Home » Eclipse Projects » P2 » After migrating to Eclipse Helios, updating my RCP fails(Using the p2 feature shows me the menu items for update, but not the functionality)
After migrating to Eclipse Helios, updating my RCP fails [message #549995] Wed, 28 July 2010 16:48
Tobias Hoppenthaler is currently offline Tobias HoppenthalerFriend
After migrating my RCP app to eclipse helios I seem to be unable to update. When I click Help>Check for Updates I get the message
Cannot complete the request. This installation has not been configured properly for Software Updates. See the error log for details.
The error log contains the following:
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2010-07-27 10:14:11.773
!MESSAGE The update checker service is not initialized
I also noticed that when I click Help>About and then in the about dialog I click Installation Details, I get an NPE and the log says:
!ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2010-07-27 10:17:18.920
!MESSAGE Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini file.
!ENTRY org.eclipse.ui 4 0 2010-07-27 10:18:10.873
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.equinox.internal.p2.ui.ProvUIActivator.addProvis ioningListener(ProvUIActivator.java:106)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. createViewer(InstalledIUGroup.java:75)
at org.eclipse.equinox.internal.p2.ui.dialogs.StructuredIUGroup .createGroupComposite(StructuredIUGroup.java:80)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. <init>(InstalledIUGroup.java:51)
at org.eclipse.equinox.p2.ui.InstalledSoftwarePage.createContro l(InstalledSoftwarePage.java:95)
at org.eclipse.ui.internal.about.InstallationDialog.tabSelected (InstallationDialog.java:274)
at org.eclipse.ui.internal.about.InstallationDialog.createConte nts(InstallationDialog.java:245)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialo g.java:126)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(Ab outDialog.java:121)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.about.AboutHandler.execute(AboutHand ler.java:32)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.company.Application.start(DiflowApplication.java:41)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!ENTRY org.eclipse.core.jobs 4 2 2010-07-27 10:18:10.874
!MESSAGE An internal error occurred during: "Fetching children of _SELF_".
!STACK 0
at org.eclipse.equinox.internal.p2.ui.model.ProfileElement.getQ ueryable(ProfileElement.java:55)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDes criptor(QueryProvider.java:54)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetc hChildren(QueriedElement.java:102)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElemen t.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I found this:
http://www.eclipse.org/forums/index.php?t=tree&th=171233 &
and did as suggested, but the problem remained like before
PLEASE HELP!
-- Tobias
Previous Topic:no profile when installing with p2 installer?
Next Topic:Referencing a fragment instance in a touchpoint action
Current Time: Mon May 21 07:20:17 GMT 2018
Powered by FUDForum. Page generated in 0.02026 seconds
