Home » Modeling » EMF » Package with uri 'null' not found ERROR(An error occured while i was reading a XML file into SymptomDatabase)
Package with uri 'null' not found ERROR [message #550646] Wed, 04 August 2010 02:54 Go to next message
No real name is currently offline No real nameFriend
My code is as below:
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
//import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.*;
import org.eclipse.hyades.models.symptom.SymptomPackage;
import org.eclipse.hyades.models.symptom.impl.*;
public class hello{
public static void main(String arg[]){
ResourceSet resourceSet = new ResourceSetImpl();
Resource.Factory.Registry registry = resourceSet.getResourceFactoryRegistry();
registry.getExtensionToFactoryMap().put("xml", new XMLResourceFactoryImpl());
SymptomPackage symPack = SymptomPackageImpl.init();
System.out.println(symPack.eNS_URI);
System.out.println(symPack.eINSTANCE);
EPackage.Registry reg = resourceSet.getPackageRegistry();
reg.put(symPack.getNsURI(), symPack);
System.out.println(symPack.getNsURI());
resourceSet.getResource(URI.createFileURI("d:\\symptomdb.xml "), true);
The error message is as below:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (file:/d:/symptomdb.xml, 52, 18)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at eclipseworld.tutorial.demo.analysis.engine.DemoSymptomDataba se.loadDatabase(DemoSymptomDatabase.java:329)
at eclipseworld.tutorial.demo.analysis.engine.DemoSymptomDataba se.merge(DemoSymptomDatabase.java:127)
at eclipseworld.tutorial.demo.analysis.engine.DemoSymptomDataba se.main(DemoSymptomDatabase.java:74)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (file:/d:/symptomdb.xml, 52, 18)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1307)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unkn own Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatc her.scanRootElementHook(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 4 more
The XML file is as below:
<!DOCTYPE symptomDatabase [
<!ELEMENT symptomDatabase (runtime+)>
<!ELEMENT runtime (symptom+ , solution+ , directive*)>
<!ATTLIST runtime
id ID #REQUIRED
name CDATA #IMPLIED
symptomUrl CDATA #IMPLIED
localExternalFileLocation CDATA #IMPLIED>
<!ELEMENT symptom (matchPattern+)>
<!ATTLIST symptom
id ID #REQUIRED
description CDATA #IMPLIED
solutions IDREFS #REQUIRED>
<!ELEMENT matchPattern EMPTY>
<!ATTLIST matchPattern
name CDATA #IMPLIED
value CDATA #REQUIRED>
<!ELEMENT solution EMPTY>
<!ATTLIST solution
id ID #REQUIRED
directives IDREFS #IMPLIED>
<!ELEMENT directive EMPTY>
<!ATTLIST directive
id ID #REQUIRED
directiveString CDATA #REQUIRED>
<!-- Created on Thursday, December 09, 2004 at 9:00:53:0315 PM EST -->
<!-- NOTE: Do not translate any content in this XML file. -->
<symptomDatabase>
<runtime id="Runtime_0" name="symptomDB" symptomUrl="http://www.eclipse.org" localExternalFileLocation="www.eclipse.org">
<!-- Symptoms: -->
<symptom id="Symptom_0" description="Could not determine server name" solutions="Solution_0">
<matchPattern name="null" value="httpd: Could not determine the server&apos;s fully qualified domain name"/>
</symptom>
<symptom id="Symptom_1" description="File does not exist" solutions="Solution_1">
<matchPattern name="null" value="File does not exist:"/>
</symptom>
<!-- Solutions: -->
<solution id="Solution_0" description="Add Severname &apos;servername&apos; to httpd.conf and enter the&#xD;&#xA;corresponding entry for &apos;servername&apos; in /etc/hosts file.&#xD;&#xA;&#xD;&#xA;Where &apos;servername&apos; is the name of your server." />
<solution id="Solution_1" description="Try reinstalling the apache server." directives="Directive_0"/>
<!-- Directives: -->
<directive id="Directive_0" description="Contact your local administrator." directiveString=""/>
</runtime>
</symptomDatabase>
Re: Package with uri 'null' not found ERROR [message #550647 is a reply to message #550646] Wed, 04 August 2010 02:56 Go to previous messageGo to next message
Why the package is with "null" uri? Where should i change the uri value? How can i fix the error?
