on your computer host, you haven't chosen
well. Install a proper JDK, whose version you will obviously know since
you're installing it on purpose, then run Eclipse on that.
For more information, please see the first few articles under the
"Eclipse-oriented" menu at http://www.javahotchocolate.com
Hope this helps.
FUDForum. Page generated in 0.09194 seconds
