Home » Newcomers » Newcomers » Hibernate, Spring and Struts in Eclipse 3.6 (Helios)(Hibernate, Spring and Struts plugins for Eclipse 3.6 (Helios))
Hibernate, Spring and Struts in Eclipse 3.6 (Helios) [message #551313] Thu, 05 August 2010 17:38 Go to next message
Esh  is currently offline Esh
I am new to Eclipse, though not to Java.
I have downloaded Eclipse (3.6) Helios and have already executed some Java applications to make sure the IDE is working.
Now, I want to know which version of the plugins for:
a) Struts
b) Hibernate (I downloaded 3.5.4 final but it doesnt seem to work)
c) Spring
I need to download and place them where exactly (somewhere I read I should put the jars under <eclipse/plugins> folder ) for these to work.
Also, there is no <Software Updates> submenu under the Tools menu.
Please help.
Esh
Re: Hibernate, Spring and Struts in Eclipse 3.6 (Helios) [message #551320 is a reply to message #551313] Thu, 05 August 2010 19:31 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
On 2010.08.05 15:38, Esh wrote:
> Hello,
Welcome!
Congratulations!
> a) Struts
So, you're probably not new to Hibernate, however, I tackle it from an
Eclipse point of view in an article at
http://www.javahotchocolate.com/tutorials/hibernate.html I'll bet what
puzzles you is explained in there. Ignore the stupid bits of the article
and you're there.
> c) Spring
There are two ways of doing Spring. The first is to download the
plug-ins for Eclipse. I haven't done this, but I think it's the most
common and the most stable. More on plug-ins in a moment...
Second, you could download the SpringSource Tool Suite (STS) from
Spring. If you can get it set up just right, it's pretty cool. I find
that it's hard to get and set up a copy that is stable on either Linux
or Windows, though I haven't tried since the beginning of the year. At
this point, I'm not doing any Spring, but I expect that will change soon.
Always and only install new software (read: plug-ins) using Help ->
Install New Software. There is another option, using the dropins
subdirectory under eclipse, but that's a last-ditch thing to be avoided
as long as you can.
Probably because you were really looking for the Help -> Install New
Software or the Help -> Check for Updates menu items?
Re: Hibernate, Spring and Struts in Eclipse 3.6 (Helios) [message #551835 is a reply to message #551320] Mon, 09 August 2010 13:16 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
> as long as you can.
You might find it a little bit easier to use the Marketplace (Help >
Eclipse Marketplace) GUI to find and install what you're looking for.
It's a new feature in the Helios release, but is a little better for
discovering new plugins than the Install New Software UI.
Hope this helps,
Eric
Re: Hibernate, Spring and Struts in Eclipse 3.6 (Helios) [message #551858 is a reply to message #551313] Mon, 09 August 2010 15:30 Go to previous message
Thanks Russell and Eric.
Will try both the approaches and see.
Appreciate it.
Esh
Previous Topic:SWT error with PDE cheat sheet on OS X 10.6.3
Next Topic:Plug-ins not showing up
Current Time: Sat May 25 11:14:38 EDT 2013
Powered by FUDForum. Page generated in 0.02197 seconds
