Home » Eclipse Projects » Buckminster » why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created(on Client pc)
why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created [message #550189] Thu, 29 July 2010 13:45 Go to next message
Amel Jakupovic is currently offline Amel JakupovicFriend
Member
Hy guys,
when I publish product build with buckminster3.5/hudson to client pc. When product is started, it's created this folder.
Why ?
On windows it's possible to create, but on linux it's dificult Smile
thanks
Re: why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created [message #550196 is a reply to message #550189] Thu, 29 July 2010 13:58 Go to previous messageGo to next message
Philipp Nanz is currently offline Philipp NanzFriend
Member
Seems to be related to this P2 bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=273821
I have also found the folder /opt/public/technology/epp/epp_build/35/eclipse/ being created on my workstation, but I couldn't track down the exact circumstances
Re: why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created [message #550207 is a reply to message #550189] Thu, 29 July 2010 14:19 Go to previous messageGo to next message
Member
I read that we must use -roming parameter in product.ant.
but I don't know (can't find) what this parameter is for. is boolean, path...
thanks Philipp
Re: why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created [message #550248 is a reply to message #550189] Thu, 29 July 2010 15:31 Go to previous messageGo to next message
Member
I put it in product.ant <ant value="-roaming"/>
same.
now I found the parameter -shared
now I will try with that param.
this is all parametrs from direcotr:
http://www.linuxtopia.org/online_books/eclipse_documentation /eclipse_platform_plug-in_developer_guide/topic/org.eclipse. platform.doc.isv/guide/eclipse_platform_plugin_p2_director.h tml
thanks
Re: why /var/lib/hudson/jobs/xyz/workspace/buckminster.output is created [message #550270 is a reply to message #550189] Thu, 29 July 2010 16:59 Go to previous message
Member
I risolved like this.
I publis product on local PC (without hudson). Zip it and publish it to all clients.
After that client start the application, and when go to install new software everything works fine.
Previous Topic:java.io.FileNotFoundException: /tmp/p2.brandingIron
Next Topic:Include dynamically created rootfiles in p2 site
Current Time: Fri Feb 23 16:53:02 GMT 2018
Powered by FUDForum. Page generated in 0.01984 seconds
