Home » Language IDEs » C / C++ IDE (CDT) » GDB Debugger hangs on Debug starting(GDB Debugger does not start and hangs on some point.)
GDB Debugger hangs on Debug starting [message #551594] Sat, 07 August 2010 19:39 Go to next message
Munim Abdul is currently offline Munim AbdulFriend
I downloaded Eclipse for C++ v 3.6 32-bit version on my WIndows 7 64-bit OS.
I can build and run my code, but I cannot debug.
I am using MingW32 compiler v5.1.6 with GDB v7.1 .
When try to "debug" my application, the progress tab shows "Launching: Configuraing GDB" at 86% for infinite time. The stop button beside the progress bar does not work where says "Cancel Requested".
With thanks and regards,
Munim
Re: GDB Debugger hangs on Debug starting [message #551596 is a reply to message #551594] Sat, 07 August 2010 20:17 Go to previous message
Problem fixed. MinGW\bin folder did not have the file libexpat-1.dll for some reason. Downloaded the file from here and extracted to MinGW\bin and everything working smoothly Smile
Previous Topic:Strange indexer issue
Next Topic:Arranging Build targets
Current Time: Mon Jan 22 12:36:48 GMT 2018
Powered by FUDForum. Page generated in 0.02064 seconds
