Home » Eclipse Projects » Eclipse 4 » Databinding: tableviewer does not refresh automatically
Databinding: tableviewer does not refresh automatically [message #551959] Tue, 10 August 2010 10:06 Go to next message
Mo P. is currently offline Mo P.Friend
there are two employees in the TableViewer_MasterDetail_Edit test from package e4.xwt.tests.jface.tableviewer.master.detail.
When I select one in the table, his name is displayed in the text field. When I change the text in the textfield, the objects attribute changes obviously (because when I deselect the employee and then select it again, the name in the text field is changed) but the text of the tableitem doesn't change at all. I think it is not refreshing properly.
Thank you very much for all your help
Moritz
Re: Databinding: tableviewer does not refresh automatically [message #551975 is a reply to message #551959] Tue, 10 August 2010 11:07 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANGFriend
Please fill a bug. Thanks for the report.
Best regards
Yves YANG
"Mo P." <moritzpavlik@gmx.de> wrote in message
news:i3r8aa$f0p$1@build.eclipse.org...
> Hello,
> Regards
> Moritz
Re: Databinding: tableviewer does not refresh automatically [message #551990 is a reply to message #551959] Tue, 10 August 2010 12:39 Go to previous messageGo to next message
bug report has been created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=322221
thanks a lot for your replies.
you want me to file a bug everytime I discover such things?
often i'm not sure if its a bug or wanted Wink
Re: Databinding: tableviewer does not refresh automatically [message #552481 is a reply to message #551990] Thu, 12 August 2010 10:57 Go to previous message
If you have a problem and it is identified, you can submit a bug directly
with a descritpion and a testcase. Otherwise, post your questions here.
best regards
Yves YANG
news:i3rha4$vfd$1@build.eclipse.org...
> often i'm not sure if its a bug or wanted ;)
Re: Databinding: tableviewer does not refresh automatically [message #580635 is a reply to message #551990] Thu, 12 August 2010 10:57 Go to previous message
best regards
Yves YANG
Previous Topic:Where's the best place to start with e4?
Next Topic:PartSashContainer: Children
Current Time: Mon Jun 25 02:47:06 GMT 2018
Powered by FUDForum. Page generated in 0.02021 seconds