[Updated on: Wed, 04 August 2010 07:50]
Report message to a moderator
Re: Package with uri 'null' not found ERROR [message #550873 is a reply to message #550646] Wed, 04 August 2010 13:37 Go to previous messageGo to next message
It's highly likely that the Symptom package has a specialized resource
factory Impl that you'll need to register.
> public class hello{
> LHandler.java:1468)
> Handler.java:1019)
> ndler.java:1001)
> ndler.java:712)
> nown Source)
> own Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 4 more
> <!ATTLIST runtime
> id ID #REQUIRED
> name CDATA #IMPLIED
> <!ATTLIST symptom
> id ID #REQUIRED
> name CDATA #IMPLIED
> <!ATTLIST solution
> id ID #REQUIRED
> <!ATTLIST directive
> id ID #REQUIRED
> <symptomDatabase>
> <!-- Symptoms: -->
> </symptom> <symptom id="Symptom_1" description="File
> exist:"/> </symptom>
> <!-- Solutions: -->
> </runtime>
> </symptomDatabase>
Re: Package with uri 'null' not found ERROR [message #550875 is a reply to message #550647] Wed, 04 August 2010 13:42 Go to previous messageGo to next message
The namespace of the root element is null, so the resource
implementation you've registered will look for a package registered for
the null nsURI. That's why I expect there's a specialized resource
factory you'll need to use. If you can't find it, ask on the TPTP
newsgroup where it is.
> Why the package is with "null" uri? How can i fix the error?
Re: Package with uri 'null' not found ERROR [message #551048 is a reply to message #550873] Thu, 05 August 2010 02:34 Go to previous messageGo to next message
Thanks for your help. But still i don't know where and how to register a factory. I printed the nsURI out, it shows:nsURI: http://www.eclipse.org/hyades/models/symptom1_0
Why in the error message it shows:uri:"NULL"? I post the problem in TPTP board for more help.
[Updated on: Thu, 05 August 2010 02:38]
Re: Package with uri 'null' not found ERROR [message #551050 is a reply to message #551048] Thu, 05 August 2010 02:50 Go to previous messageGo to next message
You've read the overview articles and you've looked at the FAQ?
> a factory.a
Re: Package with uri 'null' not found ERROR [message #551053 is a reply to message #551050] Thu, 05 August 2010 03:14 Go to previous messageGo to next message
Yes,after reading the FAQ, i added the code below to register the package:
Maybe i didn't quite understand it?
Re: Package with uri 'null' not found ERROR [message #551174 is a reply to message #551053] Thu, 05 August 2010 13:46 Go to previous message
--------------030908020701060907050504
Content-Type: text/plain; charset=UTF-8; format=flowed
You need to find the resource factory implementation that Hyades uses to
load. If you're writing a stand alone application, you'll want to read
this and take note that I've mentioned several times the need to
register the correct resource factory.
2.16 How do I use EMF in standalone applications (such as an
ordinary main)?
< http://wiki.eclipse.org/index.php/EMF/FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F>
> package:
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
to load.  If you're writing a stand alone application, you'll want to
read this and take note that I've mentioned several times the need to
register the correct resource factory.<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F"><span
class="tocnumber">2.16</span> <span class="toctext">How do I use EMF
in standalone applications (such as an ordinary main)?</span></a><br>
</blockquote>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:jobsheng@gmail.com">jobsheng@gmail.com</a> wrote:
<blockquote cite="mid:i3daba$ssu$1@build.eclipse.org" type="cite">Yes,after
<br>
<blockquote type="cite">SymptomPackage symPack =
SymptomPackageImpl.init(); System.out.println(symPack.eNS_URI);
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------030908020701060907050504--
Previous Topic:Model Importer Implementation
Next Topic:[EMF] Create a model instance from a DynamicEObject
Current Time: Fri Apr 20 13:06:32 GMT 2018
Powered by FUDForum. Page generated in 0.01903 seconds
