Home » Newcomers » Newcomers » Missing requirement org.eclipse.cor.runtime
Missing requirement org.eclipse.cor.runtime [message #550024] Wed, 28 July 2010 19:20 Go to next message
Nitesh Verma is currently offline Nitesh VermaFriend
i am trying to install Black Berry web pluggin in Eclipse Helios
but i am getting the following error of missing dependencies:
Cannot complete the install because one or more required items could not be found.
Software being installed: BlackBerry Web Development Plug-in 1.0.0.200907241249-33 (net.rim.browser.tools.feature.feature.group 1.0.0.200907241249-33)
Missing requirement: BlackBerry Web Development Plug-in 1.0.0.200907241249-33 (net.rim.browser.tools.feature.feature.group 1.0.0.200907241249-33) requires 'org.eclipse.core.runtime [3.4.0,3.5.0)' but it could not be found
can anyone help
Thanks in advance,
Nitesh
Re: Missing requirement org.eclipse.cor.runtime [message #550038 is a reply to message #550024] Wed, 28 July 2010 20:11 Go to previous messageGo to next message
Nitesh,
Apparently that plugin declares that it just won't work with version 3.5
or higher of the core runtime so you shouldn't expect to install it in
Helios or Galileo.
Nitesh Verma wrote:
> not be found.
> can anyone help
> Thanks in advance,
> Nitesh
Re: Missing requirement org.eclipse.cor.runtime [message #550044 is a reply to message #550038] Wed, 28 July 2010 20:58 Go to previous messageGo to next message
Thanks for your quick reply.
In the plugin website it is given that the requirement is eclipse 3.5
http://na.blackberry.com/eng/developers/browserdev/eclipsepl ugin.jsp
how can i have org.eclipse.core.runtime in my eclipse.
and if it is present how can i check..
Re: Missing requirement org.eclipse.cor.runtime [message #550064 is a reply to message #550044] Thu, 29 July 2010 02:03 Go to previous messageGo to next message
Nitesh,
The message requires 'org.eclipse.core.runtime [3.4.0,3.5.0)' tells me
that the inclusive lower bound in 3.4.0 and the exclusive upper bound is
3.5.0 so that sounds like the Ganymede version of Eclipse, i.e., the 3.4
release. So to me, whatever you're installing will only install into
Ganymede.
Use Help->About Eclipse SDK->Installation Details->Plug-ins to see what
plugin versions are in your installation.
Re: Missing requirement org.eclipse.cor.runtime [message #550362 is a reply to message #550064] Fri, 30 July 2010 06:18 Go to previous message
Thanks Ed Merks.
Its working on Ganymede version of Eclipse.
Previous Topic:Failed to run RCP application after migration from eclipse 3.1 to eclipse 3.2
Next Topic:Cannot get Eclipse Helios to run on windows 7 with Java
Current Time: Fri Feb 23 01:04:07 GMT 2018
Powered by FUDForum. Page generated in 0.03126 seconds
