Home » Eclipse Projects » Eclipse Platform » Eclipse flags ALL XML tags as invalid.
Eclipse flags ALL XML tags as invalid. [message #550443] Fri, 30 July 2010 11:55 Go to next message
Paul  is currently offline Paul Friend
Hi guys,
I have had this problem for a long while, but have a few minutes to actually try and fix it and I can't.
If I create the following file called test.jsp
<hello>
<world>Blah</world>
</hello>
Then Eclipse highlights "<hello>" and "<world>" with a warning, "Unknown Tag"
It also highlights </world> and </hello> red with the descriptive "Error" and no other information.
I have played about with JSP validation settings and XML validation settings, but nothing seems to say, "Eclipse, leave it alone, it's custom XML or an XML format you don't know about, just let me know about obvious XML structure errors, ignore the tags!"
This is Eclipse 3.4.2 but I have had the problem since Eclipse 3.2 or 3.3
The errors exist no matter what type of XML I am using.
I generally just ignore eclipse, but I'd still like to fix it someday Smile
Paul
[Updated on: Fri, 30 July 2010 11:56]
Report message to a moderator
Re: Eclipse flags ALL XML tags as invalid. [message #550455 is a reply to message #550443] Fri, 30 July 2010 12:27 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
What editor are you using? ALT+SHIFT+F1 can tell you if it's not
obvious (and you're using a recent enough version of eclipse).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Eclipse flags ALL XML tags as invalid. [message #550463 is a reply to message #550455] Fri, 30 July 2010 13:10 Go to previous messageGo to next message
JSP Editor apparently.
The active editor class:
StructuredTextEditor
The contributing plug-in:
org.eclipse.jst.jsp.ui (1.1.312.v200901290909)
The active editor identifier:
org.eclipse.jst.jsp.core.jspsource.source
The active menu contribution identifiers:
org.eclipse.jst.jsp.core.jspsource.source.EditorContext
org.eclipse.jst.jsp.core.jspsource.source.RulerContext
#OverviewRulerContext
org.eclipse.wst.sse.ui.StructuredTextEditor.EditorContext
org.eclipse.jst.jsp.core.jspsource.source.source.EditorConte xt
org.eclipse.wst.sse.ui.StructuredTextEditor.RulerContext
org.eclipse.jst.jsp.core.jspsource.source.source.RulerContex t
Paul
Re: Eclipse flags ALL XML tags as invalid. [message #550468 is a reply to message #550463] Fri, 30 July 2010 13:20 Go to previous messageGo to next message
If it's supposed to be able to handle arbitrary XML instead of just
HTML, you should 1) ask in eclipse.webtools or 2) open a bug against
Webtools/JSP source editing.
PW
Paul Webster
Re: Eclipse flags ALL XML tags as invalid. [message #550484 is a reply to message #550468] Fri, 30 July 2010 14:06 Go to previous message
Okay, thanks Smile
Previous Topic:Creating projects in workspace subfolders
Next Topic:How to detect node selection change in CN inside Editor
Current Time: Sat Feb 24 10:41:00 GMT 2018
Powered by FUDForum. Page generated in 0.02436 seconds
