Home » Eclipse Projects » Eclipse Platform » Error "org.eclipse.jface"
Error "org.eclipse.jface" [message #551932] Tue, 10 August 2010 08:44 Go to next message
Matt Rossner is currently offline Matt RossnerFriend
I keep getting this error in my .log
!ENTRY org.eclipse.jface 4 2 2010-08-10 10:37:22.148
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.IllegalArgumentException
at org.eclipse.jdt.internal.core.util.Util.scanTypeSignature(Ut il.java:2710)
at org.eclipse.jdt.core.Signature.getReturnType(Signature.java: 1644)
at org.eclipse.jdt.core.Signature.getReturnType(Signature.java: 1657)
at org.eclipse.jdt.internal.ui.viewsupport.JavaElementLabelComp oser.appendMethodLabel(JavaElementLabelComposer.java:461)
at org.eclipse.jdt.internal.ui.viewsupport.JavaElementLabelComp oser.appendElementLabel(JavaElementLabelComposer.java:236)
at org.eclipse.jdt.ui.JavaElementLabels.getElementLabel(JavaEle mentLabels.java:521)
at org.eclipse.jdt.ui.JavaElementLabels.getStyledElementLabel(J avaElementLabels.java:496)
at org.eclipse.jdt.ui.JavaElementLabels.getStyledTextLabel(Java ElementLabels.java:424)
at org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getStyledText(JavaUILabelProvider.java:178)
at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider. getStyledText(DelegatingStyledCellLabelProvider.java:195)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider. getStyledText(DecoratingStyledCellLabelProvider.java:192)
at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider. update(DelegatingStyledCellLabelProvider.java:103)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider. update(DecoratingStyledCellLabelProvider.java:134)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at org.eclipse.jface.viewers.StructuredViewer.internalUpdate(St ructuredViewer.java:2094)
at org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:2033)
at org.eclipse.jface.viewers.ColumnViewer.update(ColumnViewer.j ava:554)
at org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:1977)
at org.eclipse.jface.viewers.StructuredViewer.handleLabelProvid erChanged(StructuredViewer.java:1140)
at org.eclipse.jdt.internal.ui.viewsupport.ProblemTreeViewer.ha ndleLabelProviderChanged(ProblemTreeViewer.java:214)
at org.eclipse.jface.viewers.ContentViewer$1.labelProviderChang ed(ContentViewer.java:97)
at org.eclipse.jface.viewers.BaseLabelProvider$1.run(BaseLabelP rovider.java:74)
at org.eclipse.jface.viewers.BaseLabelProvider.fireLabelProvide rChanged(BaseLabelProvider.java:72)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider$ 1.labelProviderChanged(DecoratingStyledCellLabelProvider.jav a:77)
at org.eclipse.ui.internal.decorators.DecoratorManager$1.run(De coratorManager.java:430)
at org.eclipse.ui.internal.decorators.DecoratorManager.fireList ener(DecoratorManager.java:428)
at org.eclipse.ui.internal.decorators.DecorationScheduler$3.run InUIThread(DecorationScheduler.java:530)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Every time it happens I get a modal dialog in the IDE and I have to stop working and close it. It doesn't seem to affect anything but it stops my productivity. I'd like to resolve this.
Not sure if this is the right forum as I'm using WTP but it seems like a platform issue.
Version is:
Eclipse Java EE IDE for Web Developers.
Build id: 20090920-1017
We have a standard Eclipse here that everyone uses so I can't update to a later version.
Re: Error "org.eclipse.jface" [message #551939 is a reply to message #551932] Tue, 10 August 2010 08:59 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
It looks like a JDT-Problem - JFace is only catching the Exception but
is not the reason for it and it has to do with the ProblemView probably.
Tom
Am 10.08.10 10:44, schrieb Matt Rossner:
> !STACK 0
> il.java:2710)
> java:145)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> Viewer.java:2033)
> ava:554)
> Viewer.java:1977)
> rovider.java:74)
> onizer.java:134)
> a:3855)
> a:2405)
> (Realm.java:332)
> bench.java:493)
> ava:149)
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> platform issue.
> Version is:
> a later version.
Re: Error "org.eclipse.jface" [message #551951 is a reply to message #551939] Tue, 10 August 2010 09:25 Go to previous message
I restarted Eclipse with -clean and for now it seems to have fixed the problem.
Previous Topic:Selection dialogs initially empty
Next Topic:change text hover style
Current Time: Sat May 26 11:58:44 GMT 2018
Powered by FUDForum. Page generated in 0.01685 seconds
