Project Open event not getting fired - wrong flag for IResourceDelta.getFlags() [message #551469] |
Fri, 06 August 2010 14:42 |
Rahul Kamdar Messages: 63 Registered: July 2009 |
Member |
I'll first provide a brief description of my code:
After each project open (POST_BUILD) I need to run some code so I have added my Resource Change Listener. The resource delta is filtered to be checked only if:
1] resourceDelta.getResource is a project
2] resourceDelta.getFlags() == iResourceDelta.OPEN
3] if project.isOpen()
This works as expected for all cases except for one case that I have encountered now.
I have a project checked out from a Serena Dimensions CM Repository (Team / RCS). This project when closed and re-opened, *only* in this first project close-reopen the event fired and checked results in resourceDelta.getFlags() = 81920.
If I close the project again and reopen it the problem doesn't occur, the right events are fired.
I have spent a good amount of time trying to figure out what's going different but no reason/solution identified yet. I'll appreciate any help/information.
The Eclipse version in question is 3.4. I checked the source code for Resource Delta and the value returned for getFlags = status & ~KIND_MASK. So the status for the 81920 returned value seems to be MOVED_TO while the values returned by resourceDelta.getMovedFromPath / resourceDelta.getMovedToPath = null.
Grateful for any pointers/help.
FUDForum. Page generated in 0.02563 seconds
