Home » Modeling » EMF » How to save ecore model as xmi
How to save ecore model as xmi [message #551240] Thu, 05 August 2010 17:14 Go to next message
John Chen is currently offline John ChenFriend
I created ecore model based on xmi generated by a UML modeling tool (EA). I then edited the ecore model in Eclipse. How can I save the updated ecore model back to xmi so that the UML modeling tool can import the change? I tried to use "File -> Save As", but that only allows to save as .ecore or .emof file.
Thanks!
John
Re: How to save ecore model as xmi [message #551250 is a reply to message #551240] Thu, 05 August 2010 17:19 Go to previous messageGo to next message
John,
Comments below.
John Chen wrote:
Both ecore and emof are XMI representations so I'm not sure what you're
asking.
> Thanks!
> John
Re: How to save ecore model as xmi [message #551262 is a reply to message #551240] Thu, 05 August 2010 18:23 Go to previous messageGo to next message
Alex Mising name is currently offline Alex Mising nameFriend
Member
Assuming you went from UML to Ecore (and assuming you have good reasons to go back Wink), you'll have to convert it back to UML to get it in EA; e.g. "Export Model ..." from genmodel editor, or "Convert to UML Model ..." in the Sample Ecore Editor. The EA XMI Import should work on the resulting .uml file.
Alex
[Updated on: Thu, 05 August 2010 18:49]
Report message to a moderator
Re: How to save ecore model as xmi [message #551272 is a reply to message #551262] Thu, 05 August 2010 18:57 Go to previous message
Thank you, Alex and Ed. 'Sample Ecore Editor" is the right tool for this kind of job.
Cheers!
John
Previous Topic:[EMF] Create a model instance from a DynamicEObject
Next Topic:[CDO] Setting up CDO/Hibernate store with a Postgresql DB
Current Time: Sat Feb 24 01:03:37 GMT 2018
Powered by FUDForum. Page generated in 0.02238 seconds
